Great planes ultimate 160
#4677
My Feedback: (14)
RE: Great planes ultimate 160
I dug around on Ebay a bit, and found an "Ashtray Helmet" of the proper size for $7.00! After a bit of "customizing", i.e. removing the ashtray from the helmet and making sure that it was epoxied in the right places so it didn't rattle around, I wound up with a seriously good looking pilot! The full face helmet guy looks great! It doesn't weigh much, and it's a lot cheaper than the $40 - $80 'helmet heads' that i've seen on other rc sites.
Here's one...[link=http://cgi.ebay.com/Motorcycle-Bike-Helmet-Ashtray-RED-FLAMED-CHOPPERS_W0QQitemZ320141538986QQihZ011QQcategoryZ5 94QQrdZ1QQssPageNameZWD1VQQcmdZViewItem?_trksid=p1 638.m118]helmet[/link]
#4678
NC
Carbon steel....ha, ha, that's funny! Thanks guys! The Ulti will be for sport flying (no 3d) so a little weight would be okay! It's a great looking bipe, for now I plan to power it in the low end of the engine range, Fuji32b I happen to have an extra one laying around. The truth is "open mouth, insert foot" I told the guys at the field that I thought my little mighty Fuji32b would sport fly the Ulti well, now I have to put my money where my mouth is................My sport flying test will be to fly from one end of the field to the other in a knife edge without losing any altitude, big wide loop from level flight, I know that's asking alot from the little Fuji32b........again, I think it can do it! Of course, all that money in my mouth may have to go towards a DL50
#4680
My Feedback: (32)
ORIGINAL: mcmike
#4681
NC
Y'up, just ordered two helmets also! How tall and wide are they? I'll post the results of the little Fuji 32b good or bad. Thanks!
#4682
My Feedback: (14)
Well, I've got the canopy on mine with my lil' dude inside, so sticking a yardstick up to him isn't possible, but.... in my 'estimation' he's about 4" tall x 5" long x 3 1/2" wide. Looks about perfect for 27 to 30%! I set mine on a 1/2" thick block of balsa so he can see out over the instrument panel. Be sure to epoxy his visor into place, or it'll shake loose (don't ask me how I know....) Not the lightest things in the world, but I'd guess maybe 1/4 to 1/2 oz. but then, i'm not planning on flying at the TOC anytime soon, just having some fun.
#4685
NC
I'm in Jacksonville, NC and it's a bit chilly and cloudy.....but no wind right now! Truck is packed with my airplane and I'm heading for the flying field, life is good
#4686
SC
ORIGINAL: ricomari
#4687
NC
Got two great flights in before the winds picked up and sky turned really ugly........two is way better than none! Looks like my Ultimate is scheduled to arrive tomorrow by UPS, need to clean up the shop and make room to play...I mean... work on it!
#4688
NC
I plan on using my DX7(awesome radio), how are the two wings setup using two channels, two servos per Y harness per wing? Hope that makes sense! I plan to have a servo for the kill switch and dual elevator servos.....that ties up all my channels.
#4689
My Feedback: (180)
ORIGINAL: ricomari
This gives you two outputs per channel. I have the JR 7202 which is almost the same radio as the DX7 programming wise. For the Ailerons, I use the Flapperon function and in combonation with the Power Expander, no "Y"'s are needed. (Ch 2 and 6)
For the dual elevator servos, mix Elv and Aux. (Ch 3 and 7)
Kill switch is on Ch 5 (Gear)
#4691
My Feedback: (180)
ORIGINAL: ricomari
Is that the Power Expander Sport or Plus? Will either work?
I'm running dual 6V 2000 mAh NMh packs. Overkill? Maybe, but I'm also using 8 high torque digital servos.
#4693
NC
Got my Ultimate this afternoon, nice. I have the Cap232 and the Ulimate is just as nice. It did have two minor holes in the left side of the fuse but the location is just right for a Switch or decal, why would they pack the cabanes loose up against the fuse[:@], anyway too nice to get upset about it. Well gotta go read my manual so I can start building tomorrow......................Anybody have any idea as to how big/oz the gas tank is?
#4696
Hey Merry Christmas everybody,
Quick question for you Ultimate gurus. Are you using the Ca hinges that came with this kit? I always like to use Robart hinge points. I usually build from kits, so I can always add more to the trailing edge area to drill for these hinges. You guys that have had one of these stripped down, is there enough meat in the wing trailing edge and aileron leading edge to hold a hinge point? What about the tail feathers? I'm running a DL50 and 5985's.
Tim Hendrix
Tim Hendrix
#4697
FL
I've been using Radio South 1/4 scale Pro Hinges... [link=http://www.radiosouthrc.com/pro-hinge.htm]http://www.radiosouthrc.com/pro-hinge.htm[/link]
for a year and a half and they are still perfect !
I did a different layout to double up at crucial points.
Jim
Jim
#4699
SC
I used the stock GP hinge material. I cut them wider 1"x1" instead of the suggested 3/4"x1". I have not had any problems with them at all. I do keep a close check on them though as I would ANY type hinge.
