Joe and Ed's Weedy 25cc gas boat. 48" Mono hull
#201
IL
RE: Joe and Ed's Weedy FX26 Xtreme gassy boat. Mono hull
Ed's first voyage was a success! Here are some pics and links to the outing. At least one of us is on the water!
http://s237.photobucket.com/albums/f...EdsBoat003.flv
http://s237.photobucket.com/albums/f...EdsBoat004.flv
http://i237.photobucket.com/albums/f...EdsBoat001.jpg
http://i237.photobucket.com/albums/f...EdsBoat005.jpg
Enjoy!
Ed sure does
Enjoy!
Ed sure does
#203
AZ
She didn't run quiet as good as I wanted her to but she ran! Needs a lot of adjustments. George, this weekend i'm going to put on that carb you sent me and see what that does. I was looking at the stinger drive and I noticed I tightened it up were the the drive was angled down. so I will fix that. And the rudder system I don't know if there is any hope for that but it turns sharper right than left, huh what do you do. need to work on getting my radio box sealed, I noticed it had a few leaks coming in from some were. Do you guys think the trim tabs that i bought will make a difference? There the same ones on Martin's old woody build. And I deffinetly have to figure out a exshaut sytem because of right now it blows stray towards the front of the boat I haven't had time to look at the link you sent me George about the exshaust mod but i'll look intoit when I get the chance. Oh and Mart, those boat your making look super cool, yah its a shame pricing is a lot to the U.S.
Here she is so far
We found out she is sea worthy in the pool
The first retreival with Joe's fishing pole
Here she is so far
#204
Congrats on your first run looks like a success now the fun starts,trying to get her upto speed .First ditch the carb for a wa167 walbro that will liven her up a lot,then play with prop angle depth etc.You should be able to take the cannister off and turn it round so the exhaust is facing backwards thats how i did mine .As for the tabs to be honest unless shes veering right a lot it leave them off,although turn fins will def help turns.Did you offset the drive to the right to overcome prop walk? that would help and also improve left turns too,you can also shim the drive over a tad so its angled left as you look from the back to counter any prop walk etc.Also make sure your prop is sharp and balanced it really does make a big difference .
Mart
PS thanks for the compliments,if you want one of my boats you could allways come pick her up for what hemi quoted lolollol [X(]
Mart
#205
IL
Hey guys i am trying to get the new carb on and actually run proper. The intake needs to be honed out but i am not quite sure how to all i have is files and that is taking forever i just don't want to overdue it. Is there a scientific way to get it done? It revs ok with the intake not quite as big as the carb inlet but i know it has more potential.[>:]
#206
IL
1. Im back! [X(]
2. anyone got some good pics of their engine mounts from a weedy for this size boat? i have some rubber bushings just dont like my mounts enough to go through with them.
3. How do you go about getting that position the motor should be mounted in. can anyone give me a link or some detailed instructions on how to do it.
4. any bumps on the honing out of the intake for a stock weedy 8mm to go to the 11mm walbro carb?
Thanks guys great to be back by the way!
#207
Leave the intake alone just open up the black isolator block a bit,as for mounts no pics sorry !!.mount the motor as low as possible the engle isnt that important just bend your tube to match the angle you mount it at.When you decide shes not fast enough buy a nice zen 260 ,you might even get a used one off someone.
Mart
Mart
#208
AZ
OK, having troubles with the carb Walbro WT433. Im starting the L and H at 1 1/2 turns out, won't even keep an idle. not at 1/2 turn, 3/4, 1, 1 1/4, 1 1/2. just don't know[:@] And I noticed there is fuel leeking from the bottom somwere near the carb or on the carb? I checked the diaphram its not ripped, but the metal circle turns, should it? well I put another diphram on still same thing, so i switched it back. I can not find the specs on this carb for what size it is. could it be to big? I'm frazeled Oh, and when I check my plug after running for 5-10 seconds and it's wet still has spark but wet, is that ok? Does ANYBODY know what is going on?????? AND HOW TO FIX???PLEASE HELP
New carb on left old on right
Here is the throttle body beveled out
#209
Hi mate im not familiar with that carb all i know is the wa 167 is the best carb for a weedy motor its has a 11mm bore,what bore is that one? if its more than 11-12 mm it might be too big.The leak could be a bad seal where the carb meets the isolator block(black plastic thing).Try the needles at 1 on low 1 1/2 on high and tune from there on the high one leave low at that for now it should start at that setting and run.
Mart
Mart
#210
AZ
The carb has a 11.11 mm bore. Thanks mart I think I might have try that. but ill try again. i'm pretty sure that seal is good but ill look again.
#212
Its hard to say as you only ran it for a few seconds so the fuel won t have brunt off from your intitial priming most likeley ,11.11 bore shouldnt be a problem,have you checked the diaprham is on the right way round ?.Im no mechanic ,maybe someone else can help you more sorry mate.
Mart
Mart
#213
IL
Hey guys i went with a 9/32 brass tube for the flex shaft now my shaft is 1/4 it is a bit sloppy will this be ok or will i have to get a tighter fit?
#215
It'll be impossible to hold a tune or idle if your leaking fuel from carb,most likely a bad gasket/iso block,resolve that issue first,.... [8D]
#216
Banned
ORIGINAL: gojoecrewchief1
#217
IL
well i went to the store today and exchanged the brass tube for 1/4" shaft fits nicely in there now just enough room for some grease. I bought most of my things from ACE hardware because they are one of the only places around that have a military discount which helps just enough! I made my motor mounts today and they look great, the motor will sit really low in the boat almost right on the bottom of the engine but with clearance. Tonight I would like to work on mounting the flex shaft tube. I would like to mount the engine but i dont have any of the strut, rudder, prop and radio box incorpirated yet so i cant get the 30% distribution. Havent taken many pics of what i have done because well im working [>:] hope you all are enjoying this as much as i am!
#218
Banned
glad to hear that you found a correct size brass tube for the shaft. you're doing a great job on your mono's building, that's kind of fun.
#219
AZ
OK can't the the WT443 carb to work, its leaking fuel from the bottum somewhere. But I did get the other carb that george sent me a while beck to run great!! how much diff do you think that 9.53mm carb will be? I take a look at the other carb later.
After I turned my can exshaust around now it blows into my engine[X(] so I am going to put some straight pipes running right out of the can. What size do you think the pipe should be so I don't stand a chance of to much back pressure?
One more thing, Found out that my paint isn't gas proof LOL. Does anyone know a kind of rattle spray that is gas resistant that I can get here in the states?
#220
try any car paints they should be fuel proof or get some clear coat from a car shop and coat your existing paint with it.as for outlet pipes just make em same size as existing outlet or a tad bigger.
#221
Banned
9.53 mm of the bore is a bit too small for a marine engine, go get a 15.44 mm big bore 257 carb, it'd only cost $26 from fleabay.
#222
ORIGINAL: rcboateric
Mart
#223
IL
Well i have gotten alot done since friday here are some updated pictures.
finished empty radio box, finished deck formers, finished motor mounts tell me what you think of them please!
I really am enjoying this i know that it is not perfect but it feels good to get off my ass and get out working with my hands again other than getting my Jeep stroker motor running. Any ideas are welcome please let me know.
I am also in the process of making a exhaust manifold/muffler. ill show steps when i know it works
#225
AZ
hey everyone, just been working on a let's say...different type of exhaust. It works actually really good, and pretty quiet. A lot quieter than the can. 3/8" stainless steel pipe, with just some plumbing couplings, and the internal part of the can. I really don't know how is gonna do on water, but the engine still has quick pick up. only time will tell
