joining alu tube?
Anyone know of a strong joining method to weld alu tube to alu tube without a TIG welder. Its to build a 1/3rd scale cub airframe. Thanks in advance Brent aka sir crash....</p>
ORIGINAL: frequent flyer
You might take a look at this http://www.aluminumrepair.com/video_new.asp it may help you . I have use it with success.
If the tube is going into a "socket", rough up the end of the tube and the inside of the socket and use JB Weld.
I make ALL my wing struts from K&S aluminum streamlined tubing using JB Weld and have not had a single
failure. I have had a couple of "unscheduled landings" that have turned the struts into pretzels - the JB Weld
joint was still intact.
I use a product called DURA FIX. It's really easy to work with just a propane tourch. I have made muffler's, motor mount's, exsuast extensions, reinforced landing gear's and a bunch of other stuff. Check out their web site at DURAFIX.COM. and watch the videos or go to YouTube and watch from there. I think you will like it. My club member's didn't believe you could work alu without a Tigwelder. They believe it NOW. Tony.
