What paint for polyurethane over glass finish?
My Feedback: (35)
WA
What is the lightest paint that I can use for a waterbased poly over fiberglass finish ? Since this is an electric plane no fuel proofing is required. Tks
Latex is one of the lightest paints (when dry ) and compatible with just about everything.
If you are going to be using yellow, have a base coat of silver (preferred ) or white, otherwise you will need MULTIPLE coats to cover.
