Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
Reload this Page >
Cut cooling slots in CF Spinner
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 03-04-2013, 05:59 PM
crashlander
My Feedback: (10)
Default Cut cooling slots in CF Spinner
I have acquired a new Carbon Fiber spinner and would like to cut cooling slots in the spinner section and the backplate.
Anyone out there know how to do this or can give me idea on how to?
Thank you
Crashlander
Old 03-04-2013, 07:52 PM
Jetdesign
My Feedback: (8)
Jetdesign's Avatar
Default RE: Cut cooling slots in CF Spinner
Here are two examples:
http://www.f3aunlimited.com/webstore...roducts_id=693
http://www.f3aunlimited.com/webstore...roducts_id=659
I would measure and mark, cut with a dremel cut-off wheel, and finish by hand with sandpaper, probably glued to a small dowel. Then balance.
Old 03-04-2013, 09:17 PM
toddblose
My Feedback: (10)
toddblose's Avatar
See if this helps
http://toddblose.homestead.com/Da-Ja-Vu_Build3.html
Old 03-05-2013, 08:52 AM
crashlander
My Feedback: (10)
Thanks guys for the ideas and help. I will try them.
Crashlander
Old 03-07-2013, 10:22 AM
crashlander
My Feedback: (10)
OK guys, completed the project-cut two slots in the spinner. Came out very nice, almost pro looking, a little clearcoat should enhance it a bit more.
Balancing is another matter. It is not easy to balance a spinner, considerably more time taking than balancing a prop.
I have tried several times and still cannot balance the spinner to my satisfaction-still have a heavy side. Right now, it is going to stay like that until I get some force to try again.
Orlando
Old 03-07-2013, 06:35 PM
nonstoprc
My Feedback: (90)
nonstoprc's Avatar
Could stick some duck tape on the lighter side to balance it out. A small piece is all it takes.
Old 03-07-2013, 06:43 PM
Bill Clark
Bill Clark's Avatar
maybe try small peices of tape to get it to balance then remove material 180deg opposite. may also try balancing it in 2 planes.
dont know if it will help but page 16 of the Bolly Book http://www.bolly.com.au/1998%20Bolly%20Book%20v3.pdf outlines some advanced propeller balancing techniques that may be applied to the spinner
Old 03-07-2013, 07:22 PM
crashlander
My Feedback: (10)
I never thought about adding some tape. Great idea. I'll try that. I have been using CA with micro-ballons. Difficult to do.
Orlando
Old 03-08-2013, 06:57 PM
Jetdesign
My Feedback: (8)
Jetdesign's Avatar
Are you balancing the back plate separately? I would think removing material in the back plate with a drill would be the way to go there. For the cone, well I use scotch tape on the back of my prop tips and it works really well.
Old 03-09-2013, 06:12 AM
crashlander
My Feedback: (10)
I have been balancing both the backplate and spinner separately. However, I believe they should be balanced as a unit. The problem is if you have to change props, -start all over again?
Orlando
