RE: Scale Gee Bee Z question.
Finally I found a toy store nearby that had the satin and matt variant of the colors that i use so this weekend there is going to be a test to see if it's good.
Still need to buy solartex for covering but as always I bought something else instead and this time it was Reflex XTR. |
Hi
Problem again when I start building on the Gee Bee, sent a mail to Adrian and got an reply but I can't figure out where it should attach anyway. There shall be two musicwires that are attached to the landinggear and some other place. When I measure on the drawing it should be 24cm long and that is where the landinggear goes into the wing on my plane. The exact text that are on the plan #1 is L. gear cross brace-1/16 thread end rod-solder to 5/32 wheel collar this is only 24cm long and attach where the landinggear goes into the wing for me. Anybody with some pictures? Another problem is how you have mounted the firewall it's 1/8 aircraft ply, have you just glued it or boltet it? Update: Anybody with pictures to help me? |
| All times are GMT -8. The time now is 09:02 AM. |
