DLE 20cc Gasser! (Data & Links 1st Post)    Gallery
Logged in as Guest
Users viewing this topic: Red7fifty
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> DLE 20cc Gasser! (Data & Links 1st Post)
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
DLE 20cc Gasser! (Data & Links 1st Post) - 7/14/2010 10:38 AM  2 votes
jedijody
Score: 309
Last Login: 1/15/2013
Status: offline
OK, went out and flew the DLE20 this evening, it's an excellent runner especially for it's size. The SD Models 60" profile it was in weighed 7 lbs. 15 ounces dry. The 6 ounce fuel tank I used will run for 10 minute flight and still be 1/3 full. When was the last time you could fly all weekend on 1/2 gallon of fuel? Took some thrust numbers on the props I posted RPMs on the other day. I'm sure there may be some other props that might produce a little more but I used what I had laying around the test bench, should be enough to get a pretty good idea of what it'll do.
 APC Sport 16x7 9000 RPM 14lbs. 7oz.
JXF Beech 16x8 8300           13lbs. 10oz.
JXF Beech 17x7 7970           13lbs. 12oz.
SY 16x8              8500             13lbs. 5oz.
SY 17x8N           8200             14lbs. 9oz.
So far it's running like a watch and I haven't exactly been nice to it either, 3 hrs on a test stand and another hour on a plane tonight in only about 3/4 of a gallon of gas. I'll get some video soon, the videographer had to put his skirt on tonight for the wife at the last minute.
It weighs 29.2 ounces with everything, more power than a CRRC Pro 26 or a Saito 1.25 and has unique timing curve in the Rcexl ignition that lets it idle at 1500 RPM. I'll try to get some thrust numbers with a couple props then also. Should just be able to make out the tach reading in the last picture of it idling at 1410.
quote:
ORIGINAL:JediJody
The DLE20 requires 32:1 minimum fuel/oil ratio, read the manual. We administrate the DLE warranty for Aeroworks, if your engine has a failure and inspection reveals that the factory recommended oil raio could have prevented it it would not be covered under warranty.
EDIT UPDATE: Added this collection of data at Jody's request
quote:
ORIGINAL: a1pcfixer
Recapping the bits & pieces of info on this new engine, here's the
DLE 20cc gas engine details (misc updated info added).......
[Basic Info]
Advertised weight: 29.2 oz with ign. and muffler
Prop range: 16 X 8 to 18 X 6
Rear Carb
Beam style mount
DLE20cc mfg stated - compression ratio 10.5:1
Tower Hobbies - compression ratio 7.6:1
[Dimensions]
Motor mount bolt spacing is 1'', case width is 1-7/8''
Center to center spacing on engine bolts is 2.400"
Distance from firewall to prop washer is 5-11/16''
From the center of the rear mounting hole to the edge of the open choke valve is 2-5/16''
Distance from propeller hub to the front of the cylinder: 42 mm
Width of cylinder at exhaust port: 56 mm
Distance from the center line to the top of spark plug cap: 120 mm
(with spark plug cap fully inserted).
Prop shaft size : M8 x1.0 mm (w/two nuts)
[Muffler]
Stock muffler dimensions;
2.260" tall @ end caps - 3.800" incl exh pipe
1.100" thick out from exh port of eng
2.050" wide @ end caps
Pitts style muffler (optional);
Jtec wrap around muffler.......
J'tec Muffler Dimensions.....
[Ignition info]
Stock sparkplug is a made in China CM-6 type (DLE 3)
Valley View R/C will include true NGK/CM-6
Electronic auto advance ignition
Ignition is a new model (#3- or- #4) and special designed for this engine.
DLE recommended voltage range 4.8-6.0 volts
A 4-cell NiMh/NiCd of 1650-2000mAh is a good starting point
quote:
Oiginal:Jedijody
The manuals on Tower's website incorrectly state the timing as 45 deg. BTDC. The DLE factory does indeed attempt to set the timing at 32* on all their engines, with varying degrees of success, they run best set at 28-30. The ignitions for the rear carbed 30 and the 20 do have a different timing curve with more retard to help them idle better, the full advance and static timing is the same as all the rest, 28-30 BTDC.
[Ignition current consumption + ign voltage issues]
Ignition draw + Voltage issues......
Ignition current consumption.....
[Prop Data]:
Vess 17x6 14lb. 8oz. - Great throttle response and crappy tach showed 8549RPM
Vess 17x8 14lb. 0oz. - Great throttle response only slightly less RPM than 17x6
Vess 18x6 14lb. 3oz. - Above average throttle response, may be perfect when fully broken in
Vess 16x8 13lb. 9oz. RPM through the roof (by ear) and instant throttle response spools up like an electric motor!
Zinger 16x8 - stinks, no power, way low on thrust
APC 17x4W 3D prop - decent but the idle transition was terrible, 9700 rpm!
Xoar 16x8 - Good prop but not as much thrust on the high end as the next one...
Xoar 17x6 - Hands down the best prop so far. Great punch out of hover, great top end, improved low end but more to come on this....
MA K-series 15x8 2 blade- 13lbs 11oz @ 9750 rpm.
MA K-series 15x10 2 blade- 12lbs 13oz @ 8400 rpm.
Xoar 15x8- 13lbs 5oz @ 9000 rpm.
The MA 15x8 and Xoar 15x8 have unbelievable throttle response
MA K-series 15x6 3-blade 13.0lbs @ 9100 rpm
NO thrust numbers for 4-blade props....YET!
[VIDEO's]
Jody Haack - test flight video......
Test run of DLE20cc......
First bench run (mpascualslp).......
and the engine response after 1 hour (mpascualslp)......
FUNTANA 125 WITH DLE 20.....
[Photos]
DLE20cc engine dissasembled photos......
Exhaust diverter.....
Link to ALL photos on this DLE20cc msg thread......
[Interesting comments]
same mount size as OS 1.20
a 20cc is a drop in replacement for .90 to 1.20 size four stroke
more power than a CRRC Pro 26 or a Saito 1.25 (Saito FG-20/gasser)
20cc = 1.20 c.i.
30cc = 1.80 c.i.
The Jtech {muffler} is supposed to be quieter {than the stock one}
and that is important to me
When propping aerobatic planes the most important engine aspect to
consider {is} the torque curve, peak torque comes in at approximately
3/4 of the peak HP RPM, so you want a prop that loads the engine in
a manner that takes advantage of that RPM band, typically these are
the larger props in an engines acceptable use range.
prop the engine for the performance you want for the airframe it's
mounted on, forget about the "break in prop" they are unnecessary
[Warranty]
Valley View R/C; 1 year
Tower Hobbies; 2 years
[Ordering info....]
Valley View RC.....
DLE20cc @ Tower Hobbies.......
[Owners manual]
DLE20cc Factory Manual.....
DLE20cc Tower manual.....
Jody's gas engine tuning tips (pdf files);
http://www.rcuniverse.com/forum/fb.asp?m=10293852
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by w8ye -- 6/24/2012 12:56 AM >
_____________________________
Now go outside and play
Hide Signatures
       Post #: 1
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/14/2010 12:03 PM
mpascual
Score: 115
Last Login: 12/27/2012
Status: offline
Many thanks for the info ...
Regards
Hide Signatures
(in reply to jedijody)
       Post #: 2
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/14/2010 3:22 PM
JNorton
Score: 149
Last Login: 6/19/2013
Status: offline
Subscribed.
Have desk ... Will Fly.... Saito Member #467
Ultimate Brotherhood #11, Ultra Sport Brotherhood #90
Hide Signatures
(in reply to mpascual)
       Post #: 3
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/14/2010 4:10 PM
w8ye
Score: 318
Status: offline
When is it going to be available?
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to JNorton)
       Post #: 4
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/14/2010 5:17 PM
Whistling Death
Score: 150
Last Login: 6/16/2013
Status: offline
This little engine is such good news for us. DLE won't be able to make them fast enough.
Now come on DLE you made half of my wishes (a 20cc and a 40 cc) come true now please make the other come true.
Blake
CORSAIR Brotherhood Lucky #13
Hide Signatures
(in reply to w8ye)
       Post #: 5
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/14/2010 6:02 PM
Lifer
Score: 153
Status: offline
Jody,
Any idea of it's price?
Hide Signatures
(in reply to Whistling Death)
       Post #: 6
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/14/2010 6:04 PM
ggraham500
Score: 108
Last Login: 6/17/2013
Status: offline
quote:
ORIGINAL: w8ye
and what price? If it sells around $200, IMHO it would be a huge seller.
With airplanes, keep the pointy end going forward as much as possible.
Hide Signatures
(in reply to w8ye)
       Post #: 7
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/14/2010 6:06 PM
TimBle
Score: 162
Last Login: 6/18/2013
Status: offline
Subscribed. This sounds like the ideal motor for the Ta152H I'm planning on building soon.
Many thanks for the heads up
Hide Signatures
(in reply to ggraham500)
       Post #: 8
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/14/2010 9:10 PM
jedijody
Score: 309
Status: offline
It came in a DLE30 box with no manual or special instructions. I'm using my regular mix of 87/89 octane pump gas and Stihl HP Ultra @ 32:1. The main bearings are both sealed and both ends of the rod are caged roller bearings but with revs this engine unloads to in flight I wouldn't want to run any less oil. Cylinder and piston are a scaled down version of the 30, carb and reed assembly appears to be the same as the 30, I didn't take the intake tract apart yet to verify that though, ignition has unique timing curve that allows it to idle real slow. The other modules work with it also but idle quality suffers.
It is a little loud for it's size, not as loud as a 30 on stock exhaust but.....power makes noise. I'm going to try my little 26cc canister on it later on but it might be a little much for a lot of 1.20 sized airframes to carry around.
My gut feeling is that it will be available before October but it will be more than $200, though it's less than 50% of a DLE55 in cubic capacity, the manufacturing cost is probably 70-75% of the bigger engine.
Hide Signatures
(in reply to TimBle)
       Post #: 9
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/14/2010 9:43 PM
krayzc-RCU
Score: 104
Status: offline
what size is the mounting ie 91-4 stroke or a 120 size ect?
smooth as silk!
Hide Signatures
       Post #: 10
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/14/2010 11:25 PM
jedijody
Score: 309
Status: offline
Bolt spacing is 1", case width is 1-7/8"
Hide Signatures
(in reply to krayzc-RCU)
       Post #: 11
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/14/2010 11:28 PM
seagull extra
Score: 100
Last Login: 5/13/2013
Status: offline
What is the weight differance RTF between the 30 and the 20?
Hide Signatures
       Post #: 12
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/14/2010 11:58 PM
jedijody
Score: 309
Status: offline
41 oz. for the 30, 29 oz. for the 20.
Includes mufflers stand-offs, ignitions, spark plugs, prop hardware, etc.
Hide Signatures
(in reply to seagull extra)
       Post #: 13
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/15/2010 12:21 AM
Edwin
Score: 156
Status: offline
Subscribed
Edwin
Hide Signatures
       Post #: 14
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/15/2010 12:32 AM
krayzc-RCU
Score: 104
Status: offline
thanks thats in line wiht a 120 size bottom end......
smooth as silk!
Hide Signatures
(in reply to Edwin)
       Post #: 15
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/15/2010 4:38 AM
BullardRM
Score: 100
Status: offline
Are these avaliable yet? TBM nor Tower have them listed.
Hide Signatures
       Post #: 16
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/15/2010 4:49 AM
ggraham500
Score: 108
Status: offline
not yet per Jody Haack (jedijodi) at Valley View. The engines are in test mode and won't be available until later. Some of us are guessing around October and unknown price.
Hide Signatures
(in reply to BullardRM)
       Post #: 17
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/15/2010 5:43 AM
litterbug
Score: 100
Last Login: 1/29/2013
Status: offline
This engine would solve my questions of what to get when entering into the gas market.
Familiarity breeds contempt.
Hide Signatures
       Post #: 18
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/15/2010 6:41 AM
fly24-7
Score: 119
Status: offline
What would be the minimum mounting distance (firewall to prop drive washer) without having to cut a hole in the firewall for the carb?
Never underestimate the importance of altitude...
Hide Signatures
(in reply to litterbug)
       Post #: 19
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/15/2010 7:10 AM
jedijody
Score: 309
Status: offline
5-11/16"
Hide Signatures
(in reply to fly24-7)
       Post #: 20
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/15/2010 4:13 PM
Bpar4
Score: 105
Status: offline
This looks wonderful.  Will have one when they are available.  The Saito 125 w/ muffler weighs ~25oz.  With an IBE this puts this 20cc engine in a bunch of airplanes.  And especially so if it is smooth runner.  Bob
Hide Signatures
       Post #: 21
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/15/2010 4:43 PM
Whistling Death
Score: 150
Status: offline
Here are the stats so far for those who have ADD or just won't read the whole thread.
All information is straight from jedijody.
Price:
"My gut feeling is that it will be available before October but it will be more than $200, though it's less than 50% of a DLE55 in cubic capacity, the manufacturing cost is probably 70-75% of the bigger engine."
Weight:
Dimensions:
Motor mount bolt spacing is 1", case width is 1-7/8"
Distance from firewall to prop washer is 5-11/16"
Prop Data:
Interesting quote:
"more power than a CRRC Pro 26 or a Saito 1.25"
Blake
Hide Signatures
(in reply to Bpar4)
       Post #: 22
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/15/2010 4:55 PM
TimBle
Score: 162
Status: offline
and more we don't need to know. just need to place on backorder asap
Hide Signatures
       Post #: 23
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/15/2010 6:40 PM
hairy46
Score: 183
Status: offline
Jody, How soon can they be preordered? I would like to get on a list, Thanks for letting us know! Bob
My doctor told me I would need allot more therapy, So I bought more airplanes!
Hide Signatures
       Post #: 24
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post) - 7/15/2010 7:47 PM
P-51B
Score: 2807
Last Login: 2/28/2013
Status: offline
Any chance they will change it to a radial mount instead of being set up for beams?
Hide Signatures
(in reply to hairy46)
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> DLE 20cc Gasser! (Data & Links 1st Post)
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
