LB Getting Ready for SNOW - Kyosho EP Blizzard DF-300 Thread!
#1577
QC, CANADA
RE: LB Getting Ready for SNOW - Kyosho EP Blizzard DF-300 Thread!
ORIGINAL: Lunchboxer
Looks great!! Be sure to show us some action pics when you hit the snow today!!
I'm not 100% happy with the body cut and decals that I found very difficult to work with. The paint is a metallic red that didn't show very well on the pictures but it's much better in real.
I did the basic mods (bb, 120k diff, brake pad, reverse steering) and it is really easy to drive inside. Now I can wait to test it in the real world !
#1578
Looks pretty good to me.. but yeah, metallic paint usually show up better in person.. maybe a pic under the sun will show the metallic particals better!
#1580
OH
exactly what you need....great detail in this one...
http://cgi.ebay.com/ws/eBayISAPI.dll...m=320328945577
#1581
I will be trying mine with a Mamba Max with the stock motor or 3S shortly, I just need some connectors and fix a few drivetrain issues.
#1582
NL, CANADA
Got the disc brakes done today, really straight forward, but doesn't seems to work that well, on the Making Trax site, those pads or something will improve the brakes right?
(Sorry about the pictures, camera was dropped on the floor before which now makes pictures a bit bad quality. It's starting to make me mad. [:@][:@])
#1583
NL, CANADA
One side track chain and suspension are finished. The other will be done soon...
#1584
NL, CANADA
I uses the wrong locknuts at the brakes, so I had to take everything apart today. [:@]
I never looked carefully with the instructions, but at the next part of the build I will be ready. Pictures tomorrow.
#1585
QC, CANADA
First outdoor run today.
Good speed with the current 19t pinion, I will try a 21t or 23t soon. I was able to take some small jumps and I'm really surprised by how it can be fun like it is.
The run ended too soon because of an unglued velcro that made the cab rubbing against the track. Things I have to change/check for the next run :
- loosen the brake a little (course is too short)
- change current velcro for some industrial kind
- change pinion gear.
I will also try to take some pictures.
So far I'm very pleased with this truck.
#1586
No need to mess around with 21 or 23t. I'm running a 4600kv with 27t and it's still has tons of torque. Internal ratio is 5.633. Stock gearing is 25.5 :1.
#1587
QC, CANADA
ORIGINAL: secretsg
#1588
Couple of pics from yest. Temp was 12 deg F. 18" of super dry powder. Snow is actually too soft and the front wants to dig in. Running a sidewinder / 4600 & 7 cell 5000. It is a rocket on ground where I plowed. Be nice to lighten the front in this super dry powder tho.
#1590
NL, CANADA
Got the tune pipe attached to the engine and the QRC unit was already assemble from the factory, so got that attached on the chassis easily. That's it for tonight. Will get the engine on the chassis soon...
Again sorry for the pictures, this camera is really getting on me. [:@]
#1591
Trivia for you. 6 cell 4200 nimh = 15.8 oz. 7 cell 5000 = 1lb 1.9 oz. My total wt including the 6 cell, sidewinder / 4600, Spektrum 3000, all lights & 9 volt dry cell, full bearings, Cen 144 oz servo, and radio box = 5 lbs 3.7 oz. Also, after running it last year, all rubber shielded bearings are as free as new and the diff with 100k losi fluid is not leaking at all.
#1592
Glad to hear that your Blizzard has held up to your abuse, I mean, use, for a year.. and no problem so far!!
#1593
PA
lunchboxer thanks for posting video of the blizzard you just saved me a hole lot
of money man that blizzard is sad in the snow i think a tmax could out do the
blizzard snow ps thank you again iam about the speed [8D]the blizzard is still cool looking
is the nitro one any faster??
#1595
Snow cats are definitely not for speed. They are built to go anywhere in very soft ground conditions. Real snow cats are lucky to go 15mph downhill.
I could never get my RC trucks to work very well in snow. If the snow was old and had thawed and froze the truck would stay on top enough to have fun. Otherwise the rear tires would just dig straight down into the snow and the truck would not go anywhere.
#1596
My monster trucks would work okay up to maybe 5-6" of snow...
After that, it is all Blizzard..
#1597
I put the Bliz on the laptop and took out some brake. Helped alot from nosing in off throttle. Also got some new snow with a bit of moisture in it. Much more fun now. It's running super good. I think the CC 4600 is working out just about perfect for a Bliz.
#1598
Does anyone know if the Turborix 2.4GHz 6 channel radio left stick can be made self centering ?
Perhaps by moving springs from the right stick ? (AFAIK that seems to be the a common solution).
The radio is about 42 USD
http://www.r2hobbies.com/proddetail....cps61206_61411
#1599
No idea.. but if I have to guess, it should be able to. I don't see a reason for the manufactuer to design 2 different gimbal systems for the left and the right control sticks..
