Tamiya Monster Trucks Discuss classics all Tamiya Monster trucks from the Clodbuster to the TXT1 and everything in between!
What's a strong diff
Old 01-09-2012 | 03:28 AM
phmaximus's Avatar
Default What's a strong diff
Hey guys I've been developing a crawler based on a cut up TL01B chassis...
But it keeps on stripping the axle splines, I've even tried lock tight but eventually it fails.
Any ideas... I think the weakest link the the bevel gears, they seem heaps softer than the hardened diff outputs and strip more.
ATM it's stripped the rear right, but the splines and lock tight are still in good shape on the diff out put yoke?
Old 01-09-2012 | 03:31 AM
phmaximus's Avatar
Default RE: What's a strong diff
Here are a few pics of the chassis, well whats left lol
Old 01-09-2012 | 05:01 AM
The Mad Modder's Avatar
Try genuine Tamiya parts?
Old 01-10-2012 | 01:50 AM
phmaximus's Avatar
Yep done that... I've even stripped a one way diff and a manta ray diff, 2 tamiya diffs and 2 hbx, same car just different setup
If only there were steel not cast bevel gears or a one piece locked diff
Old 01-11-2012 | 05:31 AM
The chassis was designed to be a sedan and later expanded to be buggy. It was never intended to be driven offroad with 2.2 truck or crawler tires. You might try 1.9 wheels and tires to reduce some of that stress. Also I'd lower the rear a bit to reduce the extreme angle the driveshafts are at.
Old 01-11-2012 | 04:34 PM
phmaximus's Avatar
know that, Ive even got a Baja King
Dont see how changing the wheels will help, I know it wasent designed to have 2.2 wheels but these exact diffs, out put shafts, drive shafts are the same as what a wild dagger & tamiya twin detonator????
well thanks for your help, seems there is no one around?????
OK ive worked it out all by my self, im going to get a spool and run the TT01 drive cups #53790
Old 04-04-2012 | 12:47 PM
Eman77's Avatar
I assume something like diffs from a CR-01 (which was built to crawl) won't fit/work for you?
Old 05-15-2012 | 06:02 AM
phmaximus's Avatar
No bud totally different.
How's its been a while, still haven't fixed it, been 3 wheeling every where.
Well I'm going to order these
http://www.ebay.com.au/itm/Alloy-sol...#ht_1513wt_823
http://www.ebay.com.au/itm/Tamiya-53...#ht_1678wt_922
