Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Delta
Old 01-21-2004 | 09:24 AM
My Feedback: (43)
Default Delta
Will a standard symmetrical airfoil work in a tailess delta layout? ie, a NACA 0016?
Old 01-21-2004 | 09:37 AM
pmw
Default RE: Delta
JeffH
Yes a symmetrical airfoil will work well on a tail less delta. I've built and flown several Laser Arrows and the airfoil is symmetrical. They fly rock solid and float like a sail plane during landing. The only problem with any delta is the tendency to tip stall. I put wing fences and tip plates on the Arrow and solved the problem. Good luck
Paul
Old 01-21-2004 | 12:26 PM
Default RE: Delta
pmw - what's a wing fence?
Old 01-21-2004 | 01:13 PM
BMatthews's Avatar
Default RE: Delta
Symetrical is fine but you'll find you have to add a bit of up elevon trim for the reflex you need before your first flight. It won't trim with the elevons right on the center line.
