 Funtana Engine Advice? >
Old 06-03-2004 | 01:46 AM
Spacey's Avatar
Default RE: Funtana Engine Advice?
Interesting Weedfix. I think I might have to make a plan sometime. Maybe with my next order from OMP.
Old 06-03-2004 | 09:55 AM
skysthelimit's Avatar
Where can I get the futana 90 would a 1.08 work with it that is all i have right now. Dang that guy is good thats a futana 40 dang I might have to get one myself.
Old 06-05-2004 | 10:17 PM
I would use the Satio 91 with apc 15 X 4 W
or the YS 63
Old 06-05-2004 | 11:09 PM
DougT's Avatar
Johnnylightning,
DA150!!!
Not quite, but an Echo 21cc trimmer motor! No, Really!!! Has the same AUW as a Saito 100 powered version, doesn't spit goo all over, is easy to fly, fuel is $2.00 a gallon, a 6 oz tank flies for 20+ minutes, etc. I'm still tuning the carb and trying props but it should be a hoot. It flew very well friday.
http://www.rcuniverse.com/forum/Echo...1536012/tm.htm
And everyone on this forum(3D forum) said it was a waste of time.
Doug
Old 06-06-2004 | 12:38 AM
just in case you guys were wondering, the funtana in that Video is set up with the stock hardware. used everything that came with the plane. only reason i have a new scheme is because after flying it for months i decided to check for stresses. i found one minor joint that came lose, but wouldnt have effected anything.
i am running a YS 63 with a Master airscrew 13x6 K-series prop on wildcat YS 20/20 fule.
that funtana is gone now due to a mid air. but i was so impressed with the plane that i had a new one ready to fly the next weekend.
the YS 63 is a good choice if you are at or near sea level. i am about 100 feet above it.
if you are higher than sea level you may want to think about the saito 91. the YS would hover it but you would be about 2 clicks from full throttle.(trust me, i have done this) the saito 91 would be a much better combo at higher altitude. if your altitude is way up in the stratosphere then i would not blame you for going with the saito 100. might need it to grap what limited air there is up there.
PS: the new Saito 82 would be a great choice for sea level. wont know for sure till it is tried though
Old 06-06-2004 | 11:04 AM
  #31
My Feedback: (10)
I use the MVVS 49 with mini Pipe, unlimited vertical. With 12.25x3.75 APC propeller.
