Training Gear Question
MD
I bought training gear for a 30 to 90 size heli. It seems like the training gear is a little big, but I figured that is better than it being to small.
So, my question is:
Are their any hazards to having large training gear on the Heli?
Can I attach the gear using zip ties rather than the rubber bands? It seems like the gear would move around with the rubber bands that are provided in the kit.
So, my question is:
The training gear that is made for the 600 Trex is 20 inches on each of the four legs. It is 40 inches over all.
Zip ties work well. The rubberbands work but are not as strong. I have used both. I like the zip ties better.
Generally if the heli is trimed without training gear it will still be in trim with it installled.
I bought two 36" long carbon fiber hollow rods to use for my training gear.
these turned out to be unnessary, so I cut them off at 24" each.
The biggest concern of large landing gear is the weight it adds.
on a Trex 450 you want a low weight training gear, so carbon fiber rods are just right.
And I used nylon zip-ties to attach them.
Harry [8D]
Harry [8D]
TX
rstroup,
I'd think the rubber bands are for some flexibility. If you land a little hard the rubber bands may give a little to prevent damage to the skids or a tip over.
Ted
Ted
