Cub
Old 07-14-2011 | 11:14 AM
Guitarman52's Avatar
Default Cub
I purchased a used Hanger 9 cub with a 80"wing off a friend of mine who got frustrated because he couldn't take it off. Everytime he gave it power it would turn violently to the left. I should have known better, because he is an experienced pilot. I am having the same trouble. The motor had left thrust in the engine from the factory, so we put 2 washers under the left side to give it a little right thrust like it should have had to start with and I am still having trouble. Any ideas or techniques from you cub flyers?? I know there is already a few threads about this but I thought maybe someone had come up with the magic solution. I have a friend that had no trouble on the take off twice. I don't have those skills evidently.
Old 07-14-2011 | 11:30 AM
Default RE: Cub
How are you applying power to take-off? The way I would take-off with my Cubs (full-size as well ):
o Full up elevator
o Right rudder
o Apply power slowly until some speed is built
o Slowly let off the up elevator as speed builds
o Keep right rudder as needed for wind and tork (P-Factor)
o Lift her off the ground when the tail is flying and rotation speed is acheived
Hope this helps.
Old 07-14-2011 | 12:31 PM
Default RE: Cub
Thanks Shadow... I'll give it a try.
Old 07-14-2011 | 02:44 PM
Default RE: Cub
i agree with shadow but with out the full up elevator get that tail flying first thing and it will help alot
Old 07-14-2011 | 03:27 PM
Default RE: Cub
Without the downward pressure on the tail with up elevator, the tailwheel will not have enough pressure on it to be effective.
I wanted to put some "teeth" in this by a demo. Notice the elevator in Jim Deitrich's 50% scale Spacewalker while taxiing and when he starts the take-off roll. He holds up elevator while taxiing to keep pressure on the tailwheel. The same applies when he starts his take-off roll.
http://www.youtube.com/watch?v=5ZAXarCvVoE
Beautiful plane too
Old 07-14-2011 | 06:16 PM
tailskid's Avatar
My Feedback: (34)
Default RE: Cub
I've often used the 'blast' method with success.....line it up and give it a quick blast - the tail will come up quickly and then throttle back to 1/4 throttle and continue with a straight take-off.....did that with a full scale also.
Old 07-14-2011 | 06:25 PM
Hill202's Avatar
My Feedback: (24)
Default RE: Cub
ORIGINAL: RCShadow
o Full up elevator
o Right rudder
Hope this helps.
This is the way I do it with my 80" Cub. Its challenging to learn but once you get it, its fun and looks great. I have quite a few planes that I fly but none that I enjoy more than my Cub. Performing touch and goes with a Cub, run it down the runway on its mains, it don't get any better than that!
Old 07-14-2011 | 06:43 PM
Default RE: Cub
Wow Tailskid...wow...I expected more from a once magazine contributor lol. Kidding by the way.
Old 07-14-2011 | 07:00 PM
tailskid's Avatar
My Feedback: (34)
Default RE: Cub
Ha Ha...you have to try it - it works!!!
Old 07-14-2011 | 07:15 PM
Default RE: Cub
ORIGINAL: tailskid
I'll stick to what I was taught...I've seen you fly a tail dragger <grin>. BFG!!!! Jerry, nothing but respect...we have conversed many times on rec.models.rc.air when the newsgroups were around...I miss that [] I know, it still is there, but not nearly as popular as it once was by any means. I miss Red and the others on there. Red b!tching and all lol...remember all the threads on "black wire disease"?
Old 07-14-2011 | 09:58 PM
tailskid's Avatar
My Feedback: (34)
Default RE: Cub
and what about the 'knot' in your antenna wire thread
Old 07-15-2011 | 05:45 AM
MinnFlyer's Avatar
Default RE: Cub
I'm with RCShadow. Full up at all times when taxiing and as you begin the takeoff roll. It also prevents the sudden application of power from causing a nose-over!
Old 07-15-2011 | 07:07 AM
Default RE: Cub
ORIGINAL: tailskid
LOL! I think I remember that one...the memories
ORIGINAL: MinnFlyer
Yep! I think tailskid must've been trained by an Alaskan Bush Pilot with a turbo cub lol.
Old 07-15-2011 | 08:39 AM
My Feedback: (89)
Default RE: Cub
Two Cents from an old Builder/RC Flyer, Bend the Landing gear to have abour 2 degrees "TOE-IN", you know, point the wheels towards the NOSE slightly. This "TOE-IN" will help in ground handling and take-offs.
Than start you Take-Off from the grass.
If you want to make better landings, Line the model up on your shoulder, make your normal approach, as the model gets down to about two (2) feet from the ground, FOCUS your eyes to the MAIN WHEELS, Watch the Main Wheels and feed in elevator for a perfect Landing. Same is true on Tri-Gear, Focus on the Main Wheels. If you just watch the whole airplane, you will hit on the NOSE Gear almost every time.
Happy Take-offs, and Landings.
Ken AMA 1528[/size].
Old 07-15-2011 | 09:07 AM
Default RE: Cub
ORIGINAL: Ken Kehlet
Two Cents from an old Builder/RC Flyer, Bend the Landing gear to have abour 2 degrees ''TOE-IN'', you know, point the wheels towards the NOSE slightly. This ''TOE-IN'' will help in ground handling and take-offs.
All good stuff Ken and I couldn't agree more. Thank you!
Old 07-15-2011 | 10:40 AM
My Feedback: (9)
Default RE: Cub
I suspect that you are punching the throttle to quickly. Ease in to the roll, take your time gaining ground speed, let the tail come up then a little added elevator and you will be flying. You might have to add just a tad of right rudder during the roll out.
Old 07-15-2011 | 10:56 AM
eddieC's Avatar
Default RE: Cub
"The Shadow knows..." RCShadow is right.
I agree it sounds like the throttle is being advanced too quickly. Is it a 4-stroke? Most of mine have a non-linear throttle response, getting 90% throttle before half-stick. May have to change throttle linkage or use expo. That Cub should take off at half-throttle with a good motor.
Old 07-15-2011 | 11:15 AM
Default RE: Cub
I was going to suggest the same thing, wheel alignment is very important (more so) on a taildragger. I had the same type of issues once on a taildragger and adjusted the wheels so they had a little "toe-in" and the plane was a different animal after that. Good Luck and let know how you make out!
FB
Old 07-15-2011 | 03:40 PM
retransit's Avatar
My Feedback: (18)
Default RE: Cub
I have two Cubs, a 1/4 scale Balsa USA and a Goldberg. I agree with the sugestion of toeing in the landing gear as viewed from above. It works, with and without varying throttle control, and I fly off pavement. You can also add a heading hold gyro and switch it off as you leave the ground. My buddy couldn't get his Great Planes Cub to behave, so he added the gyro and it solved the problem. Make sure you are able to control it from your Tx or you will encounter some other problems.
Bob
Old 07-15-2011 | 05:20 PM
My Feedback: (67)
Default RE: Cub
Finally someone who knows about ground handling
Old 07-15-2011 | 05:35 PM
Default RE: Cub
If you want to look like a real pro...put your aileron stick into the prevailing wind (if a cross-wind component exists). Slowly ease off the aileron stick the same as the elevator. What this does in full-scale is, it keeps the wings level as the cross-wind tries to lift the wing on the wind side as airspeed builds thus stopping any ground loop or flip-over. The same applies to RC only to a lesser extent, hence why RC guys don't use it often unless they have a big bird and have learned the hard way [X(]
I know in full-scale, if you do not use this method, the FAA check-ride pilot will fail you immediately and take the controls and scold you AND your instructor for improper procedures.
Old 07-15-2011 | 06:42 PM
cfircav8r's Avatar
Default RE: Cub
This also adds a little adverse yaw in your favor.
Old 07-16-2011 | 09:56 AM
Default RE: Cub
ORIGINAL: cfircav8r
...and will aid someone trying to land in a cross-wind situation. This thread is turning into ground school lol.
Old 07-16-2011 | 01:12 PM
Hill202's Avatar
My Feedback: (24)
Default RE: Cub
I've never been in a full scale cub, thats definitely something to add to my "bucket list".
Old 07-16-2011 | 04:55 PM
Default RE: Cub
Thanks gentlemen, Lots of great ideas to try. I have several planes and I don't have any trouble taking them off. This one is a real bugger. I especially like the toe in idea... gonna definitively do that. I am flying tomorrow. We'll see what happens.
