 BME Edge? >
BME Edge?
BME Edge?
Old 09-06-2004 | 02:57 PM
  #276
My Feedback: (25)
Default RE: BME Edge?
The covering is not as good in the hot sun as Monocote, mainly the black. Its not bad though, I would compare it to Ultracote to work with. In fact the colors match Ultracote best. It takes Ironing and heat gun well with out worry of burning. The only thing I did was replace the black on the wing and now all is fine. So far it seem like it will hold up well. I've seen ARF's with covering that is not near this quality.
Old 09-07-2004 | 07:25 AM
  #277
Thanks Ronk1!
jmw
Old 09-07-2004 | 06:25 PM
  #278
Bryant330L's Avatar
My Feedback: (126)
Well, I have it finished. I am not real happy with the balance, but everything else came out nice. The balance is 5 1/2" back from the LE at the fuse. To you guys that are flying this, is that safe? I like a fairly tail heavy plane, but I don't want something that is going to be dangerous. I can replace that stock tail wheel setup, but that is not going to move the cg much. I checked the cg without the tail wheel on there and it only advanced it a little. I don't want to add lead cause it is already 17.2 lbs, but I don't want a terrible handling airplane either. I know some of these manufactures cg are real conservative, and I hope thats the case on this one. Should be able to try it out when the weather clears a little.
ID:	171199   Click image for larger version
Old 09-07-2004 | 09:10 PM
  #279
Hi Bryant your cg at 5 1/2 will be fine. I flew mine at 5 3/4 today and it was good, hover alot better then when i had it at 5 1/4. I see you weight with the Brison is close to mine 17.5lb, maybe i not crazy after all Are you running 2 receiver batterys and what muffler?
Old 09-07-2004 | 09:45 PM
  #280
Slyder's Avatar
Looks great, cant wait to hear what you think of it.
Old 09-07-2004 | 09:53 PM
  #281
coony2787's Avatar
My Feedback: (33)
Looks great Bryant330L. Let us know what you think about it. I'am trying to sell my Double Vision now so i can buy this plane instead!
Chad
Old 09-07-2004 | 10:13 PM
  #282
Bryant330L's Avatar
My Feedback: (126)
I will be sure to give a flight report for you guys. We need more reports on this plane so others can decide for or against it. Thanks for the info Y N C. That eases my mind on the cg issue. Thanks for compliments also. I think this covering scheme is more exciting than the stock one.
Old 09-08-2004 | 05:58 AM
  #283
DENNIS C's Avatar
My Feedback: (99)
ORIGINAL: Bryant330L
I thought these planes were suppose to come in @ 15 lbs..............What happened
Old 09-08-2004 | 12:17 PM
  #284
ptgarcia's Avatar
My Feedback: (36)
ORIGINAL: bodymann
Just like every other light-weight claim made by every other manufacturer out there it is bogus. The larger ARFs always seem to come out around 10% heavier than the high end of the claimed weight range. I just wish these guys would be honest about the weight, its really not a big deal. I'm sure the BME Edge will be an outstanding performer at 17-lbs anyway!
Old 09-08-2004 | 03:39 PM
  #285
Dago Red's Avatar
Just got my Carbonfiber spinner and muffler in today
Old 09-08-2004 | 09:42 PM
  #286
BME claim the plane is no more than 15.5 or 16lbs, but the plane comes out of the box with little hardware that came with it is 10lb 5oz, by the time you add engine , radio equiments, and the rest of the hardwares its going to be 17 +lbs. It's still a great flying plane, just a little dispointed of the weight. Maybe their scale only goes to 15.5lbs.
Old 09-09-2004 | 10:14 AM
  #287
ptgarcia's Avatar
My Feedback: (36)
ORIGINAL: Y N C
That's my point. You know and they know this plane will be fantastic at 17-lbs, so they might as well say its going to be 17-lbs! Truthful information will get me to buy a plane far sooner than a "light weight" claim.
Old 09-09-2004 | 01:27 PM
  #288
aeromax's Avatar
testing
Old 09-09-2004 | 04:12 PM
  #289
coony2787's Avatar
My Feedback: (33)
You all need to remeber that a BME 50cc only wieghts in at 3.0lbs that leaves 2 lbs for the rest of the stuff. I think it can come in at 15.5lbs with the right engine and equipment.
What engine are you guys using that came in at 17lbs ??? And what batteries ??
Chad
Old 09-09-2004 | 04:56 PM
  #290
Bryant330L's Avatar
My Feedback: (126)
I have a Brison 3.2 for power, 1200 NiMH for rx and the same for ign. Motor weight is not really too much of an issue on mine because I am still tail heavy. If my motor was lighter I would still have to add weight. I don't put too much stock in manufacturers weight because they are hardly ever right. There is no way to get this plane anywhere close to the 14lbs that they have listed on the bottom end of their scale. I know mine could be lighter but it would take redoing the plane to get the weight up front.
Old 09-09-2004 | 05:06 PM
  #291
ptgarcia's Avatar
My Feedback: (36)
3-lbs is probably for a bare engine. Its more like 4-lbs ready to fly (pitts muffler, ignition and battery included). I just don't see any coming in under 16-lbs, with something closer to 17-lbs the norm. Again, these planes will be awesome at 17-lbs so its not a big deal. I just take exception to false claims.
Old 09-09-2004 | 06:40 PM
  #292
coony2787's Avatar
My Feedback: (33)
I'am not defending them , i agree that manfactures cannot tell the whole truth!! I just am fixin to order one of these and trying to get all the info i can and the best plane !!!
I was wondering if someone would mind measuring one wing half for me on there BME edge, I need the legnth and the width of the root and the tip. I'am just wanting to know the real wing area of this plane .
One place that i have found is that manafactures cannot tell the truth about wing area!! They usually include the fuse there and some even just add the tail in for good measure. When the only thing that actually flies is the wing itself ..... It is what holds the plane in the air the rest of the plane just controls the wing. Any way if some one would measure that i would appreciate it.
Chad
Old 09-09-2004 | 07:18 PM
  #293
Bryant330L's Avatar
My Feedback: (126)
length of one panel---- 38 1/8" root width 20 1/8" tip width--10"
Old 09-09-2004 | 07:38 PM
  #294
coony2787's Avatar
My Feedback: (33)
Thanks alot Bryant330L.
Chad
Old 09-09-2004 | 09:17 PM
  #295
Hey Ptgarcia don't forget you need a engine mount for the BME. Brison 4.1lb with ignition and muffler.
Old 09-10-2004 | 08:53 AM
  #296
coony2787's Avatar
My Feedback: (33)
Well i figured the wing area for the BME. It has 1148.52 square inches of wing area. That is not too bad. Now that is real wing area no cheating and just the wing.
17lbs , 1148.52 wing area, yikes wing loading kinda high !!!! Has anyone done some high alpha stuff with this plane yet ?
Chad
Old 09-10-2004 | 11:09 PM
  #297
That can't be right. My wm extra 300s and Sig Sukhoi has more wing area than that and it's a small wing.
Old 09-10-2004 | 11:19 PM
  #298
coony2787's Avatar
My Feedback: (33)
I do believe that my math is correct , are you going by what is advertised or did you measure the wing ? I have found that advertised wing area includes the fuse. As we all know the fuse does not fly the wing does! the rest of the plain just holds the wing and controls it. If i'am wrong please correct me !
Chad
Old 09-10-2004 | 11:22 PM
  #299
Bryant330l flew the Edge today with cg at 6inch from leading edge, that's balance at the middle of the wing tube and it still very stable, hover and TR alot better too. The only thing I notice it has little more coupling during knift edge, other than that its the nices plane I had flowen so far.
Old 09-11-2004 | 01:24 AM
  #300
Bryant330L's Avatar
My Feedback: (126)
Well, I got to fly mine today also. My cg is still at 5 1/2 and it is good there. The plane is very stable in a harrier. It is a really nice flyer for a plane this size. It flys a little like my 34% Extra but just not quite as stable in some 3d stuff. Harrier rolls are nice and pretty much everything else it too. My Brison gave it unlimited vertical, but it does not "rocket" out of a hover. My only real concern with this plane is the lack of rudder authority. It didn't seem like it had very much. Maybe I don't have enough servo on it. I am running a Hitec 700 on 6v, which has 161 oz of torque. I would think that would be plenty. For you guys on the fence about buying this one... I give it a thumbs up. Particleman here on rcu flew it for a little while too, maybe he will give his opinion on how it flys.
