 Sig Mayhem 3D ARF >
Sig Mayhem 3D ARF
Sig Mayhem 3D ARF
Old 10-12-2005 | 06:43 PM
  #701
Default RE: Sig Mayhem 3D ARF
The only thing worse than a bad pilot, is a bad upholster. Does anyone else agree??
Old 10-13-2005 | 01:59 AM
  #702
sgillmore's Avatar
My Feedback: (50)
ORIGINAL: luftmeister
Thanks Barry,
I did read about that and have been contemplating the move. I believe that I will end up doing so and feel comfortable with the process - especially since the little cable popping issue came up. I may have to re-read the posts, but did you put the servo in forward of the elevator servo or aft? I am guessing fore would be easier with the increased depth, but I am just curious - and did you just use a 4-40 rod for the pushrod? Thanks!
Chris
Barry is right. I have a Magnum 120 4-Stroke mounted to the front of my Mayhem and with the rudder servo in the rear, it balances at 5.5" with the battery under the rear of the canopy with no additional weight. You're going to be very nose heavy with the rudder servo in the stock location. There are pictures of my rudder servo install on the previous page (p27) in this thread. I mounted mine in-line with the elevator servo and right behind it. It's not very thick back there, but a couple small hardwood blocks on the outside give it just enough room. It works great and moves the servo weight way back where it's most effective.
For the pushrod, I used a 4-40 turnbuckle from an electric R/C stadium truck. Works great.
Old 10-13-2005 | 03:38 AM
  #703
My Feedback: (17)
I mounted my rudder servo on the opposite side of the elevator servo and just forward of it. The fuse is just a little thicker there and slightly eaiser to build the mount. I was able to access the newly cut servo hole from through the elevator servo hole to help with the glueing of the plywood for the rudder servo mount.
I used a carbon fiber rod with titanium 2/56 rod ends. Very stiff and light. However, light isn't necessarily better in this case, but it's what I used.
I haven't flown my Mayhem in a while, I think I'll get it out for this weekend. I really enjoy it.
Barry
Old 11-07-2005 | 06:09 PM
  #704
sgillmore's Avatar
My Feedback: (50)
I hope someone is still looking at this thread. I'd like to put carbon fiber landing gear on my Mayhem. Has anyone done this? If so, any recommendations on sources and/or size would be greatly appreciated. Thanks.
Old 11-08-2005 | 12:44 AM
  #705
Just wanted to drop a quick thanks to everyone that kept this thread going. I followed it for a couple weeks from the start and bought my own. Setup as follows: Saito 1.00, Hitec 645 all surfaces, pull-pull rudder, hitec 81 throttle, JR PCM 770 rx, 1700 NiMh under rudder servo, all stock hardware, and some minor surguries for lightening puposes. It wieghs 6.6 LBS dry (yes Im sure its correct) and the CG is at 6 inches. I flew it about 6 times and hated it, but I think my hate was a misunderstanding after reading every post in this thread over the last couple evenings. I've built and flown 4 other models since the Mayhem while it sat in the basement for well over a year ashamed of itself. [&o] Looking back on those first flights I remember the reasons I didn't like it: it was painfully slow, fragile, it floated too much landing, it didn't like wind, the uplines were crooked, and although it could 3d well the standard aerobatics were lacking in accuracy and crispness. Well since then Ive quenched my thirst for speed (predator 500), ruggedness (USL 120 w/ G26 gasser), accuracy (27% H9 Extra), and 3D (EF mini 3d), so I am back thinking about a short field knock around 3D plane (that is bigger than my mini 3d that flies like a foamie on a steriod/methamphetamine cocktail). After reading all of the posts from satisfied Mayhem owners I think I need to give the Mayhem another try. I got it ready today...reprogrammed the radio for spoilers to help the landings, fixed the thrust for uplines, and checked everything over. I really am exited to fly this plane again! That doesn't happen often in this hobby without spending the green! Now that Im am more realistic about how this plane is meant to fly I think I will enjoy it more, and the fact that I've had it so long eliminates the feeling of spending money on it and thus elimates the fear factor so I am going to thash with it! I have to admit it was odd to pull the cowl off of a plane I have owned for a year and a half to discover a perfectly new clean engine.
Old 11-08-2005 | 01:56 PM
  #706
sgillmore, I checked graphteck and they didnt list it, but you might give them a call to see if another model's gear is compatible.
this is the site: http://www.graphtechrc.com/Secure/mall/maingear.asp#h9
Old 12-21-2005 | 07:37 AM
  #707
I just got a Mayhem and was still deciding on the engine choice. With the new Saito 125, does anyone have any thoughts on it vs the YS 110? Fit?
Old 12-21-2005 | 10:48 AM
  #708
Steve's Avatar
My Feedback: (54)
Both motors would be a good choice for this plane. Check weights and use the lighter motor if you want the best performance.
Old 12-21-2005 | 11:00 AM
  #709
ORIGINAL: Steve
Steve, the Saito 125 is rated at 2.2 hp according to their website with a weight of 24.69 oz with muffler or 21.87 engine only. The YS 110 is rated at 2.1 hp from what I read and it is 28.12 oz with the muffler. With the Saito lighter and higher hp for almost the same price, why would I go with the YS 110? The fuel pump? My local hobby shop is not huge on the YS and says parts are hard to come by, but I only have an OS to go by from my own personal experience.
Old 12-24-2005 | 04:41 PM
  #710
im think im going with the ST 90 becyase i dont have enough money for a four stroke or any bigger 2 stroke. im at about 50feet about sea level. thats right, 50. u guys think this will be ok?? prolly gonna put a 13x6 on 'er. cant wait
Old 12-26-2005 | 04:35 AM
  #711
I just got one for Christmas and will be putting a 91 fx in it...should swing a 14X4w or 15x4w no problem. Im right as sea level so I think this will be fine since the plane is so light.
Old 12-27-2005 | 08:19 AM
  #712
Hello Mayhem owners, guess what I found under the tree ? Yessss, a SIG Mayhem ! They just started to sell them here in Germany, and when I ordered the delivery was postponed till just before Christmas.
I read through the whole thread throughout the last weeks and am excited to get the bird built and ready to fly. I'm just breaking in my 13years old YS120SF which was still new in the box. I bought it on a business trip to Shrewsbury/Mass. in those days. We were flying Gremlins at a field called CMRCM.
Maybe I over read it but I'm still looking for the best prop size for this engine, 18x6 or 16x8 or 18x5, 18x4 ? My experience with this engine is very low, just 30 minutes break in. Any hint or link is very appreciated.
MX-Freak
Old 01-13-2006 | 08:25 AM
  #713
Ok, how bad did I screw up?
Just got started on building my mayham. I joined the wing halves together last night on my large table making sure they were lined up correctly (rib to rib) and also making sure they butt up to each other as much as possible. I then let it dry lying flat over night.
This morning I pulled the tape off I used to secure it together and I noticed something wrong. The wing now has approximately 1/8" - 3/16" of anhedral built into it. [:@]
Should I buy a new wing kit or just fly it?
Thanks.
Old 01-13-2006 | 10:21 AM
  #714
Steve's Avatar
My Feedback: (54)
Freak, use a 16 X 8.
Mark, just fly it. I doubt you even notice. It will fly a little better inverted though.
Old 01-17-2006 | 12:58 PM
  #715
Hi Barry
Knew I'd find your here in Mayham country. Plane looks great. Does it fly as good as UCD? Stop and see the guys on UCD thread. Approaching 4000 post. We miss ya!
Doug
Old 01-18-2006 | 11:02 PM
  #716
Hi friends, this my first post but I read the entire forum, I live in Spain and now i am building the Sig´s Mayhem, it looks a nice 3d airplane. Instead of using the decals provided I use a new decoration, but still using the original covering, also I put carbon stringer in the tail. and home made carbon fiber main and tail landing gear.
The options for power is an A.S.P. 108 and the new O.S. 120 AX, soom I will send some photos.
Big Barry is a great defender of this model, and so I want to do with the finish of my airplane somo honors to him.
Old 02-08-2006 | 01:54 PM
  #717
My Feedback: (17)
Just bringing this up for ULPROD to read.
THanks
Barry
Old 02-09-2006 | 07:54 AM
  #718
Barry, got mine done and cg'd at about 5.25". I had to ad .5 oz to the tail since I didn't want to move the battery back yet since I used the stock pull-pull rudder location. 3 flights and boy I love this plane. I am not a 3D pilot yet, but at my stage of the game, I love what this plane can do. The landings are so nice since it slows down so well.''
Just a quick question, does anyone use flaperons to slow it down since it can float?
Old 02-09-2006 | 10:38 AM
  #719
My Feedback: (17)
wxman...
Glad you like the plane. They are pretty cool. I use spoilerons instead of flaperons. Spoilerons make the plane drop in stead of float.
Barry
Old 02-09-2006 | 11:17 AM
  #720
ORIGINAL: Barry Cazier
wxman...
Barry
I have a 6EXAP right now and it only will do flaperons. Kind of stinks, but I have spent too much cash already.
Old 02-09-2006 | 12:45 PM
  #721
My Feedback: (17)
I think the flaperons will make the plane float more. But I land mine all the time without using flaps or spoils. You may want to mechanical add just a bit of spoilerons. Maybe even double check your ailerons. You many have them slightly down already. Just lengthen the pushrod a hair and it will help without hurting anything. If you go to far, add flaps.
Barry
Old 02-09-2006 | 11:37 PM
  #722
I noticed the Mayhem at one of my local LHS's about 3 weeks ago, They had
it discounted as a managers special $149. I have been reading posts about it
over the last few days, alot of great things said about it.
I called my LHS last night to see if they still had it, the fella that I spoke to said
they sold it. Bummer![:@][&o]
I thought about it for a moment, I wondered if the guy really did look for it, or
if he just kind of glanced around and could have missed it.
Well I called back to the store 5 minutes later, I got a different LHS worker this
time, one who's voice I recognized. He told me they still had it! I was at the store
in 10 minutes!
So I am now the proud owner of a very nice looking Mayhem and for a great price!
I am electriifying this one. Purple Hacker power!
Thanks for all the great posts guys!
Regards,
Jesse
Old 02-10-2006 | 11:35 PM
  #723
My Feedback: (22)
Hi guys I saw my first 40 size Mayhem at or Hobby shop and the man that order it was there too pick it up.That was the first I had heard About them releaseing any of the 40 sizes.I will let you'll know how it flys when he gets it together and brings it too the field.
Joe
Old 02-21-2006 | 09:33 PM
  #724
ben beyer's Avatar
My Feedback: (23)
Does the joiner between the two elevator halves seem to be pretty solid or does it flex a lot? I know someone people complain about the wire joiner on planes like the Funtana because it allows the two halves to flex a lot.
Old 02-21-2006 | 10:34 PM
  #725
My Feedback: (17)
As I remember the elevator is one piece. Doesn't have a joiner. You cut the tail apart and there is a pre-drilled hole the the elevator goes through and you glue the part you cut out back in. Pretty slick. And you save the weight and cost of one servo. I use a Hitec HS5645 on the elevator and I haven't had a bit of problems. I really can't tell any difference than say the Funtana, UCD, Showtime, Yak, all of which have two elevator halves. It seems to have just as much athority and I don't notice any deflection.
Barry
