Wing bolt tool
Some wing bolts have dome shaped slotted heads for use with a standard screwdriver, while others have nut shaped heads for use with a socket tool, or have a centre hex shaped slot for use with an Allen key.
Karol
Karol
The tool below is invaluable as it perfoms the solution to the problem you have already found and it also will assist you as you build more planes.
[link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXK356&P=ML[/link]
ORIGINAL: karolh
Karol
Karol
The centre, light gray part is raised approximately 3/8" from the circular plate below.
ORIGINAL: grosbeak
Then there's this type, which is what I have. The bolt from the top looks roughly like this:
The centre, light gray part is raised approximately 3/8'' from the circular plate below.
