The Official Traxxas Slash short-course race truck
#376
RE: The Official Traxxas Slash short-course race truck
ORIGINAL: bnangle
I noticed it pulled to the right though.I can do the adjustments to fix that
ORIGINAL: bnangle
when I installed the brushless system and my new Futaba 3pm radio I ran into some issues during test runs.First I hooked up everything as per directions throttle in channel steering in channel 1.I matched up the color traxxas brushless wires and turned on my readio.I noticed fwd trigger was not brake but throttle and squeezing the trigger gave me reverse.I reversed the channel and it works but I dont think I should have had to do that.
ORIGINAL: bnangle
Second I noticed that either stock or brushless this vehicle doesnt stop on a dime in fact it rolls at least 7 feet after letting go of the trigger.Isnt the a motor brake?
ORIGINAL: bnangle
Third I noticed that in the lawn at turns the body rubs the wheels and the suspension is very spongy.Is this normal?Well thats it for now but any advice would be great.The only help I can get is from you all.Thanks.I'll post pics when I can.Maybe tonight.
ORIGINAL: bnangle
I also have no Idea what settings to keep the radio at If anyone has some recommended settings I'll use them.
#377
ORIGINAL: bnangle
"If you are using a Futaba or Futaba OEM brand transmitter, you will need to set the transmitter’s throttle channel direction to the REVERSE (Rev) position. This is either an external micro switch on the transmitter or an option available within the computer programming of the transmitter’s throttle channel."
I believe it is the brushes contacting the commutator on a brushed motor that causes drag and a braking effect with the throttle in a neutral position. That plus whatever other resistance/friction is present througout the driveline including energy losses between the tire and ground and through suspension travel. Hmmm I suppose the magnetic fields in the motors will also add resistance. Brushless motors don't have that mechanical drag caused by brushes since it has no brushes, so it can actually roll out further on neutral before all the other factors are able to stop the truck from rolling. Most brushless ESC allow you to dial-in "drag brake" so the motor will provide the amount of braking you specify with the throtte in neutral.
#378
Another note on brakes: The brakes on the Slash are not as strong as on other electric vehicles I've driven, even using the same motor and ESC. I think this has to do with the added mass - this is substantially larger and heavier than a Stampede or Rustler.
#379
NY
Great thanks for the input.I got some really good points there.I just realized and forgot to add before, When I am in driving forward and I go to reverse nothing happens.I have to keep hitting the trigger.I think something may be off with the throttle settings but I am going to look at it later.I am going to post pics of my slash now if I can
#380
NY
#382
so, wheelies with the brushless motor? if you are going forward, and push the trigger to reverse, trhe truck should slow a LOT... you will notice it... if not, then either something is wrong with the ESC, or your radio is set up wrong. Go into the end point adjustment screen on your radio (EPA) and make sure forward and reverse are both at 100%.....
#383
NY
Dacaur, Actually I installed the wheeliebar mainly because most of the you tube videos on the Slash with brushless and lipo batteries were doing wheelies the whole time.I am not really a fan of wheelies in fact I liked how the stock rear bumper looks.I already have reinstalled instead of the wheelie bar.How do they do the wheelies though.Mine has even come close to a wheelie.Also I was wondering if anyone knew the best spur gear pinion combo for what I have setup right now.I have the stock spur gear and the opitional pinion the slash comes with I think it is 23t?Thanks Brian
#385
try putting the 19t pinion back on if you cant do wheelies, you need to gear down, you will lose speed, but not much, and gain power (acceleration) and run time... the wheelbase on the slash is a few inches longer than a rustler or stampede.
#386
NY
I am not really a wheelie guy but I want the right gearing for fast semi-level dirt field driving.I really enjoyed the slash on a local baseball field.Dust was everywhere and I like the rear end slides around turns.Its like the traxxas video on the real ones.
#387
UT
I wonder if you could mount that front bumper on a Rustler?? That'd be sweet! Apparently there's a bunch of parts on this truck that are compatible with the Rustler/pede. In fact it almost looks like the only difference is in the chassis. Tranny's the same and so are the arms, shock towers, suspension, front bulkhead... So this is almlost like another addition to the Rustler Stampede duo.... Now it's a trio!!! Mix and match, I love it!
Also... wouldn't the Slash look a bit better with bigger tires like some Talons or Mashers?? That big fat body just makes the tires look so tiny...
#389
NY
I recently noticed my spur gear wobbles as it goes round and seems warped.I removed the spur gear to find one of the frition pads was broke.How I donot know.I called traxxas up and they are sending me out a new spurgear and slipper clutch.They dont have the stock spurgear but the tech rep. said hes sending an 83t spurgear and a 16t pinion for me to use with the brushlees setup.He said its a great combination he uses on his slash and his electronics stay cool.I was very impressed with the traxxas technical support.It was no hassle and they are more than happy to send the parts I need.
I setup up 3pm radio the right way and I have no brake issues anymore.stops on a dime.
#390
ORIGINAL: simplecj
#391
NY
Does anyone know if they make metal spur gears or are they always plastic?Also I want to order a good lipo battery,Any ideas?Thanks
P.S. I am still trying to figure out the best gear combo for my slash.I am about to install 16t pinion on a 83t spur gear as per aTraxxas reps reccomendation.
#392
PA
I dont know of a metal spur gear that would work with the slash's slipper clutch but if you get the mesh perfect and make sure the three screws are locktighted and the gear is seated all the way down, this will reduce the wobble in the gear. Use a slip of paper, I like to use a reciept paper. push down with moderate pressure against the spur and tighten the screws back and forth a little at a time until tight. Now, spin the gear and look and feel for high spots in the gear. If you feel any amount of binding on the pinion, move the motor away from the spur gear slightly and then retighten. This should give you plenty of gear life. I run 11.1 v lipo and on asphalt and get very good life. If you get a lipo battery make sure you have a good balancing charger or external balancer. The protek batteriers are holding up well. Try to get 25c 7.4 but 20 c will do. I like the evo25 battery from flight power but it costs alot more. As for gearing, I run the mamba max 7700 and much lower gearing is needed for that motor so I cant comment on the vxl. I keep a temp gun handy and check often. Also try to get your battery at 4000mah or higher.
#393
UT
I got a 90T spur for my rustler that "wobbles". It seems like the center hole with the bearing isn't centered or something. It works ok, but it's noisier than the stock 83T spur. I think I need a new one...
#394
PA
ORIGINAL: bnangle
http://www.hot-racing.com/?partnumber=TE886H&c=416
#395
TX
I just loaded my diff with Bad Horsie Diff Locking Grease (I love this stuff):
http://www.badhorsie.com/products/diff-lock-grease.html
Whew! I hope I never have to open that transmission again. [sm=stupid.gif] I can already see a big reduction of wheel spin since the diff does not completely unload every time I turn in the parking lot. [sm=thumbs_up.gif]
#397
ORIGINAL: crazysavage
I found something
ORIGINAL: bnangle
Second, you dont want metal on metal gears unless they are steel, you never want any type of metal gear meshing with an aluminum gear, as the aluminum will wear fast. An aluminum pinion is fine on a plastic spur, but not with an aluminum or steel gear... Learn to set the slipper properly or take your finger off the throttle when you land from jumps and the plastic spur will last a long time....
#398
ORIGINAL: dacaur
OK, first, you dont want to buy anything from hot racing... poor quality, even worse quality control.
I found something
ORIGINAL: bnangle
Just curious if you are making the statement about Hot Racing from personal experience or from hearsay? I have used Hot Racing parts on several vehicles without any problems. I have had more problems with bad parts from Integy.
But I will agree he needs to learn to set the gear mesh properly or he will keep stripping the spur.
#399
ORIGINAL: t9dragon
Jus t curious if you are making the statement about Hot Racing from personal experience or from hearsay?
#400
Hey All,
My first experience with the Slash has been GREAT!!...of course, I can't drive for crap but other than that all is well....except, somehow I managed to lose a bottom spring retainer on the front shock. I was wondering if it would be okay to glue them on with a drop of CA....or is this some kind of "fluck" thing that only happens to me..[&:]
