VPP or PPS
Interesting choice here, either the VPP from Hobby Lobby or the PPS from OMP. It seems that OMP has a better motor or so they claim, however, there are nto thrust or RPM figures for it. Has any one got the info for this motor? Also, which would be a better buy in terms of performance and reliability and after sales service? all opinions and suggestion are welcomed, as the info will be very helpful
if you check the blurb, it says something like 'wound to give 30% more power'? although the specs are the same as the AXI motor that it is, they just say you can use 2 OR 3 cells, where as AXI say 2. ( Graupner also do the same motor in black, woohoo. ) i believe the 30% more power bit, is refering to 30% more than the stock brushed setup. i got the conversion kit today, the new motor shaft is actually plastic tube, like white ABS, not wot i expected. also, i snapped both of the shaft retaining screws ( the ones the props O ring goes round in fixed pitch form ) trying to unscrew them !!! and yes, i used a soldering iron ( 70 watt ) to heat them up, it all got too hot to hold and the loctite? still would rather i snapped the screws than let go. Doh. anyways, i drilled them out and ran a 3mm tap through the holes and have got capheads ready for the rebuild. i hoped to purchase some of the steel tube that is linked to in the build your own vpp thread, they only ship international using FEDEX, $75 2 day, or $65 normal, for a $6 item. i don't think so, but in fairness, they were most helpful on the phone and i accept policy is policy. IF, anybody in europe knows of a source for a similar product? please drop me a pm or post a link for all to use. i may just order the 220834 with hollow shaft from hobbylobby when it comes available. cest la vie.
seems the plastic tube may not be the motor shaft, i have now got the pukka red axi with the hollow shaft from ikarus and it is a steel shaft.
a few more retractions folks. the red ikarus motor is not an axi 220454!!, it is similar though. the hub that a fixed pitch prop would be fitted to is around 4mm further forward from the rotor than the 220454. also, it is a 5mm long motor, it would be in axi terms a 2205?? ( question marks because the wind is a mystery ) . so, in conclusion, this motor may well have 30% more oomph than the little axi that it looks like.
Hi guys,
The VPP from HL is really poor about quality, I just received mine, and I don´t like it.
I never see the PPS from Ikarus, but in the pics looks like a much better product.
Sorry for my english.
Gaston
Argentina
Gaston
Argentina
the pitch slider arrangement from ikarus is good, it has 2 flanged ballraces on the slider. i think the ikarus hub system with the hobbylobby 220834 would be the dogs.
