Reload this Page >
JACK STAFFORD Models Aircoupe's
Old 05-20-2006, 01:26 PM
  #76
WacoNut
WacoNut's Avatar
Default RE: JACK STAFFORD Models Aircoupe's
ORIGINAL: maekju
CubNut,
Great job on the Aircoupe. I'm not building one I just like to read through the kit building forum to pick up tips and tricks. I noticed in one of your earlier post, you said you were using Robart hinges and in another post with a pic it looks like you have a few installed on the ailerons before you begin painting. If you did install those hinges, how did you remove them when you were ready for priming? I have a CG Ultimate I want to get back to and I have some Robart hinges and would like to use them.
I had the hinges just pushed into the holes while I was getting the plane built and ready for paint, I just pulled them out when I started to put primer on the plane. I will install them with epoxy when I do the final assembly.
Anthony
Old 05-20-2006, 01:30 PM
  #77
WacoNut
WacoNut's Avatar
I decided to throw plane #1 together and let it sit out in the sun to cure the paint while I work on painting plane #2. As you can see from the pics I still need to paint the roundels on the wings and airbrush the red and white stripes on the rudders. I think it is looking good so far[8D]
Anthony
ID:	464098   Click image for larger version
ID:	464099   Click image for larger version
Old 05-20-2006, 07:37 PM
  #78
mrbigg
My Feedback: (21)
mrbigg's Avatar
Anthony, I see you have my plane about finished. PM me and I'll send you my address so you can get it shipped out right away![sm=lol.gif] I wish!
Seriously, nice work!
Old 05-20-2006, 08:00 PM
  #79
TexasAirBoss
My Feedback: (22)
TexasAirBoss's Avatar
Looks great !!!!
Well, don't you just love scale planes ? I have two of the Comanches that need building.......................
Those colors really pop ! Fantastic !
Can you hear them ask, " is that an ARF ?".
Tell them yes, $129 from Horizon.
Old 05-21-2006, 04:55 PM
  #80
WacoNut
WacoNut's Avatar
Thanks Guys,
I have the blue painted on Plane#2 and it looks great, I have the roundels and the rudders painted on Plane#1.
Here is a few pics!!
Anthony
ID:	464628   Click image for larger version
ID:	464629   Click image for larger version
Old 05-21-2006, 06:50 PM
  #81
WacoNut
WacoNut's Avatar
A couple more pics to end the day,
I added the wing walks and painted the cockpit black and added the instrument panel. I am very happy with how everything is turning out.
Later!
Anthony
ID:	464650   Click image for larger version
Old 05-22-2006, 05:28 AM
  #82
bassman
It's looking great. Someday I will get back to mine. Most of the planes I have seen with the red and white ruder stripe had a vertical blue stripe on the leading edge of the rudder. Are you coping a particular plane that didn't have it? After all the work what did the all up weight come in at? What brand of paint are you using and how hard and resilient a surface did you end up with. I am thinking about paint over fiberglass.
Bassman
Old 05-22-2006, 08:01 AM
  #83
WacoNut
WacoNut's Avatar
Bassman,
Good Eye I still have to paint the blue stripe on the rudders, I am copying form a particular plane. The surface is fairly strong, not as strong as fiberglass but much stronger than monokote. The paint is Behr semi-gloss latex and the graphics are Testors Model Master paints. The weight minus aileron servo's,receiver and battery is 5.5lbs. Should wind up with a all up weight of 6.5 lbs.
Anthony
Old 05-22-2006, 09:27 AM
  #84
bassman
Will you end up with a fuel proof finish or are you going to overspray with fuel proof clear?
Bassman
Old 05-22-2006, 09:30 AM
  #85
WacoNut
WacoNut's Avatar
I will be spraying on a coat of Nelson's Hobby Specialies clear gloss for fuel proofing.
Anthony
Old 05-24-2006, 07:47 PM
  #86
WacoNut
WacoNut's Avatar
I have plane #2 painted and I am waiting for the paint to cure to apply the Graphics. I learned from some mistakes on plane #1 and #2 is turning out great.
Here is a couple pics of how it looks now.
Anthony
ID:	466118   Click image for larger version
ID:	466119   Click image for larger version
Old 05-28-2006, 04:27 PM
  #87
WacoNut
WacoNut's Avatar
I finally got around to painting the Blue Stripe on the leading edge of the rudders. I am paiting the roundels on plane #2 now.
Later!!
Anthony
ID:	467715   Click image for larger version
Old 05-29-2006, 11:10 AM
  #88
WacoNut
WacoNut's Avatar
Both Planes are now painted,
I will let them cure for a few days before clear coating. The miaden flights for the planes will be June 23rd weather permitting.
Later!!
Anthony
ID:	468091   Click image for larger version
ID:	468092   Click image for larger version
Old 05-29-2006, 11:12 AM
  #89
WacoNut
WacoNut's Avatar
A few more final Pics!!
ID:	468097   Click image for larger version
ID:	468098   Click image for larger version
Old 05-29-2006, 04:11 PM
  #90
bassman
Fantastic job. If and when I ever get back to mine I will use your pictures as inspiration. Where did you get the detail on the airframe panels and rivet patterns?
Bassman
Old 05-29-2006, 05:51 PM
  #91
WacoNut
WacoNut's Avatar
ORIGINAL: bassman
Bassman
Bassman,
I picked up what detail I could from pics from this site and a couple other pics I found on the net. Here is a link to a site with some good pics [link]http://www.scaleaero.com/ercoupe.htm[/link] I spaced my rivets 1/4" apart. It takes longer to layout where to put them than to put them on.
Later!
Anthony
Old 06-01-2006, 02:52 PM
  #92
ekir
Anthony
Your Ercoupe looks great. I might have to order the Ercoupe and start a summer building session.
I have a couple questions;
1. Was the Ercoupe quicker and easier to build that the Sig Clipped Wing Cub?
2. Does anyone have experinece flying the Ercoupe? Is it a good flying aircraft? Would it fly like the Cub?
Ed
Old 06-01-2006, 05:02 PM
  #93
TexasAirBoss
My Feedback: (22)
Its been years since I built my Ercoupe. I thought it was a tough kit to build. They do fly like a trainer at low speeds. However, they are capable of remarkable top speeds. They out run Super Sportsters !! You do need to pay particular attention when landing. The rudders and fins hang down below the stab. It is easy to knock them loose . I fly from grass. And its not that smooth. Bouncing around on the ground makes me nervous. So I generally don't do touch and goes. ( which was my original intention, a scale T-n-G bird ).
So, I generally grab a chair and sit down and slow fly the entire tank. It is hypnotizing to watch. But I am building the Ercoupe's replacement. A scale Sig Bonanza which I hope will be more T-n-G friendly.
Old 06-01-2006, 05:46 PM
  #94
WacoNut
WacoNut's Avatar
ORIGINAL: ekir
Anthony
Ed
Hi Ed nice to hear from you again
The Coupe is a quicker build than the C/W Cub, it is still a builders kit and it will reck your brain in a few areas but that is half the fun. I am guessing I have around 200hrs in each plane start to finish, not that bad for as much detail I put into them. I am also very pleased with the weight, JSM says 5-6 lbs. my plane with the OS .61 4-stroke(Old Design) weighs 6.5 lbs dry. Plane #2 with an OS .52 4-stroke (New Design) weighs 5.5 lbs dry. I can tell by looking at them that with all that dihedral in the wings they should be very easy and gentle to fly at low speeds like PilotFighter says.
If you decide to build one I will try to help you as much as possible with the build, I have alot of build pics that I did not post here in the build thread.
Later!!
Anthony
Old 06-17-2006, 01:14 PM
  #95
WacoNut
WacoNut's Avatar
I finally got my pilots painted,installed and the canopies glued into place. The planes will take to the air next Friday.
Anthony
ID:	478879   Click image for larger version
ID:	478880   Click image for larger version
ID:	478881   Click image for larger version
Old 06-24-2006, 12:24 PM
  #96
WacoNut
WacoNut's Avatar
We sucessfully flew both Aircoupe's today,
The .52 4-stroke seems to be a perfect match for the plane. Most of the flying is done at less than 1/2 throttle. The plane with the .61 4-stroke is very fast and most of the flying was done at 1/3 throttle or less.
The planes are very stable and predictable at all speed ranges, they do tend to float on landing and will take a BIG BOUNCE if they are not set down very gentle. All in all I am very happy with how they fly.
Later!
Anthony
Old 06-24-2006, 09:31 PM
  #97
WacoNut
WacoNut's Avatar
I took a few pics of my buddy flying his Aircoupe, unfortunately my camea is not that good for distance shots. We put 6 flights on each plane today. We just finished doing a post flight inspection and makeing minor adjustments and making sure everything is tight.
We will be flying again tomorrow.
Anthony
ID:	482201   Click image for larger version
ID:	482202   Click image for larger version
Old 06-25-2006, 05:52 AM
  #98
Mr_Scale
My Feedback: (7)
Congratulations Anthony. They look great!
Old 06-25-2006, 06:29 AM
  #99
bassman
I have always loved the way the Blue and yellow color scheme looks in the air. Great job on the planes. Any issues upon post flight examination? I am still in the middle of another project. As soon as it flies the coupe if next.
Bassman
Old 06-25-2006, 07:56 AM
  #100
WacoNut
WacoNut's Avatar
The main gear developed a little slot in the gear block, I reinforced it with epoxy lastnight. I will see how it does during today's flying session.
Later!!
Anthony
