Reload this Page >
BEST 3D PLANE FOR 2004
Old 06-02-2004, 11:43 PM
  #51
sensei
sensei's Avatar
Default RE: BEST 3D PLANE FOR 2004
Mine is outfitted with a DA 150, on KS 1090 tuned pipes and deep drop flex headers all purchased from Dave Johnson. Cut your headers at 12.25 in length measured from the center of your exhaust ports, this will give you good mid range and right at 500 rpm gain on the top end.
Bob
Old 06-03-2004, 12:41 AM
  #52
JohnVH
My Feedback: (38)
JohnVH's Avatar
Cool, thanks for the info Bob... Im still torn between cans and pipes at this point... not sure what to get
Old 06-03-2004, 09:41 AM
  #53
sensei
sensei's Avatar
Hello John
That extra 500 rpm at the top will make a huge difference, particularly on those double up-line snaps, when your flying something at between 42 and 44 lbs. on a warm summer day. If you can get down to San Antonio, I will let you fly mine before you make a decision.
Bob
Old 06-03-2004, 10:00 AM
  #54
JohnVH
My Feedback: (38)
JohnVH's Avatar
Thanks Bob, I appreciate the offer... I wonder how many RPM over the cans though.. Hmmm.
Ive watched your vid a bunch of times now
Old 06-03-2004, 10:39 AM
  #55
sensei
sensei's Avatar
The cans will give you between 150 and 200 rpm gain. Many of the IMAC guys I fly with use cans and pipes and we have done lots of comparisons.
Bob
Old 06-03-2004, 02:18 PM
  #56
TailTwister
The mostest bestest I've got hold of in 2004, so far, is the Extreme Flight Mini 3D. A 25FX and sub micro gear yeilds a 2 pound 4 ounce 3D machine. At 530 squares, people think it's filled with helium it floats so light.
I like my EF Edge 540T, but the Mini is a better 3D machine, IMHO.
In the "I wish I could testify" category would have to be the Chip Hyde Double Vision.
Old 06-11-2004, 09:15 PM
  #57
Kris^
Banned
I'm sorry. . I've looked at all the responses, but they just aren't quite as good as my 28 lbs 40% Composite-ARF Extra 330 powered by a BME110X on canisters. I have yet to see anything out there near it's size (lets say over 100") that can fly as slow, as precisely, as radically, or as crazy, as this plane will. Even those Yaks that everyone raves about can't get near it. I was doing harrier passes the other day, with the spoilerons cranked up at about 20 degrees. . not only did it putt along at 5 mph and 30 degrees nose up, the slots in the ailerons whistled the entire time, and it had zero wing rock and was as steady and controllable as if it was doing 40 mph. The upright slow-spin elevator was the same way, totally locked in.
Then crank in some throttle and do 15' square loops with zero tip dropout, or even 15' tail-chasing loops in place that never lose altitude or become unstable or slow down. Not talking waterfalls here. . real. . flying . . . loops. The plane will do "S" turn climbs and never slow down, just pull, push, pull, push, on up and up and up. Then come down the same way. It happens almost as fast as you can say it.
I'm sorry, you get the weight down that low, it's just unbeatable.
One other mention. .for the 1/4 scale sized planes don't forget the 80" "Frenzy" that debuted at Joe Nall this year. With the BME50 on the nose, I really don't think ANY other 72-90' plane can touch it. Soon to be out in kit and ARF forms in full-fuselage and profile versions.
Old 06-11-2004, 09:37 PM
  #58
Frankenthumb
The best Pure 3D-er that I've personally flown is the EF Edge540T. I've flown some bigger planes that are a blend of the 3D/IMAC disciplines and really like the way the H9 Extra 330 performed.
I guess the question is about a pure 3D plane, and in my book profiles are really hard to beat. Mark me down for the EF Edge.
Old 06-11-2004, 10:29 PM
  #59
YS-I-DO
My Feedback: (-1)
Gotta say it's the 65" OMP Yak 54.
Old 06-11-2004, 11:20 PM
  #60
TailTwister
40% and 28 pounds?
Old 06-12-2004, 04:55 AM
  #61
Kris^
Banned
yes Tailtwister. . 40% Composite-ARF at 28 lbs .. its written right on the side of the plane. . "40%, 28.5 lbs, 110cc's, Nuff said" That includes the IMAC mandated pilot figure and IP.
As you can see from the pics, you can hold it easily with one hand and arm extended.
Last picture is Tony Dupaquier (Ynot on these forums) and the Frenzy at Joe Nall.
ID:	142354   Click image for larger version
ID:	142355   Click image for larger version
ID:	142356   Click image for larger version
Old 06-12-2004, 08:54 AM
  #62
JohnVH
My Feedback: (38)
JohnVH's Avatar
Wasnt there a thread on that thing somewhere around here?? I believe it was some special super lightweight version right?
Old 06-12-2004, 05:42 PM
  #63
Kris^
Banned
yeah Jon. . I asked Andreas to mold me one that was as light as possible, the bare airframe came in about 4 lbs lighter than normal ones do. The BME110 loses another 4 lbs compared to a 150 setup, and I traded the aluminum wing tube for a CF one, and removed some non-critical material.
Funny thing. . while talking with Andreas at Joe Nall last month, he told me that he was basically VERY surprised that the plane was stillin one piece. He figured it would break apart within a month after I got it flying . .I've gone over every inch of the structure, and I really can't any signs of strain or problems. I gues either Andreas is better than he thinks he is, or I got VER lucky with this bird.
If I had it do again, I think I'd try a TBM 42% 260. It's only slightly larger, yet is about the same weight with another 200" of wing area. . 2600" of area and 29 lbs. . .think about it.
Old 06-12-2004, 08:01 PM
  #64
YS-I-DO
My Feedback: (-1)
Or you could do two OMP Yaks. 2400" of area and 15 lbs. . . .think about it.
  #65
YS-I-DO
My Feedback: (-1)
Sorry...had to do it.
Old 06-29-2004, 12:51 PM
  #66
flat spin
i can't speak personally about the giant scale stuff but the generally looks like one of the best flying planes around.
From what i have flown though i have to say Kangke Fun 50.
Old 06-29-2004, 01:06 PM
  #67
TailTwister
Damn that's a light bird.
Old 06-29-2004, 01:12 PM
  #68
Spaceclam
Spaceclam's Avatar
The Extreme flight 68" yak 54 is the best 3D plane for 2004. The Extreme flight 68" yak 54 is the best 3D plane for 2004. The Extreme flight 68" yak 54 is the best 3D plane for 2004. The Extreme flight 68" yak 54 is the best 3D plane for 2004. The Extreme flight 68" yak 54 is the best 3D plane for 2004. The Extreme flight 68" yak 54 is the best 3D plane for 2004. The Extreme flight 68" yak 54 is the best 3D plane for 2004.
Old 06-29-2004, 01:41 PM
  #69
JohnVH
My Feedback: (38)
JohnVH's Avatar
Spaceclam
I Have Issues.
Yep..
How many of these are flying as of now?
Old 06-29-2004, 02:02 PM
  #70
Shortman
My Feedback: (21)
Shortman's Avatar
Quite a few, over 100 to say the least. Knowing that the first shipment was sold out and that had 60 in itself.
The 87" Yak awaits[8D]
Old 06-29-2004, 02:27 PM
  #71
Spaceclam
Spaceclam's Avatar
it was cool for a hwile. i had one of the only 60 in the us for a while
Old 06-29-2004, 05:33 PM
  #72
YS-I-DO
My Feedback: (-1)
Clam, tell us what you really think about the Yak. Why is it that as soon as I get 20 flights on what I consider the best plane ever, a better one comes along? ALWAYS!!!
Old 06-29-2004, 06:04 PM
  #73
Spaceclam
Spaceclam's Avatar
all i can say is i really love it. it flies great, it feels nice and locked in but it is by no means noseheavy. on low rates i can to 15 foot diameter loops. i havent yet gotten a chance to try it on high rates. this thing is a real blast. i have gotten it down to an easy walking speed with no wing rock, almost NO knife edge coupling. it took something like 5% to correct. inverted flight is hands off. this plane is of much better quality than ANYTHING i have seen in the past. even the foam is cut out where it is not necessary. assembly was superb. fits the 110 like a glove. simply surpasses everything else by a long shot. completely airfoiled tailsection, and it came out to a measely 9 lbs!
Old 06-29-2004, 06:08 PM
  #74
YS-I-DO
My Feedback: (-1)
Did you post pictures in the YS Club thread? I'm sitting here building the EF Yak in my head. Did you use the stock exhaust on the 110?
Old 06-29-2004, 06:13 PM
  #75
Spaceclam
Spaceclam's Avatar
no, i did not post pictures but i can post them if you wish. i used a slimline pitts style muffler and man does it sound sweet.
