Excelleron 90 problem
My Feedback: (7)
I have an Excelleron 90 that has an odd problem. The upper elevator pull-pull cable exits are at different heights. The left side is at 4 5/8" up from the bottom of the fuse as per the manual and the right side is at 3 3/4" from the bottom of the fuse. At 3 3/4", the pull-pull cable would rub against the top of the stab. I have emailed Hobby People but haven't got any response from them. Has anyone else had this problem? It looks like I'll have to open up the side to fix the problem and was wondering if anyone else had to do this and could give me some advice.
Thanks!
Shawn
Thanks!
Shawn
My Feedback: (7)
Ernie,
It actually was pretty easy. I peeled back the gold trim on the bottom and the orange and yellow trim at the top to make my horizontal cuts so I could hide those cuts under the trim colors. I then peeled back the white covering. When I opened up the side, the pull-pull cable tube wasn't really supported by formers so all I had to do was cut a new hole in the fuse side piece where I wanted the cable to exit and gooped the tube in place. Once that dries, I'll ca the balsa back down in place, blend the seam and fill the old hole so no one will ever know I cut it open and reapply the covering I peeled back. Hopefully the vertical cut in the white won't be too noticeable.
Shawn
Shawn
