question with compatibility
AZ
hey guys
is the avistar select fuse and wings the EXACTLY the same as this ARF :
Hobbico Avistar 40 II MonoKote ARF .40,59"
thanks Felix
thanks Felix
Felix, the Avistar MK II AWARF is the discontinued model. It had plastic add on wing tips on the wing and hor. stab. The Avistar 40 II MonoKote ARF is the current model. The wings are interchangeable. As to weather you can join two halves from different models, I don't think so. Unless I'm mistaken, the older model may have used a metal tube in place of the wooden wing joiner and was held together with screwed on straps (as opposed to glueing together). Like the Superstar wing. Joe
I beleive on the RTF model they still might use the metal tube. And the ARF uses a ply joiner and epoxy instead of the straps. But either wing should fit either version. I was missing parts out of my ARF and when I called to get them to ship me the parts, they needed the model number because they said that some have different parts.
AZ
hey guys
actutall i have a AVISTAR SELECT the RTF version
i crashed it..
now i want to buy the ARF kit..its not really a kit i know but the thing for 99 bucks
i was wondering if i can use my parts like rudder and such..
FElix
i crashed it..
FElix
You could if you needed too. But you would have to reslot and rehinge it all. But all the electronics and the engine would work fine. I picked mine up for 95, but had already bought everything else for another plane. And most of the other hardware would work too.
It just came to me. They interchange them at the factory all the time. I bought the ARF. When I got it, some of the steps were already done. Engine mount, landing gear mount, servo tray were all installed. Also to tube holes and switch were cut out already as well. And these are things that are covered in the steps in the manual. So it just shows that my fuselage was one of the RTF versions. And thing thing I don't like is that the switch hole does not match the switch unit that I use.
