GP Super Stearman
#352
AZ
RE: GP Super Stearman
ffdg,
They should come with a fill connector. It is just a little nipple that you connect to the tires valve. You can blow enough air to fill them. I chose to leave them underinflated. It stops the bounce and even looks scale at the field. I just put the tires on the plane set it on my plane stand, inserted the nipple to fill the tires and instead of putting air in, I mashed the air out. It is real easy to do. Hope this helps.
Stangevil29
Stangevil29
#354
stanevil29,I got a set of the dubro inflat. 4" they look good they are on the stearman now but the engine is not installed yet.Did you have a hard time getting your ailarons throws right?Its killing me worked on it all day and came up with "O".
thanks Fred
thanks Fred
#356
your trying too hard! take it from me. don't worry about it. just pay attention to making sure the horn locations are the same on all ailerons. bottom left same as bottom right. top left same as top right. the connecting rod won't be in perfect parallel with the aft N strut but that is okay. I put double stick tape on the horns (after drilling a few holes) so I wouldn't keep drilling more holes to help with the alignment. worry about the bottom throw if anything and the top will happen. just make sure you don't go over center on the top horn (when it's deflected fully up or down)or you might get a hang up in flight. hope that helps. the plane flies well despite the flaws in the set up instructions.
#357
Guys,
I'm trying to figure out the best position to mount a smoke pump. I was considering mounting at where the weight box is. Also trying to figure out the best position to place a tank for the smoke oil. Any photos or suggestions would be great
thanks.
thanks.
#360
IN
Hi to all I'm thinking about about getting one of these and for all who used a G-26 I was wondering how the vetical was with it.
THanks for the help. Jon
#362
Codimasta Hi, I have read about moving the cortrol horn out from 1 3/8 to 7/8 on the bottom but still I could not get the throws called for.Im going to get some ball links and swivel links and try them.Do you think this will help.
thanks Fred
thanks Fred
#363
I don't think it will help. believe me this has been discussed in detail in here somewhere. I tried most hints and finally decided that I would try it with the throws I got and found the plane to fly like a champ. I get only about 1/2" up and down on the bottom ailerons. of course the uppers will be exponential. you also only have so much threaded rod to work with before the clevis becomes unstable.
#365
in short, the top ailerons will have more travel than the bottom depending on where you place the horns. ideally, like on the ultimates, the connecting rod should be on the trailing edge to get the same throw. but there isn't enough room or threaded rod to do that. so I just made sure the measurements were the same from left to right, put the two servo's on seperate channels so I could adjust the travel on the flaperon mix,and let it go at that.
#367
Stuffer,I got the ailirons to go 7/8 down on the bottom today.I went back from the trialing edge 7/8 not 1 3/8,on the top control horn ,put the bottom ailiron in the bottom hole of the control horn and that did it.The bottom control horn came out to be 1/2 from the trialing edge.
Fred
Fred
#371
My Feedback: (209)
ORIGINAL: Birddog-RCU
Here is a thread that talks to this topic. http://www.rcuniverse.com/forum/m_17...tm.htm#1733757
Ralph Cunningham (RCIGN1) is an expert on Zenoah engines. He converted a G26 to electronic ignition for me and it is the best running engine I have. I think you will find that you are right on the limit of where you should run this engine and that a larger prop is needed to convert those rpm into thrust.
How much did this cost to do if you don't mind me asking.
ham870
#373
hey anybody:
Reguarding MGA's muffler on his FPE. I have one of these engines and would like to know what muffler he is useing on his super stearman. It really cleans up the cowl nicely as opposed to the standard side mounted one. I left a message here asking him to reply, but apparently he is not watching this forum any more.
Anyone know what it is, or who makes a pitts style for the FPE?
Thanks Craig
Thanks Craig
#374
flew my super stearman today for frist time flew great with just a few clicks of ail.trim.have a zenoah g-26 with 18x6 prop.The engine ran great right out of the box.Very stable the crowd love it and so did I.Very happy with this plane.This is my frist gas and large plane,will never go back to 60 size glow.
#375
My Feedback: (13)
TX
ORIGINAL: KCCraig
hey anybody:
Thanks Craig
hey anybody:
Thanks Craig
smoker for next week. Here's some pic's.
Homlite 33 Glow
18x8 Masterscrew Clasic @7400rpm
Pitts (wacker engines)
Futaba PCM
[img][/img]
Jim
