Reload this Page >
NEW Hanger-9 30cc Beaver
Old 04-22-2014, 10:00 AM
  #101
Planejaw
My Feedback: (53)
Great looking lights!! Trying to find some lights for my Beaver as well.
Old 04-23-2014, 02:34 AM
  #102
Planejaw
My Feedback: (53)
Spinner adapter came and mounted the spinner last night. Also, on the Evo 33, instead of trying to get my index finger in the cowl to activate the choke, added a choke rod that extends through the bottom of the cowl. Mounted the seats last night, so we're getting closer to maiden flight time.
Name:	Beaver 04-23-2014  1.JPG
ID:	1989207   Click image for larger version
Name:	Beaver 04-23-2014  2.JPG
ID:	1989208   Click image for larger version
Name:	Beaver 04-23-2014  3.JPG
Old 04-23-2014, 03:44 AM
  #103
BarracudaHockey
BarracudaHockey's Avatar
Cant wait to see a flight shot with that spinner
Old 04-23-2014, 11:43 AM
  #104
BarracudaHockey
Had a little fun today....
ID:	1989310   Click image for larger version
ID:	1989311   Click image for larger version
ID:	1989312   Click image for larger version
Old 04-23-2014, 12:07 PM
  #105
iflyfloats
iflyfloats's Avatar
nice pictures, but your in the wrong seat !
Old 04-24-2014, 02:39 AM
  #106
Planejaw
My Feedback: (53)
Yes, very neat photos. Big-brother and little brother!!
Until I find a good LED lighting package (any ideas lads?), I used some #00 X 1/2" phillips screws to hold on the landing light covers...makes them easily removeable for installing lights later.
Name:	Beaver 04-24-2014  1.JPG
ID:	1989451   Click image for larger version
Name:	Beaver 04-24-2014  2.JPG
Old 04-24-2014, 04:08 AM
  #107
Reverend
Reverend's Avatar
Planejaw, I would send Ulrich @ unilight.at an email. he has a specific set for the beaver. I used the weaker 4W lights in mine. There is an 8W version for the landing lights that will blow your retina out.
Rev
Old 04-24-2014, 04:19 AM
  #108
Planejaw
My Feedback: (53)
Thanks Rev, I'll give them a try.
Old 04-27-2014, 09:30 AM
  #109
Desertlakesflying
My Feedback: (28)
PM cublover. He found some great lights that are really bright that run off of a 11.1V lipo. I think he got them at Autozone in the accessories section.
Old 05-05-2014, 06:50 AM
  #110
mikmarsh
My Feedback: (31)
What engines are being used ?? Anyone try the DLE 40 twin ?? Will it fit. What about a G-38
Thanks, Mike
Old 05-05-2014, 07:01 AM
  #111
Reverend
Reverend's Avatar
I am running the recommended Evolution 33GX and even hat very rich setting it has absolute ample power to fly the plane with authority. Loops from level flight are not a problem.
The G38 might be too tall. If you dont mind cutting the cowl the NGH GF38 might be a nice 4 Stroke alternative.
https://www.youtube.com/watch?v=U1EoDWfw0ao
Old 05-05-2014, 11:46 AM
  #112
Desertlakesflying
My Feedback: (28)
The VVRC 40cc twin fits inside the cowl.
http://www.valleyviewrc.com/estore/v...-w-1-4x32.html
Old 05-14-2014, 04:48 PM
  #113
Jeepindog
Jeepindog's Avatar
I thought everyone knew about these: http://www.electrodynam.com/store/ED...9-Beaver.shtml I put this in mine and the guys at the field go NUTS every time I fly it.
Old 05-29-2014, 02:28 AM
  #114
Planejaw
My Feedback: (53)
Had my maiden flight last week. Noted that at the recommended CG position, there was quite a bit of "up" elevator trim needed for level flight...even more than would be expected with a full tank of fuel. Has anyone else found the CG to be a little too far forward?
Old 05-29-2014, 02:33 AM
  #115
Lifer
Lifer's Avatar
The up elevator trim may, or may not, have anything to do with the c/g. Did you check the incidence?
Old 05-31-2014, 03:21 PM
  #116
Jeepindog
Jeepindog's Avatar
ID:	2000234   Click image for larger version
ID:	2000235   Click image for larger version
ID:	2000236   Click image for larger version
ID:	2000237   Click image for larger version
Old 09-02-2014, 01:12 PM
  #117
laryboy
Default spinner
tell me about the spinner
Old 10-02-2014, 11:16 AM
  #118
mikmarsh
My Feedback: (31)
Has anyone actually installed the VVRC 40 in one
Old 10-02-2014, 12:14 PM
  #119
Jeepindog
Jeepindog's Avatar
Lots of people have used the VVRC 40cc twin in the Hangar 9 30cc Beaver. I'm one of them. It fits inside the cowl without any trimming needed, except for exhaust stacks. They barely protrude outside the cowl. I'm planning on modifying a set of mufflers two make a 2-into-1 header and have it exit at the scale location. That's a Winter project. Still too much flying to do this Fall! The VVRC 40 is a perfect match for this airframe. Hauls it off the ground quick, makes very scale short-field takeoffs, and sounds great. It's pretty rumbly at mid-range, which gives it a beastly and powerful sound. I run a 19x10 3-blade semi-scale prop on mine, and get about 7000rpm on the ground, and I live and fly at 5,800' MSL. Perfect prop to claw through our less dense air at this altitude, and not too much blade to decrease performance. If I were flying a 3D airplane I would have to use a different prop. For the scale Beaver, though, it is absolutely perfect. See pics 3 posts up.
Old 10-02-2014, 12:21 PM
  #120
laryboy
any opinions on wheel size . pneumatic
Old 10-02-2014, 12:27 PM
  #121
Jeepindog
Jeepindog's Avatar
6" tires, at least, if you're looking for tundra tires. Beavers usually run a 35" tire, and at ~20% scale this one really needs a 7" meat to be correct. I think it will both fly and look ok with a 6 incher, though!
Old 10-02-2014, 04:30 PM
  #122
mikmarsh
My Feedback: (31)
Did you have to modify the firewall so the engine sets back far enough as to not stick out the cowl 2 inches
Old 10-03-2014, 09:58 AM
  #123
Jeepindog
Jeepindog's Avatar
No, I just mounted it as far rearward as it would go, just past flush with the false firewall. I had to grind the edges where there would have been interference with the mufflers, but no major modifications. You will have to remove the sides of the black part of the motorbox shroud that protrudes forward from the firewall to accommodate the cylinder heads.
Old 10-14-2014, 08:53 AM
  #124
flytmates
Can you post some pics of your vvrc engine install?
Old 10-14-2014, 10:51 AM
  #125
Jeff Hendricks
I also would like to see the pics of the Beaver with the VVRC 40 CC Twin.
