www.Learning 3D step by step
#201
Banned
[8D][size=4]Hi people
[sm=thumbup.gif][color=red]Dear 3D beginners, good news, very good news
[color=blue]While outdoors it's snowing, I'm playing with Real Flight G2.
I'm flying with CAP 232 (I haven't add-on) and OS 1.20 4 stroke engine.
[sm=thumbup.gif]To learn torque roll I have understood we must use this TRICK:
We have to place the plane vertical slowly, holding it slightly bent forward. We must manage the trottle always. There is not a point where hold the engine stick fix. We must continue to move the trottle up and down slowly. We must use the rudder only for big corrections ("Pizza" is right).
[sm=thumbup.gif]THE RIGHT PITCH SETTING-UP IS THE KEY TO LEARN TORQUE ROLL.
PLAY UNTILL YOU ENJOY YOURSELVES.
[:@]Remember: we are not members of "practice and burning fuel brotherhood"
[color=green]Vittorio from Italy[sm=sunsmiley.gif]a beautiful country.
[color=blue]While outdoors it's snowing, I'm playing with Real Flight G2.I'm flying with CAP 232 (I haven't add-on) and OS 1.20 4 stroke engine.
We have to place the plane vertical slowly, holding it slightly bent forward. We must manage the trottle always. There is not a point where hold the engine stick fix. We must continue to move the trottle up and down slowly. We must use the rudder only for big corrections ("Pizza" is right).[sm=thumbup.gif]THE RIGHT PITCH SETTING-UP IS THE KEY TO LEARN TORQUE ROLL.
#202
OK Italian Flyer, do not practice but keep playing on the Realflight and then whenever you can, take your plane to the field and play with it repeating what you did on the simulator. Keep playing a lot on the field and you will find you can do the hovering and torque rolling easily. You call it playing and I will call it practice. As long as we burn a lot of fuel, it doesn't matter what we call it.
Pizza,
Your earlier post regarding stick exercises in the dark is very helpful. After practising as you outlined in your post, I tried it on the Realflight to nail the slow rolls and then rolling circles. One thing I find very helpful is as follows:
Take one of the 3D Top Cap or Extras downloaded from the net and reduce the time multiplier to 60-70%. This slows the plane down, giving more time for reacting and appropriate stick inputs. Then I go to the view menu and put the pilot position behind aircraft. This way, while flying slow rolls, I can see the result of the control inputs very close to the aircraft and polish the stick inputs to make the planes movement smooth. Its great for hand-eye coordination. I can aim for a point on the horizon to ensure that the slow rolls are axial and the plane follows a true line. I am slowly increasing the time multiplier back towards 100% as my skills improve.
I found the above helpful, hope others will try it and send their inputs.
Cheers!!
Pizza,
Cheers!!
#203
Banned
[color=blue]Dear "Krazyflyer",
about rolling circles I am advantaged, because my radio has elevator and rudder on the left stick and I must only do an elliptic path. You, instead, must synchronize the left thumb with the right thumb.
"Pizza" (where has he gone?) said:
[color=blue]Not only they are no problem but I think that 3D and mode 1 are better.
What do you think about, 3D experts?
about rolling circles I am advantaged, because my radio has elevator and rudder on the left stick and I must only do an elliptic path. You, instead, must synchronize the left thumb with the right thumb."Pizza" (where has he gone?) said:
[color=red]If you have seen Mr. queki somenzini? spelling fly you will know that 3d and mode 1 are no problem
What do you think about, 3D experts?[color=green]Vittorio from Italy[sm=sunsmiley.gif]a beautiful country.
#204
Italian Flyer,
The debate on which mode is better is a pointless one. Good on you if you feel advantaged with the mode you fly.
Ultimately it comes down to intelligent practice - sorry intelligent play with your model on field.
Cheers!!
Cheers!!
#205
ORIGINAL: edible_engine
G2 int aerodynamicly as acurate as aerofly pro. G2 is a good sim but for true realism its not great[
What is that stuff (Marmite)? It looks good. Is it some kind of marmalade or fudge?
I'm thinking it's some sort of peanut butter or choc spread. Am I right?
Please explain.
#206
answer is simple... if you know how to fly already... use that mode. If you live in Europe, learn mode 1. If you live in United States, learn mode 2. It is much easier to learn from a logistics point of view if you fly the same mode as everyone in your circle of flying friends. I learned mode 1, because my father learned mode 1 in the late 60's. Mode one is an artifact of the old "Toggle Switch" REED sets. There was a directional toggle switch located about where we now have the right stick, This switch worked side ways for left and right. There was also a Up-Down toggle switch about where we now have the left stick for elevator. See how Digital Proportional early systems came from this? I like mode 1 better, I have some reasons why I stick with it, but until recently acquiring a mode 1 radio in the US required a special order. Early 90's that turned around with the programmable radios. Airtronics actually had first "Consumer switchable mode Tx's... of the "BIG" 3 manufacturers that is... I don't know if the multiplex systems had this capability or not... Early simple systems, you just switched the spring and throttle rachet to other side, but if there was mixing, or dual rates, that would often not be useable. Check out the KRAFT and CITIZENSHIP in the picture!!! Oh yeah... I think Curtis Youngblood flies SINGLE STICK!!!!
#207
ORIGINAL: Johnnylightning
Hey Ian, you've changed your Avatar.
Please explain.
Please explain.
#208
Banned
[8D]Hi people
[&o][color=blue]Dear 3D beginners, bad news, no news.
[color=red]Hei, 3D experts, are you sleeping?
[&:]After ROLLING CIRCLES AND EDGE LOOPS, which interesting exercises do you suggest?
I have visited the site [link]http://www.hobby-lobby.com[/link] and seen some 3D ugly videos.
[sm=confused.gif]Where can I find nice 3D videos?
Please, 3D experts, help us poor beginners, don't leave us alone, ah, ah, ah.
Please, Mr. Queque (Which is the right pronunciation?) Somenzini, help us, make us dreaming.
[color=red]Hei, 3D experts, are you sleeping?[&:]After ROLLING CIRCLES AND EDGE LOOPS, which interesting exercises do you suggest?
#209
[/quote]
Marmite, were do i start[:-] Its the most amazing, tastiest thing in the world. Ita a spread, aussies have the same sort of stuff, vegimite, thats wo they call it but this is nicer!
[/quote]
Ian, I've heard of vegimite. It's mentioned in that old song from "Men at Work". It's the only time that I've ever heard it mentioned tho. Wot's funny is that I've heard the same thing that you've described, about either liking it or hating it. How does it compare to the Aussie's vegimite? I mean, in wot way?
Is it really-really sweet? I'm assuming that it's something like condensed milk sorta'? But maybe not so sweet. I'd actually like to try some myself, but I'm afraid that I'll have a hard time finding some here in the States. Gonna' check out the site and see if they'll send me a sample jar.
Have you always eaten the stuff, or is it somtin' you've recently aquired a taste for?
"Yo Adrian", do you eat Vegimite?
[/quote]
#210
Ok , I've been following this thread for a while now...and biting my tongue the entire time.
Italian-flyer, no practice? what do you call your 2 or 3 days a week on G2? Why do you think that for the TOC's in Vegas do they alot space on the salt flats for...PRACTICE!!!
Until two days ago, i have never used a sim...i bought G2 for something to do on rainy days, and while it is fun, nothing beats getting out there and actually flying your plane. I've been flying for six years, and by no means consider myself an expert, but i owe all that i know to practice...all those times i would just "throw" the sticks to the corners to see what happend, and then coordinating that to perform specific maneuvers. And i'm not even going to go into how rude you're being by asking a question and then criticizing the answers like you could have answered them better yourself. My apologies to everyone that may have said the same things earlier in the thread, but thats just my .02...
#211
man i practically grew up on marmite - fray bentos and bovril all more or less the same stuff. never took any practice to get me rolling one sandwich after another - make a marvelous afternoon soup snack - but!!! were i live it's not so kosher so it's a little hard to get - yummy
#213
Banned
[8D]Hi people
[color=red]Dear 3D beginners, good news, very good news.
[color=blue]We are in good hands.
Our 3D experts beguin to answer all the questions, ah, ah, ah.
[sm=thumbup.gif]SECOND STEP: WE MUST DO VERY SLOW ROLLING MARMITE WITH FULL TROTTLE VEGIMITE.
Very well learning 3D crap by crap.
"O sole mio", pizza e spaghetti, Napoli e tarantella, la, la ,la...
Our 3D experts beguin to answer all the questions, ah, ah, ah. [sm=thumbup.gif]SECOND STEP: WE MUST DO VERY SLOW ROLLING MARMITE WITH FULL TROTTLE VEGIMITE.
Very well learning 3D crap by crap."O sole mio", pizza e spaghetti, Napoli e tarantella, la, la ,la...
#214
MMMM, MARMITE! im evendoing a talk on it at school. if you want info, look here! http://www.ilovemarmite.com/marmite/...&document_id=6
Jonny, try find some in specilised supermarkets! good luck! its worth it!
Adrian, its good to see a fellow marmiter on here! i also grew up on it, by the time i was old enough to eat solids i ate marmite! and haven stoped!
ime afraid to say Vittorio that is not a 3D maneuver. i dont know were you got that rubbish from but i can assure you its not true
#215
ORIGINAL: adrian-RCU
Great site Ian!! I can't believe a basic food group has established a following. Of course I had to visit the Marmite hater's site as well.
**Question to you both and any other Marmite consumers. If I try it now, as a young adult, what are the chances that I will actually like it. In other words; does one have to be raised on it in order to acquire its taste? And if I do like it, is there a chance that it will further enhance or sharpen my flying capability (you know, sorta' like Popeye and spinach)? Marmite may simply be the solution to successfull, "practice-free" 3D.
I could see it now, RCU...exclusively sponsered by Marmite!
#216
50/50 chance you'll like it. hoever, eat it as it makes you have super 3D powers!
Ian
PS, bovril is extract of cow
Ian
#217
Banned
[8D]Hi people
[color=red][sm=thumbup.gif]Dear 3D beginners, good news, very good news.
[COLOR=BLUE]I have found it's very amusing to fly helicopters.
I think if we'll be able to fly helicopters, we'll be advantaged in 3D flying, because we'll get a great sensibility in managing the sticks.
I'm using the REAL FLIGHT G2 trainer helicopter.
IT'S VERY MUCH MORE FUNNY TO FLY HELICOPTERS. 3D HELICOPTERS ARE A BLAST and not too difficult to fly. Also for helicopters
the greater difficulty is landing.
Helicopters are very expensive, but with G2 simulator we touch space bar and "voila" a new helicopter.
[sm=thumbup.gif][color=red]Dear 3D beginners, follow me and we'll learn 3D manoeuvers enjoying ourselves with our favourite music.
IT'S VERY MUCH MORE FUNNY TO FLY HELICOPTERS. 3D HELICOPTERS ARE A BLAST and not too difficult to fly. Also for helicopters the greater difficulty is landing.
Helicopters are very expensive, but with G2 simulator we touch space bar and "voila" a new helicopter.[sm=thumbup.gif][color=red]Dear 3D beginners, follow me and we'll learn 3D manoeuvers enjoying ourselves with our favourite music.
#218
3D heli flying is not easy. With the powers of marmite you can fly them tho. Can you do sustained chaos or a death spiral yet?
#219
Just a thought Ian, what would happen if I were to add about 2-3oz of Marmite to my hardrive? Or maybe place just a little dab between the USB and the interface. I'll be experimenting this weekend to see what happens. Will post results.
#220
Banned
[sm=thumbup.gif][color=red]Dear 3D beginners, good news, very good news.
[color=blue]Have you seen?
Quique Somenzini Hits: 453
[color=blue]www.Learning 3D step by step Hits: 4932
I'm more famous than Quique Somenzini, ha, ha, ha.
Thanks to "Marmite". I will add about 2- 3 oz of Marmite to my hardware too.
[color=blue]Have you seen? Quique Somenzini Hits: 453
Thanks to "Marmite". I will add about 2- 3 oz of Marmite to my hardware too.[color=green]Vittorio from Italy[sm=sunsmiley.gif]a beautiful country.
#221
good, hopefully it will make you practise it makes me practise allot. the reason why Quique has less hits is because his thread is been going on for less time. Meby you need marmite to be able to thiink of that.
Ian, from england, were it rains allot[&o]
#222
Banned
[8D]Hi people
[color=blue]I have discovered it's easier to do "The Blender" with large planes than with little ones.
[:@][:@][:@]NO ONE 3D EXPERTS TOLD US THIS SIMPLE THING.
[sm=eek.gif]Oh, oh, oh, are you amazed about my knowledges?
Being well-informed is the first step to learn.
[8D]Go to [link]http://horizon.hobbyshopnow.com/articles/1022.asp[/link] and try to do that manoeuver with REAL FLIGHT G2.
First play a little with a Real Flight G2 3D helicopter.
[color=blue]I have discovered it's easier to do "The Blender" with large planes than with little ones.[:@][:@][:@]NO ONE 3D EXPERTS TOLD US THIS SIMPLE THING.
Being well-informed is the first step to learn.[8D]Go to [link]http://horizon.hobbyshopnow.com/articles/1022.asp[/link] and try to do that manoeuver with REAL FLIGHT G2.
First play a little with a Real Flight G2 3D helicopter.[color=green]Vittorio from Italy[sm=sunsmiley.gif]a beautiful country.
#223
Banned
[8D]Hi people
[color=blue]
I'm almost managing to torque roll Real Flight G2 Cap 232.
[8D]Perhaps the software understans wath to do when a plane hasn't any more wing lift.
[&:]Who knows?
[>:][>:][>:]OUR 3D EXPERTS ARE VERY BUSY TO PRACTICE AND BURNING FUEL AT THE ICE-COLD FIELD.
[>:][>:][>:]Also the simulator forum is silent.
[8D][color=red]Dear 3D beginners, how can we learn complicated 3D manoeuvers without seeing them?
[8D]How can we learn 3D flying only talking about?
[8D]We need to see what we must do.
[:@]I have seen some videos but they are ugly or muddled, a lot of wild crap manoeuvers of whirling planes that don't look like planes but leaves in the storm.
Wild style? [:@]CRAP STYLE.
[sm=idea.gif]I must find an idea. We need to see some animations to understand well what we must do to perform 3D manoeuvers.
[8D]If we talk about only, we will learn nothing.
We can't learn 3D manoeuvers in 3D space without seeing them.
TO SEE IS VERY MUCH MORE IMPORTANT THEN TO TALK. Or better: SEEING and talking together.
[&:]Who knows if anyone can help us poor beginners?
[color=green]Vittorio from Italy[sm=sunsmiley.gif] a beautiful country.
[color=blue]
I'm almost managing to torque roll Real Flight G2 Cap 232.[8D]Perhaps the software understans wath to do when a plane hasn't any more wing lift.
[&:]Who knows?
Wild style? [:@]CRAP STYLE.[sm=idea.gif]I must find an idea. We need to see some animations to understand well what we must do to perform 3D manoeuvers.
#224
[&o]so a marmite pizza was tried with marvelous result better than any simulated 1d pilot that only flies in doors - beggs for biginners help - speaks out loud like that pavarosie singer. reeks of garlic after run - needs our marmite so badly to open his eyes to real 3d - jay for marmite!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
#225
adrian- surly that hand should be pointing the outer way around?
IT-Flyer...............FOR GODS SAKE SHUT UP (sorry if anyone else is offended by that) WE DONT CARE ABOUT YOUR FLYING ON G2! D YOU EVEN OWN A 3D PLANE?
IF YOU THINK THERESE VIDS ARE
CHECK THEESE OUT! THEESE ARNT
http://www.3drc.info/media/deanbrainfreestyle.WMV
http://www.3drc.info/media/brianfuntana.WMV
http://www.3drc.info/media/3dpromo.WMV
http://www.3drc.info/media/nathanhype.WMV
http://www.3drc.info/media/nathan3styla.WMV
http://www.3drc.info/media/nathfuntana.WMV
http://www.3drc.info/media/hypepro.WMV
http://www.3drc.info/media/deanfuntana.WMV
http://www.3drc.info/media/funtfeb04s.wmv
http://www.3drc.info/media/andyflip.wmv
IF YOU THINK THEIR
YOU ARE THICK AND DANGEROUS AND YOU SHOULDENT BE ALLOWED TO OWN A PLANE AS YOU WOULD KILL ANYONE WHO PRACTISES
IAN, THE MAN IN THE LAND OF MARMITE[:@]
IF YOU THINK THEIR
