Welcome to Club SAITO !
Old 08-23-2011, 11:00 PM
  #20651
Rudolph Hart
Rudolph Hart's Avatar
Default RE: Welcome to Club SAITO !
I don't run on board glo with any of my singles or the 182 twin,they run fine like that.I have read some threads here tho and it seems to be a world of pain for some.If anyone here can recommend a proven setup you can run off the onboard flight pack i would be pleased to hear of it as i may need to run one on the 200r3 initially.It's going into a blackhorse 120 size texan and what with retracts and all i'll have my hands busy enough on the test flight without worrying about a deadstick,we have short runway approaches here.I've just run a litre of 20% nitro 15% klotz and 5% castor thru the engine and it's firing on all three above 4000rpm.Last run was at 6500 and i could take the glow stick i'd left on one cylinder off,no problems.Just how much bench time do you guys think i'll need for it to settle down a bit and does anyone have an approx main needle setting for the 170 or 200?.Reason i ask is that the engine test reviewer said he was running 4.75 turns out,figured that may be a typo?? but will want to start leaning it off shortly.Cheers
Old 08-23-2011, 11:01 PM
  #20652
FNQFLYER
Barry Wetherell, are you the same Barry that used to work for Ansett in Cairns???
Old 08-23-2011, 11:02 PM
  #20653
Rudolph Hart
Sorry for the double post
Old 08-23-2011, 11:46 PM
  #20654
barry wetherell
NQ,... no i have never been to QLD, i day I hope perhps the wetherell was spelt differently, but don't hold me on that
there are not many of us around, my grandfather he was an only male, came from UK in 1905, he only had 1 son, my dad, I am the only son from dad, I have 2 sons, but therein W.A
Barry
Old 08-24-2011, 01:22 AM
  #20655
the pope
ORIGINAL: Old Fart
Yes it's the lower left cylinder,just worried about doing some damage.Temps feel fine on the other two while running.A local magazine has run one and i can't get anywhere near what he says to do at the moment.They ran 20% nitro and 22% mix of syn and castor,against my ten and 18% mix at 5000 for the first fifteen minutes.I might hop out to the shed and up the nitro to 20% and set the rpm to five thousand,will up the oil to 20% as well.Not suffering from a voltage drop across multiple glow drivers am using a single stick 2200mh nimh on each cylinder.
Howdy O.F. I think we all know what mag that is and who is the purveyor of b.s. also is. It would be wise to take what he says with a grain of salt. Let me guess what he said, Three quick primes two more flips , power on and a back flip against compression and it was singing a merry song. Probably copy and paste from a earier long forgotton review. Cheers the pope
Old 08-24-2011, 03:36 AM
  #20656
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
OF Saito considers it flyable after 40 minutes, if you have it on a test stand, fire it up and warm up until it will run with no glow power then slowly chase the rpm up leaning the HS needle about one click at a time. When it starts to sound ever so slightly labored it should slow on the next click toward lean. Back er up three clicks rich which should be about 50 rpm below the peak then set the LS needle. Easy Peazy, go fly at your normal 200 or 300 rich of peak setting. If you take the time to set the needles correctly after 40 minutes unitial run they will change very little if any over more time. Honest
Old 08-24-2011, 03:52 AM
  #20657
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Cory, this one on the left fits all from the .50 through the 1.25.
http://search.horizonhobby.com/index...d=131FB9D4D39B
Old 08-24-2011, 06:37 AM
  #20658
blw
blw's Avatar
OF- got the duplicate post for you.
Hobbsy's break in directions are the way you should do it. The only thing I would suggest is to give it some wide open time except on the first 10 minutes. I start running mine hard as soon as they start smoothing out and needing leaning. I don't worry about letting them sing along at full throttle on the test stand. That's what they are meant to do. You can learn a lot about how it is breaking in by listening to it when wide open.
Old 08-24-2011, 02:20 PM
  #20659
FNQFLYER
On breaking / running in.  When I visited the Saito factory in Japan during my Malaysian Airline period of employment I gained a very valuable bit of advice.
They said that one should start the engine at the richest seting it would take (starting it at factory setting and richening was they way it was also explained) and run the engine at wide open throttle and increasing the engine speed gradually by leaning out.  This was for the first 10 oz of fuel.  (20% nitro 20% oil).  Successive runs were at leaner settings (they said the engine will tell you and it does) with runs (short) at max throttle setting (note no max rpm) for a couple of more tanks of fuel.  The engine should then be able to sustain transition without any problems.  Then go fly the engine while progressively leaning the engine to get the factory recommended rpm range etc.
Points to note.  \1/ I accept that the LS needle is set correctly at the factory (unless proven otherwise)
2/ I accept that the HS neddle is set correctly and open it up from there
With rebuilds I set at factory setting prior to start up.
In all cases I note the start datum settings prior to any engine running.
I have found Saito engines more than any other are engines that react to feel and sound.  I use a Tachometer for all engine runs and power set ups and listen to and observe the engine if you are attentive it will talk to you just like a bit round P&W or an offenhauser
Old 08-24-2011, 02:36 PM
  #20660
FNQFLYER
On engine handling.  I have just acquired a 115 and yet again I see that the data we here in OZ are provided with in the box the engine comes in is different to that you guys get in the US.  Ours appears to be more detailed and it comes with you beaut stickers and publicity stuff as well.
And while on that subject has any one laid hands on the new Saitos with the red rocker covers / heads.  I have only seen photos in one of our OZ magazines
Old 08-24-2011, 03:20 PM
  #20661
Craig 01
G'day FNQFLYER,
Those cnc, red anodised saito covers are a aftermarket part to add "bling" and supposedly help cooling.I"m not sure who manufactures them and there is a small write up on them in the latest aussie rag.
Heres a link to them,
http://www.hhq.com.au/store/cart.php...tegory_id=2741
and here with a different name on them.
http://secraft.net/shop/step1.php?number=909
http://secraft.net/shop/step1.php?number=915
http://secraft.net/shop/step1.php?number=978
I must admit they do look good and i like the Ti/silver .
Old 08-24-2011, 06:35 PM
  #20662
FNQFLYER
Saito manufacture them so I am informed but only for the bigger engines, I want some black ones for my Stinson Reliant or cream or red dependong on which a/c I am going to model it after.  I read BW's comments on them
 we once showed him some o/t a/c that "performed" some what different to what he said they were capable of.  I believe he attempted to compete in a couple of our events and "didn't quite perform according to reputation"
Old 08-24-2011, 06:55 PM
  #20663
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Our instructions say the first 10 minutes is a 1/4 to 1/3rd open not fully open, it doesn't make sense to run it stone cold at full throttle during the most important 10 minutes of its life.
Old 08-24-2011, 08:19 PM
  #20664
FNQFLYER
As I said run it as rich as it will stand on full throttle.  This usually results in a Saito 65 for example running at around 4000rpm. At this RPM with a very rich mixture the engine doesn't get hot at all.  With the throttle wide open you then increase the rpm by leaning it.  This method gives max cooling, max lubrication for the first run.  Then you start with the ups and downs etc with the second and successive runs
This works for us, BTB it is a modification (slightly) to the instructions given in our data.
I am puzzled by the difference in operating instructions.  Ours come from Saito and the US ones appear to be generated by Horizon Hobbies.  This opens another can of worms when one starts playing with the gas engines but that is another matter totally on which I cannot yet comment based on experience that is
Old 08-25-2011, 03:52 AM
  #20665
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
There is nothing in a Saitos construction that can benefit from heat cycling, also its much better to have the engine components close to their normal operating temp to seat in to each other at normal tolerances.
Old 08-25-2011, 04:30 AM
  #20666
Rudolph Hart
Hello guys and many many thanks for your comments,they were good and easier to understand
Old 08-25-2011, 04:50 AM
  #20667
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
OF, are you being just a might facitious?[8D]
Old 08-25-2011, 07:06 AM
  #20668
blw
blw's Avatar
The only hard rule I go by is to keep the engine at, or below 4k on the first tank. It is already wearing, changing balances, tolerances, etc and getting everything mated together.
Old 08-25-2011, 10:59 AM
  #20669
Daniel-EL
My Feedback: (9)
Daniel-EL's Avatar
The 0.015 decompression shims for the Saito 150 were once offered by C&H Electronics, but they are no longer in business. Anybody have a suggestion where they might now be found now and purchased?[]
Old 08-25-2011, 12:02 PM
  #20670
w8ye
My Feedback: (16)
w8ye's Avatar
It is not a critical area.
You can make a gasket from gasket material from the auto parts.
Trim out the i.d. mount the cylinder and then trim off the outside with a #11 Exacto blade.
Old 08-25-2011, 01:49 PM
  #20671
Rudolph Hart
ME?
Old 08-25-2011, 10:02 PM
  #20672
JariV
Hello,
if someone is having trouble with Saito radial engines dropping a cylinder during flight then there is a cure for that. I had this problem with my FA90R3 radial dropping a cylinder during flight and with throttle positions from half throttle to full throttle. I am using Keleo exhaust ring. The reason is that the engine is not getting enough fuel in high rpms. I added a Perry oscillating fuel pump and adjusted the fuel pressure and the trouble is completely gone. Works very well and full power available all the time. Just to let you guys know if someone has the same problem. First I thought it was glowplug related problem but I tested that extensively with many different plug sets.
Old 08-26-2011, 04:36 AM
  #20673
clytle374
I'm subscribed to this thread, but quit getting emails.
I removed the previous exhaust system, and just used the rcspecialties 90 and the 15 deg manifold. I gained a another 300 rpm and can now lean it out to 9000rpm.
I think the exhaust with a flair and a nut like and OS would work great with my cowl, any of the OS ones fit the 100? I'd still need a pressure tap. Here's a picture of the 90 with the hole drilled. Any ideas on how to test if I'm getting any pressure? I wanted to tap the flat side of the 90, but it was too thin to hold imo.
Cory
Old 08-26-2011, 05:01 AM
  #20674
w8ye
My Feedback: (16)
w8ye's Avatar
Nothing "OS" will fit anything "Saito 100"
Old 08-26-2011, 06:08 AM
  #20675
hsukaria
I am not sure this is the correct forum to ask this question, but it has to do with my Saito 180 nitro engine.
I acquired it used but have not started it yet. I plan on starting it this weekend (tomorrow). I heard from here that I should add some light oil into the pushrod tubes before starting it. In the past, I used Automatic Transmission Fluid (ATF) to store other engines. Will ATF work ok to pre-lube a Saito before starting from storage? Is there a maximum limit to how much oil there should be in the engine before cranking it with a starter to avoid hydrolock?
Thanks.
