Super Skybolt ARF
#102
My Feedback: (197)
MN
ORIGINAL: ekir
I have never owned a bipe and I have been in the hobby for over 30 years. I think the time has come for me to make the move. I have an OS 91 4-stroke available that should be a good choice.
For the readers that have had bipe experience, I have a question about field set-up. To assemble the bipe at the flying site, does it take just a few minutes to get the wings assembled and all connects hooked up or is this a 20-30 minute project?
Ed
Ed
#104
OH
am interested in that engine, the 120 as I have one, was hoping to mount it inverted to save cutting up the cowling I'll watch this thread and see. ...builder jim
#108
My Feedback: (25)
PA
ORIGINAL: crash pad
What about using one of the larger 2 strokes in the .75 to .91 range for the super skybolt arf. Also is anyone considering a smoke system?
I would love to put a smoke system in mine but it just seems a little on the small side in the fuselage. The rest of the plane looks great. Just waiting on my OS 91 FS-II. I have the smoke muffler and everything.
#109
IL
I just received a Super Skybolt ARF from Tower. Yep: 7 1/2 pounds supposedly. The color scheme looks good. I plan to power it with a Saito 1.00. I let you know how it comes out if you like.
#110
IL
The Skybolt ARF has a different cabanes and interplanes setup from the kit. Should take only a couple of minutes more than a monoplane to set up.
#113
My Feedback: (10)
VA
Got all the wrinkles out of the covering, man she sure is a beauty. I'm going to go with an OS 91 Surpass ,should haul it around pretty good. I hope she flys as good as she looks.
#116
ORIGINAL: iflywhenican
About 2 more hours of work and she will be ready to maiden. Has anybody flown theirs yet?
Any flight characteristics would be appreciated.
What's your all up weight?
#119
I weighed mine on a bathroom scale and it looks like it is between 7.25 and 7.75 lbs, build went great, however I did crack the firewall and had to add extra support during a hard start due to my electric starter, still have not had it up yet, balance was bang on using a RCV 91-cd , have not added weight for lateral balance but the right wing does want to dip, will post more when I have flown it.
#121
SC
Mine tilted to the right also when doing a lateral balance. Took about a 1/2 oz of weight to correct it. I also added some fiberglass tape to the bottom of the firewall to give added strength.
Maiden report: It's a keeper for sure. Lined her up on the runway, takeoff was straight and true with no rudder input. Had to add about 4 clicks of up elevator though. This baby will KE on low rate. It has a lot of pattern characteristics to it. Very smooth and predictable. Landing was spot on...I just brought the throttle back and let her settle in on the mains...beautiful...no tendancy to drop like a brick either. [sm=thumbup.gif]
Saito 100 14x6 APC prop untill fully broken in then I will change to 14x10
Futaba 9001 servos on 6 volt
#122
IL
I received a Super Skybolt from Tower the end of last week and it's almost completed. I've never been a Great Planes fan, especially ARF's, but they got this one right. At $299 it should be nice quality, and it is. Many innovations, including the way the cabanes are anchored, interplanes "thumbscrews", tailwheel brackets, a large fuel tank, and others. Most important, everything goes together like it should, the fit of parts is exceptional. The covering job is also outstanding, and the color scheme is copied from a full-scale Super Skybolt (white, red, blue, and gold). I haven't weighed the finished product yet because I'm waiting for a couple of items that I've ordered, but I don't think it will be over 8 1/2 lbs. That includes a Saito 1.00 and Slimline Pitts-style muffler. Only negative so far: an aluminum spinner is included, but it's 5/16 O.S. thread, of course. Can't be readily adapted to Saito, so a bit of a waste. I can't wait to put it in the air. I'll give you an update after the maiden flight.
#123
as far as weight, on my bathroom scale it was between 7.25 and 7.75 lbs, will way on a digital scale soon, and post, but under 8lbs your saito should be a nice combo.
#124
SC
I did not use the wood dowels in the cabane struts as called for. I replaced them with 1/8" carbon fiber rods. I also soldered the control rods instead of using the collars.
#125
CA
May I ask the guys with Saito 100s if you needed more weight towards the nose to get your planes to balance out? I'm debating between an OS FS91 and the Saito 100 and would probably just go with the OS if your Saito setups needed an extra few ounces towards the nose for balance.
The Saito 100 looks like a great engine for this plane, but my positive experiences (performance, reliability, etc.) with multiple OS engines is just making me lean towards the FS91.
Thanks in advance!
Thanks in advance!
