Comment on tbe FAA NPRM
#51
Operators are not the public. They are participants under the FARs. Your system protects participants during a small fraction of the entire flight, but might well minimize damage to the toy. His method protects the public during the majority of the flight and does not consider preservation of the toy.
Regards,
Astro
#52
Kind of like the free flight contest video that was posted a while back. There should be no individual liablility posed on the participants in that event by the spectators who CHOSE to attend an event where they know there is an increased chance for harm as opposed to, say, staying in bed!
#53
I believe in survival of the fittest (WITHOUT stepping on anyone else's toes, or infringing on their rights). I have my thresholds for what I consider safe, others have theirs. I prefer we not legislate safety, for fear of living a completely vanilla, mundane existance in a world overpopulated with non-thinkers.
Astro
#54
My Feedback: (29)
Sorry guys I'm not buying it. There are too many variables to accurately say which one has the more favorable odds of protecting the general public. That is unless either of you have accurate data. Perhaps this falls under what would be best for the flying site. Since the flying fields that I frequent are well away from the General public, there is virtually no risk to them should a loss of signal happen. The risk is to the participants at the field.
Now that being said, an actual failsafe event is quite rare. Most out of control situations are battery related with linkage failure being a close second. A Brown out is not a failsafe event. Since failsafe was introduced I have only had 1 failsafe event which I had all surfaces to neutral and engine off. The airplane glided into a hillside and was destroyed. However if flying a small model in a residential zone with minimal overflight to reach houses then the " all in " method my be best.
#55
Banned
Simple, just add a return spring on the throttle... FAA expects you to already be taking steps to ensure this does not impose undue risk if something as simple as a battery becomes disconnected. Not only is that a very concerning single point of failure on a large and obviously higher risk toy, to not add redundancy and something as simple as a throttle return spring would seem rather cavalier were I the investigator.
Knee jerk solutions imposed by bureaucrats on the spur of the moment are rarely well thought out.
#56
Banned
this will not be popular for most folk, but it is what i have done since real failsafes came available to us decades ago:
fixed wing: throttle to full idle/kill, all other controls to full positive snap inputsrotorwing: throttle to hold/kill, all others ail and rud to neutral, ele to full back.
this has worked, everytime it has been needed to keep an aircraft from flying away
My fail safe settings for power planes are generally set to the factory default: Hold the last position at signal loss. That gives me the best chance to regain control of the model, in which case I can direct it to a safe area or simply resume flying. I could support a fail safe which would "dump" it after signal loss persisted for an extended time -- say 10 or 15 seconds.
For sailplanes, I set my fail safe to motor off, full crow (flaps down/ailerons up) and full up elevator. This should put the model into a slow speed descent. With neutral spiral stability it will fall off on a wing anyway, no reason to force it. This doubles as a "thermal escape" mode.
#58
Hands up all those who fly IC powered models who think this is reasonable. For my money, putting a spring of any kind in opposition to a servo is generally bad practice. In this specific case, the spring will have to be strong enough to overcome the resistance of the servo with power off in order to close the throttle. No I don't have numbers but those of us who set up our own control systems know that it takes a few ounces to get the servo moving. So the servo will be fighting the spring all through each and every flight, drawing more current, running the battery down faster, and shortening the life of the servo.......
Of course , gas powered models (with a spark ignition VS glow) can easily be equipped with an optical ignition cutoff that will kill the spark instantly should the TX and RX loose radio contact . I know of no such handy system for glow engine powered models , but I'm sure if it's that important some enterprising engineer should be able to come up with something . Perhaps a small "emergency battery" with a servo driver circuit that would electronically close the throttle in the event of radio system failure ?
#59
See ? I DON'T always agree with Franklin, or anyone else out here for that matter .
...... Hell , there are days when I don't even agree with MYSELF !
#60
So add redundant wiring, or batteries, or receivers, or all of them. You decide. And if something happens, you'll get your chance to tell investigators or litigators or a jury that what you decided was more than adequate - that 'accidents happen.'
#61
Banned
I've been asked by the OP to take this out of the EAA vs AMA thread, and since we're talking about failures and incidents, it seems an appropriate place to bring it up:
Not to hand the naysayers more ammunition, but there was a fatal midair collision in Germany in 1997:
https://aviation-safety.net/wikibase/wiki.php?id=58711
A brief summary:
You can read the full report (auf Deutsch!) at this link:
https://www.bfu-web.de/DE/Publikatio...ublicationFile
I applied Google Translate to some of the relevant paragraphs here:
Relevant to our current discussions, I see this case as a good argument in favor of the FRIA concept, and having FRIA locations marked on aeronautical charts. The Grob pilot violated the lower altitude limit of 600 m AGL for cross country flight in the area where the collision occurred. If he had known about an established flying site he might have paid more attention to his altitude - or been careful not to approach it from a direction where he was blinded by the sun.
A brief summary:
(A Grob motorglider) collided in mid-air with a remote controlled aircraft ("Dingo", wing span 2,40 m and a weight of 10 kg) and crashed into a wooded area. Both occupants of the motorglider were killed.
The collision occurred at an altitude between 702 m and 768 m amsl, which corresponds to 219 m and 285m agl.
The Grob should have been at an altitude of at least 600 m agl.
The organizer put up a poster about the friendship flying of the model flying group Schopfheim taking place on 02./03.97 on the door of the canteen of the Hütten gliding area. It could not be determined whether the motor glider pilot took note of this and was thus informed about the special event.
The weather conditions (according to witnesses: wind from 360 ° with 1-2 kt, visibility> 10 km, cloudless) were suitable for carrying out the flight operations. The position of the sun at the time of the accident causes the motor glider driver to be blinded by the sun.
For the model flying site, a permit issued by the competent authority for ascent lay, among other things. the above Aircraft models before. There was no exact flight height limit for models. There were the requirements that flight operations should only take place within a specified flight sector, the airspace should be monitored by the flight manager and that the model aircraft pilot should be warned when man-carrying aircraft fly into the flight sector and instructed to land or evade them.
A drop below the minimum altitude for cross-country flights by the powered glider and leaving the flight sector by the powered aircraft model could not be ruled out. However, even in these cases, a collision could have been avoided with timely detection and evasion.
Conclusions
The accident is due to the fact that the pilot of the powered model noticed the powered glider too late and therefore avoided it too late, and that the powered glider pilot was blinded by the sun, which was already relatively low at that time, and did not notice the powered aircraft model or did not notice it too late and did not avoid it or avoided it too late.
Conclusions
#62
Banned
That has served me well for over 40 years, and I don't propose to change anything until forced to. Experience shows it's entirely sufficient for my fleet and my usage.
#63
...I see this case as a good argument in favor of the FRIA concept, and having FRIA locations marked on aeronautical charts. The Grob pilot violated the lower altitude limit of 600 m AGL for cross country flight in the area where the collision occurred. If he had known about an established flying site he might have paid more attention to his altitude - or been careful not to approach it from a direction where he was blinded by the sun.
§107.37 Operation near aircraft; right-of-way rules.
(a) Each small unmanned aircraft must yield the right of way to all aircraft, airborne vehicles, and launch and reentry vehicles. Yielding the right of way means that the small unmanned aircraft must give way to the aircraft or vehicle and may not pass over, under, or ahead of it unless well clear.
(b) No person may operate a small unmanned aircraft so close to another aircraft as to create a collision hazard.
#64
Or not. I use typical, practical, and prudent steps to reduce my operational risk. Such as making sure my solder joints are good and by battery connectors are snug. Such as making sure the wires aren't kinked. Such as checking my battery voltage before each flight. Such as verifying flight controls are "free and correct" before each takeoff.
#66
Banned
According to his own information, he had only noticed the motor glider a few meters away from his model after he had released the glider model and is said to have attempted an evasive maneuver.
#67
Banned
My point to the AMA is that all it will take is one. One "Fast Freddy" at Mayhem Park that instead of pulling out of his high speed dive loses control and crashes his turbine in the middle of a busy interstate resulting in big pile up with injuries or worse. Or a slight change in circumstances that put the MR in New York through the windscreen of that helo and a resulting crash. All it will take is one. And yet they continue to take a hands off view of safety ... that it's the club's responsibility.
#69
Banned
And what does it have to do with the NPRM?
#70
Examples of irresponsible behavior by AMA members, especially when there's video supporting them, can be powerful influencers that this particular CBO should not be trusted to ensure the operations at FRIAs is as the FAA expects.
#71
Banned
I haven't finished writing up my comments, so I'm thinking about adding a couple of items related to commercial delivery drone safety. I mean, these things are obviously going to be bigger, heavier, and probably faster than typical model airplanes; so their damage potential is greater. In addition, projected numbers are much greater than the number of model airplanes, further increasing the risk. So it's entirely appropriate to recommend risk mitigation, such as:
Requiring all UAS used for commercial delivery purposes to undergo a formal risk analysis, and prohibiting commercial operations unless the manufacturer can show all flight-critical components have a MTBF of not less than 1,000,000 flight hours.
For each flight critical component having an MTBF of 1,000,000 to 1,000,000,000 flight hours, a backup component shall be provided. The system shall auto-detect failures and shall be capable of continued operation with one component failed. For a non-simultaneous second like failures, the system (if fixed wing type) shall be controllable to a safe landing. If rotary wing type it shall immediately enter a vertical descent to impact. (In the flight control business we call this "fail-op/fail-safe")
Furthermore, given the low altitudes at which such systems will operate, they shall at all times be operated such that, considering the current velocity vector, a total loss of control will result in impact no closer than 100' to any person, vehicle, or building, other than the intended points of departure and landing.
Ya wanna fly pizza to my neighbor's house? Fine with me -- just keep the thing 100' away from mine. Houses in the neighborhood not separated by 200'? Too bad. Safety is paramount, ya know.
Now would you like to help me word it more properly?
#72
And all it will take is one...commercial delivery drone that goes stupid and crashes in the middle of a busy interstate resulting in big pile up with injuries or worse. Or one that loses power and crashes through the roof of an occupied house, causing injuries or worse.
( ... deleted for brevity ... )
#73
#74
#75
