Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic > WildHare R/C Support
 Whats the main difference between wild hare and extreme flight? >
WildHare R/C Support Disscuss WildHare RC products in this forum. Please note, answers may be provided by Tom Fawcett (owner of WildHare RC) or by the general membership.
Old 04-01-2008 | 02:59 AM
Default Whats the main difference between wild hare and extreme flight?
I have been deciding on a first 50cc plane and want to get a wild hare extra 300. People have told me that there is a big difference between extreme flight and wild hare and i just want a 3D plane. So, what it is?
Old 04-01-2008 | 07:05 AM
Scar's Avatar
Default RE: Whats the main difference between wild hare and extreme flight?
ORIGINAL: Bretd123
Seems like an odd question to post in the WildHare Support forum. Did you mean to post in the root 3D forum?
Best wishes,
Dave Olson
Old 04-01-2008 | 08:15 AM
My Feedback: (19)
ORIGINAL: Bretd123
Its hard to compare two of anything when they are not exactly the same as one will have its good and bad points and the other will have its good and bad points. But the main difference between the Wild Hare 50cc plane and other airplanes is about $200.00. Tom always seems to offer a greater overall value for the $.
Old 04-01-2008 | 08:53 AM
rctom's Avatar
ORIGINAL: Bretd123
I have not had an opportunity to evaluate an EF Extra personally, so I can only tell you what I see in the specs. The EF plane is a little larger, the fuse is a lot longer at 87", this dimension if accurate makes it way out of proportion from actual scale. The full scale Extra 300 fuselage to wing ratio is approximately .88 to 1, the EF plane is almost 1 to 1. The Wild Hare Extra's wing area is almost as great in spite of having a shorter span.
Their price is $649.95, ours is $429. Based on the size and published specs I'd expect the EF Extra to be heavier, consider this when buying an engine. I see no need for a larger plane with a 50cc engine, ours flies great and the light weight is perfect for a DA-50.
Beyond these details I don't see a big difference in the planes.
Oh, and we have some blue/yellow/white planes at $379 too.
I have wondered why there is so much traffic in the giant scale aerobatic RCU forum on EF. I can't find an EF support forum, I suppose that all their posts must go in the general column.
Finally it appears that EF is very much into electric planes and accessories, I feel that with giant scale it requires all my time to properly support the products so I have not branched out into other fields.
TF
Old 04-01-2008 | 11:31 AM
My Feedback: (134)
Don't know about EF, but I have been flying a Wild Hare Extra 300 for two seasons and is about as good as it gets. I have found no weak points to the plane at all. Flys much better than my 30% Carden Cap 230 which just sits around now. Don't think you can go wrong with the plane especially at the Price.
Old 04-01-2008 | 11:44 AM
I've flown and handled both makes, with most of the W/H planes in similar sizes. In the long run the difference is price. W/H does not make a large Yak (thank God), so the difference ends there.
At least one EF Yak flier wishes his plane would turn/pivot as well as a W/H. Tom's designs work, and wing designs with W/H is superior to most others.
Old 04-01-2008 | 02:15 PM
Cool, i wasnt wanting an extreme flight, its just that i would like to get an idea how the Wild hare planes were going to fly, I'v just been told that there is no comparison of how the two planes fly. My friend has a wild hare Edge 540t v2 and I figured that if I got one that he could help me out. By the way, My friend says he knows someone from wild hare personaly his name is Mark Summerfield.
Old 04-01-2008 | 03:43 PM
I have the WH Edge V1 and the Ultimate Biplane. The edge is on its 4th season with a DA50. It is like an old friend now. I know what it will do with any control I give it. It will fly docile or crazy. Piece of cake to land. STILL gets good reviews at the flying field. As I understand it, the V2 flies even better. I just haven't been able to kill the V1!!!!!!!!
Customer support with Tom at WH is second to none. You will have a smile from ear to ear when you open the box on your WH plane and an even bigger one when you fly it.
Go for it!!!
John
Old 04-01-2008 | 05:40 PM
There's only two people to know. Tom and Patty Fawcett.
Old 04-01-2008 | 06:09 PM
I am very happy with my Edge V2. I would not hesitate to purchase another WH product.
Fitz
Old 04-01-2008 | 07:46 PM
If you want the best support money can buy get the wildhare. extreme flite you can not call in the evening or weekends Rich I own 7 of his planes
Old 04-01-2008 | 08:19 PM
My Feedback: (8)
The biggest difference is the price and the size. Both EF and WH are absolutely top-quality airplanes, easily the best in the business.
The EF planes for their higher prices include a very nice hardware kit with carbon wing and stab tubes and wing bags. It is also so large that not many 50cc planes can really handle it.
The WH planes require a hardware kit, which is about $75 more (IIRC). Or you can supply your own.
If I had one I would use an 80cc engine (weighs the same as a 50cc + cannister). The fuse on the EF Yak and Extra is roughly the same size as the 80cc Hangar 9 planes.
The WH planes will certainly tumble better due to the relatively shorter fuse, and they float better because they weigh less on about the same wing area. Both are very good at IMAC-type flying.
Both companies are very good at customer service and try very hard to keep their customers happy. Tom takes the next step and actually sponsors his own forum here on RCU and posts many times daily.
Old 04-01-2008 | 09:28 PM
rctom's Avatar
All our newer planes come with wing bags too.
TF
Old 04-01-2008 | 11:24 PM
Right now i am working on a Giant super sportster. I really wish that i wouldnt have gotten the thing[:@]. i know that it will be really boring to fly. i got an EVO 35Gt and it took so many modifications to put it on. This plane has crappy hardware and this is probably more expensive than a wild hare with a DL50,[:@] which is what i plan to get next.
My Feedback: (8)
ORIGINAL: rctom
TF
Very nice, I didn't realize that!
Bretd123, in the end just pick the one that looks best to you. You really can't go wrong either way.
Old 04-02-2008 | 12:15 AM
How much for a set of bags for the 50cc Edge V2
Fitz
Old 04-02-2008 | 12:30 AM
oh yeah, i forgot to ask, will a DL 50 be just as easy to put on as a DA50?
Old 04-02-2008 | 05:41 AM
My Feedback: (8)
ORIGINAL: Bretd123
The setup is identical.
Old 04-02-2008 | 07:37 AM
rctom's Avatar
ORIGINAL: flyingfitz
Fitz
$30 plus shipping.
Old 04-02-2008 | 08:59 PM
Henna Ojisan's Avatar
I have the 50cc V2 Extra and my buddy has the 50CC EF Extra. Other than the points already mentioned as far as kit components and cost - they fly very similar in nature. I have been hucking my Extra around and it is a confidence inspiring plane, I flew my buddies plane and they felt very similar - almost the same actually. We are very close as far as weight and he has the ES Composites pipe where I have the MTW-75K can (both on DA50). He'll have more power on the pipe than my can but it will require some tuning to keep it from being peaky. The Either way you go - you will be pleased and they both are great!
Jason
