 Hinge points in thin wood >
Old 01-02-2005 | 01:46 PM
My Feedback: (24)
Default Hinge points in thin wood
I'm ready to hinge a plane and i always use Robart hinge points in bigger planes but it has a flat plate tail 3/8 inch thick is the hinge points ok or should i use radio south ca hinges i really hate the pinned hinges still haven't got over installing them in another plane a few months ago
Old 01-02-2005 | 11:09 PM
MinnFlyer's Avatar
Default RE: Hinge points in thin wood
What size/type plane is it? As far as I can see, the tail is plenty thick enough to use either type of hinge. Go with whatever you're most comfortable with (Unless it's a really big aerobatic plane, then I'd avoid the CA hinges.)
Old 01-03-2005 | 08:44 AM
My Feedback: (24)
its the hangar 9 25% cap 232 the Chapman scheme what size hinge points should i use
Old 01-03-2005 | 10:13 AM
MinnFlyer's Avatar
3/16
Old 01-03-2005 | 04:11 PM
ptgarcia's Avatar
My Feedback: (36)
I would say the 1/8" hinge point is plenty strong for your CAP, as long as you use enough of them. I rehinged the elevators of my 28% Laser with 1/8" hinge points after I broke a CA hinge. The surfaces are built up with 3/8" stick like your CAP. I installed six 1/8" hinges on each side. There's no way I'll have hinge failure now! If I had to do it again I would probably only use 4 or 5 hinges per side. Good luck!
Old 01-03-2005 | 06:48 PM
I had the same concerns when doing a repair job on my Pitts. Here are some pictures of how mine worked out. I also used extra hinge points to add strength. Holding fine. I used Gorilla Glue as well.
ID:	210210   Click image for larger version
ID:	210211   Click image for larger version
