Traxxas Monster Truck forum Discuss the Traxxas T-Maxx, E-Maxx, Super-Maxx and all other Traxxas monster trucks in this forum. You may also optionally discuss them in our MT general discussion forum.
Bulkless Conversion Problem
Old 03-19-2006 | 12:37 AM
Default Bulkless Conversion Problem
Well, a friend of mine bought a TMaxx 3.3 and then went crazy buying upgrades for it. Anyway, he ended up putting in an aluminum bulkless conversion. Anyone familiar with doing this? I am not at all. Anyway, now that it's all installed and everything... his truck won't roll forward like mine does. Mine will roll freely across the ground... because nothing is engaging. His truck, if you push it on the ground, the wheels just slide, unless you put some force down on them, then they will rotated with the driveshaft and stuff. But it doesn't roll freely. ANY solutions or ideas as to what this would be?
Old 03-19-2006 | 12:45 AM
Default RE: Bulkless Conversion Problem
what bulkless system is it?
are the differentials put in the right way?
Old 03-19-2006 | 12:46 AM
sounds like something is binding in the diffs... post some pics if you can...
Old 03-19-2006 | 09:20 AM
Or maybe the brakes are adjusted too tight....
Old 03-19-2006 | 09:43 AM
First thought...I'd agree with Kliff, sounds like the brake is too tight.
If one diff is installed backwards the truck will not roll at all with all four tires on the ground. However, it would roll freely with either the front tires up or the back tires up.
Lastly, the bulkless set up I had (FLM) you had to make sure the bearings were seated properly or the diffs would bind when the case was bolted together. A slight tap on each bearing to seat it cured the problem.
Old 03-19-2006 | 10:57 AM
Thanks for the info guys... after removing the diffs and everything, they seems to spin ok. Then after reinstalling them, they didn't. Turns out... the center drive shaft was a little too long and wedged in there.
Old 03-19-2006 | 01:34 PM
What is a bulkless conversion? Bulk=Bulkhead?
Old 03-19-2006 | 03:52 PM
It is a bulkhead + diff case machined out of 1 single piece of aluminum.
Old 03-19-2006 | 06:22 PM
Woa that sounds nuts. Does it take the slop out of the diffs? I don't know about you guys but the diff cases are kinda sloppy in the bulkhead, it came like that. It seems like if they can flex aroound in there a little that might reduce the initial "punch" getting to the ground.
Old 03-19-2006 | 06:25 PM
there isnt too much slop in there to begin with. However, it gets rid of the wholediff case which is nice.
Later
Old 03-19-2006 | 07:29 PM
Who makes this part?
Old 03-19-2006 | 08:04 PM
flm and unlimited engineering.
Old 03-19-2006 | 09:04 PM
Maybe I'm an idiot but neither of their websites shows a pictue of that particular part
Old 03-19-2006 | 09:14 PM
Here's a direct link to the Hybrid bulks I had on my Maxx...
http://www.fastlanemachine.com/Publi...6/Default.aspx
Or for the absolute highest quality go w/ UE (Supermaxx) VBS Bulkless...
http://www.unlimitedengineering.com/...re/10301T.html
Old 03-19-2006 | 10:37 PM
Thanks, I saw those on there site. I should have been more specific, I have a Revo
Old 03-19-2006 | 11:06 PM
i would go with the FLM ones, even if you do break them, they have the "Fast Lane’s extreme abuse warranty. Replacement cost per side $15.00." and they are 400$ less than the UE ones, so you could break them MANY times and still save money over the UE ones
Old 03-19-2006 | 11:59 PM
I have those FLM ones and my only complaint is that I was unable to use the barces that the bumper screwes into, making it hard to attach the bumper. besides that, i love it. it comes with everything you need to install it. besure you remember how the diffs go in, cause i didnt, it sucked.
