Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 Is this a good setup for the t-rex 600? >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 12-26-2006 | 04:03 AM
Default Is this a good setup for the t-rex 600?
Please let me know if what I have listed here will be good for my t-rex 600. I'm getting all of it from rchover.com
1. T-rex 600 aluminum combo (600L+75G ESC+3A BEC)
2. Gyro 401/Futaba 9650 servo
3. Hitec Hs-65MG x 3 servos
4. DX7 Transmitter with receiver
5. 6s 22.2V 4600 mah battery
6. Astro 109 charger
7. 600mm CF blades
Do I need Deans connectors?
These are parts that I've found to be the best according to everybody else's advise. Anything else I need to make everything complete?
Old 12-26-2006 | 08:22 AM
VinceHerman's Avatar
Default RE: Is this a good setup for the t-rex 600?
Those servos are great for the T-Rex 450. Do people really use them on the 600? They might, I just have not heard of that.
My brother went higher end on his 600, with all digital servos, so that is not a good comparison.
Vince
Old 12-26-2006 | 10:13 AM
My Feedback: (18)
you want to go with a better servo than those . those are not goint to hold up , i have 9206 in mine . they work great , wonly have put 9451's but i would have have to buy one and did not want to spend thmoney on mine . the 401 /9254 is fine ,
Old 12-26-2006 | 01:15 PM
Is the ball link sizing tool and control rod setup tool necessary for me to buy?
I switched out the Hitec HS-65 MG x 3 servos with three Futaba S9252 servos and chose the Futaba GY401 gyro with 9254 digital servo.
Old 12-26-2006 | 06:27 PM
My Feedback: (18)
i found that on my trex i did not need to size the links but the rod tool is a must. i got the one that goes on the dig calipers from rick' sweb site . best on the market i would say. the 9252 will be good servos but you may want 'to look into the 9451's better servo for a few dollars more . the 401 is agood gyro . i am have ing some problem's with mine . it hold's strong but . i can not get a little wag to go away. i may just have to live with it . i know it's not the gyro . it came off a freya and was great on that bird .
