please help
Old 09-16-2002 | 12:25 AM
Default please help
i got some thin CA on my just finished covering job is there any way to get this off without recovering or messing the covering up that i have?
Old 09-16-2002 | 02:00 AM
Default please help
What is the covering made of? If monokote I'd try a little acetone. If it is paint, I'd just leave it alone.
Old 09-16-2002 | 02:09 AM
Default please help
I just tried debonder on a bit of Monokote, don't waste your money. It never worked
Just in case you were wondering
Old 09-16-2002 | 06:08 AM
My Feedback: (41)
Default I've used acetone and debonder
on two different occasions and it worked for me. Maybe it depends on the brand of CA and the actual formula. They needed to be rubbed gently and with quite a bit of liquid. I had a case of all sorts of fingerprints and they disappeared.
Old 09-16-2002 | 09:57 AM
Default please help
Acetone will work, but you will have to keep it wet. Try putting a small piece of paper towel over the glue and keep the paper towel sautrated with acetone. It will eventually soften it up and remove it.
Vince
Old 09-16-2002 | 07:43 PM
Default please help
its ultracoat,i was going to try acetone or something but i didnt want to melt my covering
Old 09-17-2002 | 01:15 AM
Default please help
I've actually used a small amount of Top-Flite Trim Solvent on a small rag several times and it worked with no problems for both MonoKote and Ultracote. Don't wet it to much and rub lightly.
I can't stand it when that dreaded CA transfers from the fingers to the covering.
Old 09-17-2002 | 08:26 PM
Default please help
Use Acetone on a Q-Tip. It works great. You can buy it at Home Depot, and Acetone is cheap.
