 TMPro Extra 260 P 3D/Pattern ARF >
Old 10-14-2006 | 09:06 AM
  #51
My Feedback: (21)
Default RE: TMPro Extra 260 P 3D/Pattern ARF
ORIGINAL: Dewey2
How do i pre order? Do they take the money now or when it ships?
You can pre-order now online, for $10 with CC or PayPal and will lock in your order and price. The website has been adjusted with this information. You will be billed remainder after your plane has been inspected and ready to ship.
You can also fax, email or mail your order from the contact us page using the form.
Old 10-14-2006 | 11:11 AM
  #52
My Feedback: (24)
Awesome just pre-ordered mine.
Old 10-15-2006 | 01:02 AM
  #53
3D Nut's Avatar
Sorry D,
I could not help my self
http://www.flyingthingz.com/videos/T...iew%202006.wmv
Spiro
Old 10-15-2006 | 07:34 AM
  #54
My Feedback: (21)
You sure that last knife edge spin didn't smack down??
Old 10-15-2006 | 09:57 AM
  #55
Chris-_-Memphis's Avatar
wow one link on the whole sit actually shows an airplane[:'(]
Old 10-15-2006 | 10:29 AM
  #56
A_Smith's Avatar
I was there behind the camera. It was very windy. Here is a weather report link for that day..:
http://www.weatherunderground.com/hi...q_statename=NA I'd say the 9 was the steady calm, more gusts, and wind than anything . The wind was in all directions. We fly on a hill too.[X(] Not a good day for video but the plane ( and 3d nut) did well. With the side force generators on the the wing tips, the wing went from steady to rock solid. [X(]
Old 10-15-2006 | 10:53 AM
  #57
My Feedback: (21)
The website is a week old. There are at least 12 more planes and about 25 other products which will be posted in the next couple weeks. Thanks for taking the time to have a look!
You can see a preview of all the planes we will be distributing at [link=http://www.topmodelproduction.com]TMPro's website[/link].
Old 10-15-2006 | 11:17 AM
  #58
3D Nut's Avatar
ORIGINAL: STLPilot
Hey STLpilot,
If I told you that I SMACKED it into the ground, on that knife edge spin on the video. Do I have to buy another one?
A_Smith. that 9 mph steady calm was in the morning, go check out the time that we we're there (2:00PM) and by the way nice camera work.
You could see it in the video on the knife edge how windy it was, and the plane still flew like a champ.
Spiro
ID:	541403   Click image for larger version
Old 10-19-2006 | 01:26 AM
  #59
can't wait till i can get my hands on one of these. it will be my first 3d plane so i'm hoping it won't be too much to handle. it was a decision between this and the Extreme Flight Edge 540T but given that the TMpro is going to be available locally in Australia in a few weeks time (and I didn't get a response from an email I sent to Extreme Flight) i chose to go with the TMPro.
Now for a list of questions that i'm sure you guys could answer for me, me being a 3d n00b and all
I have an OS46AX with standard muffler to go on this, running 10% nitro - will this be a big enough engine for a 4.25lb plane? What sort of vertical performance could I expect with this engine? What would be the best prop to use?
I have JR ES539 standard servos (not metal gear) for it (4.8kg torque) - will they be enough or should i get higher torque MG servos?
Thanks in advance for any replies.
Old 10-19-2006 | 01:38 AM
  #60
the standart 46 is the best choice for such style.
Go with a 11x5.5 or 12x4 , props of any brand...
You'll have much fun
Old 10-19-2006 | 01:42 AM
  #61
Spacey's Avatar
fjaust: That motor, fuel and the servos will be fine for the job. The 539's might even be a little overkill but use them as they'll feel a little better than standard servos on the precision side while flying. Everything you got is great now just make sure you don't put in a brick of a battery (ex. 1800mah nicad) in it just to make sure you keep the weight down and you'll have a great rig.
Old 10-19-2006 | 06:09 PM
  #62
3D Nut's Avatar
ORIGINAL: fjaust
Hello Fjaust,
Good choice to stick with the TMpro planes, at this time I have four of them still in one piece. As far as servos goes you could use your standard servos, the OS46AX is more then enough power, the prop I use on the video was a APC 12.25x3.75 and if you would like to get more power out of the engine just increase your nitro. By the way it lands like a trainer, nice and slow.
Spiro
Old 10-24-2006 | 06:15 AM
  #63
My Feedback: (21)
I'd put something a little stronger then a standard on the elevator on all profiles to reduce the chance of flutter. The Extra also flies a little faster then the Katana V2 due to it's slightly thinner wing which makes it track better to practice pattern and IMAC flying. It's more of a do it all plane then just low and slow 3D like the Katana.
Old 10-25-2006 | 03:36 AM
  #64
Spacey's Avatar
ORIGINAL: STLPilot
Dion's concern should not fall on deaf ears. The 539's are stronger than standard servos though so they'll work well as a nudge up upgrade on the smaller profiles. Heck I even use them on my .60 sized fatty Yak which is a full on Freestyle. Even still with the 539's though you need to ensure that you use proper super horns on the servos and utilize the best mechanical efficiency to reduce chances of flutter. And even then still you need to use proper throttle management as with any 3D model. 539's Aren't famous for slop free operation Their gears have lotsa backlash so make sure you use a proper mechanical setup.
Old 10-28-2006 | 01:42 AM
  #65
More vids avilable yet ??
awesome...
Old 10-28-2006 | 09:27 AM
  #66
3D Nut's Avatar
ORIGINAL: Hobby-Motory
awesome...
Yeah for sure, I'm trying to get them done. I'm just over flooded with work, and trying to catch up.
Spiro
Old 10-29-2006 | 11:37 AM
  #67
3D Nut's Avatar
awesome...
Well it's to windy to go to the flying field, and I was not in the mood to do house work so here you go, but don't forget this in not the main video I had in mind enjoy
[link=http://www.flyingthingz.com/videos/tmprousa.wmv]TeamFlyingThingZ[/link]
if you guys realized in the video, I was flying it fast due to the high gust of wind that day, and it did not fall apart
Spiro
Old 10-29-2006 | 06:59 PM
  #68
My Feedback: (7)
Sweet.So how do I get one?
Old 10-30-2006 | 01:13 PM
  #69
My Feedback: (21)
ORIGINAL: thtoyman
Order online or just call. See link in my sig file. It's $10 to pre-order and to reserve at that price.
Old 11-11-2006 | 05:30 PM
  #70
My Feedback: (24)
When do i pay the rest? Won't be back in town till the end of the week.
Old 11-12-2006 | 07:07 AM
  #71
is there any left from the first shipment ?
Old 11-12-2006 | 07:41 AM
  #72
My Feedback: (21)
Yes, there are some left for first shipment. I'm awaiting the phone call from the port any day now and only have to go pick them up as the port is only 10 miles from our wharehouse.
Old 11-14-2006 | 09:03 PM
  #73
My Feedback: (24)
So it's shipping tomorrow?
Old 11-15-2006 | 05:30 AM
  #74
Dewey2, for being the one who posted the most in this thread,
i think you should be the one to open a formal built thread... :-)))))
once you do get your bird...
Old 11-15-2006 | 03:13 PM
  #75
My Feedback: (21)
Just got a call that the boat is in the port. Only a couple days late, not too bad. Seen worst. I'll keep you updated.
