 Sig Rascal 110 >
Sig Rascal 110
Sig Rascal 110
Old 11-02-2008 | 12:08 PM
  #151
Default RE: Sig Rascal 110
ORIGINAL: Zippi
ORIGINAL: captinjohn
Zippi, Did you ever get the the neat fly-ins they had by Mishawalka right by Cliff Bennets place? It was great! We went every year to the fly-in there. Capt,n
Looks like a lot of nice planes and a lot going on. I don't get to a lot of fly-ins like I use to. I guess I got fat, lazy, and lost the get-up and go I use to have years ago . My mind say yes but my body says no .
The Fly-in in the 2 photos below& above, was at least 20 years ago. You must have been more "zippi" back then!!!! Best Regards Capt,n
ID:	1063982   Click image for larger version
Old 11-02-2008 | 05:58 PM
  #152
Brian,
I know where your flying field is. I may have to sneak down there and fly it while your not looking.
Old 11-02-2008 | 06:17 PM
  #153
Zippi's Avatar
My Feedback: (10)
I got the Rascal out today and it was an interesting day to say the least. The first flight was a no brainer needing only 2 clicks of left Aileron. After a few minutes in the air I thought I would land and just give everything the once over. Good thing I did, the screw in the servo arm on the right Aileron had backed out half way. After using some locktite on the two Aileron servo screws it was off for another flight. After trying some touch and goes I thought I would land and check everything once again. By this time the wind had picked up pretty good so once I landed I clipped the wire fence that lines our runway and broke my nice white 18X6 XOAR prop. I put on an APC 17X6 prop and tweaked the G26 until I was getting around 9400-9600 rpm on top end. At this point I'm having a ball with the Rascal and let two of my flying buddies have their go at the Rascal and they seem to like it pretty well. The rudder sure is very effective in knive edge flight and the landings are very slow and stable. It was to windy to try anything crazy but there's always another day. You gotta love these Rascals .
ID:	1064163   Click image for larger version
ID:	1064164   Click image for larger version
Old 11-02-2008 | 06:21 PM
  #154
My Feedback: (117)
Well bring your AMA card and c'mon down.. . Brian
ORIGINAL: lrglnman
Brian,
Old 11-02-2008 | 06:24 PM
  #155
My Feedback: (117)
Hey. Congrtas on the flights. I hate breaking props, but some days it is part of the game.. Looks great.
I love mine. I just bought a new white XOAR 18x6 at the swap meets Sat. Brian
ORIGINAL: Zippi
Old 11-02-2008 | 06:31 PM
  #156
Zippi's Avatar
My Feedback: (10)
ORIGINAL: Brian Smith
ORIGINAL: Zippi
Brian,
Thanks man. The Rascal is a cool plane. I seem to get better performance out of the APC 17X6 prop. What rpm's are you getting on the 18X6?
Old 11-02-2008 | 06:36 PM
  #157
My Feedback: (117)
I have not had a chance to try it yet. Plus your running a G26 and I am running a G23 on my Rascal. So till I get another G26 in the air I won't know. Brian
ORIGINAL: Zippi
ORIGINAL: Zippi
Brian,
Old 11-02-2008 | 06:43 PM
  #158
Zippi's Avatar
My Feedback: (10)
Brian,
I forgot you were running a G23. I think I may buy a white XOAR 17X6 and 18X6. After the engine is broke in and the rpm's come up the 18X6 may be ok.
Old 11-02-2008 | 07:36 PM
  #159
king_arthur1953's Avatar
I flew mine all afternoon today and had a great day. I spent on whole 30 minute flight tweaking the flap/elevator mix and have it all tweaked in. Now with full flaps and a couple of clicks off idle I can fly down the field slow enough to pick it out of the air. The landings are so alick. With the flaps down I fly in with a few clicks of power on and just before touchdown flare and cut the throttle. My G26 is really starting to break in. I can fell the top end picking up and the idle getting smoother. I weighed mine today and it weighs in at 14lb 6oz. I also closrd off the cockpit and moved the batteries to the rear compartment. I also repositioned the AR7000 reciever. Nor the CG is dead on and leaninf towards tail heavy whih also has afected the quick elevator response and helps he float at slow apeeds. I finished the rienforcement tube for the fuselage wing strut mount and will install it this week. Every time I fly her she gets better and better. I just love the girl. Zippie did the bolts arrive or did you borrow one?
BTW I am only using about 9 ounces of gas in a 30 minute flight of mixed flying say 30% full throttle and the rest below half throttle. How are others doing?
Old 11-02-2008 | 07:46 PM
  #160
Zippi's Avatar
My Feedback: (10)
Ron,
I bought a 5/16" hard bolt and a plastic spinner just so I could fly the Rascal. I still can't use an aluminum spinner because I can't bolt it on. I have not received the bolts yet.
Old 11-02-2008 | 08:16 PM
  #161
If you don't receive them tomorrow let me know and I will make a couple more and send them again.
Old 11-02-2008 | 10:56 PM
  #162
My Feedback: (29)
perfect flying weather, today , here is mine, need to got some upgrades, engine ran great. ready to install cowl and spinner, frank
Old 11-03-2008 | 07:06 AM
  #163
Zippi's Avatar
My Feedback: (10)
Frank,
The Rascal looks good. Glad to hear that you got the engine tweaked out. Can't remember, are you running the G26 also? What tire manufacture are you putting on your wheel pants? Goodyear, Firestone, Michelin, Cooper have already been taken. You gotta add the pin striping as well. It really sets the Rascal off.
Just thought I would mention that I am using the new Airtronics RDS8000 2.4 Ghz system without a glitch at all. I've been running Airtronics since the early 80's and never had an issue. I have also ran JR for a while but prefer Airtronics for it's ease of programming.
Old 11-03-2008 | 08:06 AM
  #164
My Feedback: (29)
i think i will try toyo like on my truck. The engine is first place 1.3. Does bad brad sell the pin stripes too and where can i get the white prop that looks so nice thanks frank
Old 11-03-2008 | 09:09 AM
  #165
My Feedback: (29)
Hard to see but i out lined mine with silver pin striping, think i wil do the pants the same.The 110 looks good with any thing and the way it flys is out of sight thanks frank
ID:	1064558   Click image for larger version
Old 11-03-2008 | 09:15 AM
  #166
Frank where do you fly out of? I am in AR also in Searcy.
Old 11-03-2008 | 10:37 AM
  #167
My Feedback: (29)
king i have saw your posts and have a friend in sercy , i think i saw your field near the napa store???, need to hook up some time, this bunch in sheridan roams around just about every where, we go to farm club
benton pine bluff eldorado conway moticello and we have a real nice field 5 miles south of sheridan come on down, had 33% yak and the 110 up yesterday with perfect weather thanks frank
Old 11-03-2008 | 12:28 PM
  #168
We are located off Benton behind Razorback Concrete. It is a small grass field but we are isolated enough that we don't have to worry about houses or traffic. Here is a link to our club page. http://www.fullers*********.com/SMAFA.htm
Old 11-03-2008 | 12:58 PM
  #169
Zippi's Avatar
My Feedback: (10)
ORIGINAL: frank99
The pin strip I used is automotive 1/4" black pin stripe and you'll use the whole roll as long as you don't use it on the bottom of the wing. The white XOAR prop I got from [link=http://www.chiefaircraft.com/rcmsec/Models/Accessories/Props/XOARProps.html]Cheif Aircraft[/link]
Old 11-03-2008 | 08:42 PM
  #170
Okay guys,
I have been out of the loop for a week or so. Zippi, great job on finishing your Rascal and congrats on the test flights. Looks like i will be flying the first Rascal glider if one of you can provide a tow plane. It seems that my G26 has harked a bearing or something according to the Zenoah guys at Horizon. I had to pull it off and got to send it in to see whats up with my powerplant. The engine kept dying after 2-3 minutes of flying the last time out, thought i could have had some bad gas, but the way my luck runs, there was some play at the end of the crankshaft.
ID:	1064907   Click image for larger version
ID:	1064908   Click image for larger version
ID:	1064909   Click image for larger version
Old 11-03-2008 | 08:45 PM
  #171
any takers on the tow plane..........just let me know??
thanks
Eric
ID:	1064911   Click image for larger version
Old 11-03-2008 | 09:50 PM
  #172
Zippi's Avatar
My Feedback: (10)
Eric,
I hate to hear that a good Zenoah engine has hacked up a bearing. Thanks to king_arthur1953 I now have a prop bolt that is tapped 10-32 so I can use the True-Turn 3 1/2" spinner I just ordered from Tower. I was really amazed at how effective the rudder was for the small size that it is. I'm still kinda undecided on the 18X6 or the 17X6 prop. Once I get some time on the engine and the rpm come up I should be able to get a better feel for what prop is best.
Did you ever call Chad about that Monocoupe?
Old 11-04-2008 | 08:05 AM
  #173
Zippi
I did talk to Chad over the weekend and yes, it is a Kangke Monocoupe.
Eric
Old 11-05-2008 | 05:27 PM
  #174
Zippi's Avatar
My Feedback: (10)
ORIGINAL: pittsman
Zippi
Eric
Thanks for the info Eric. My 3 1/2" True-Turn spinner should be here this week from Tower and I think I'll use the APC 17X6 prop for now. Not to many flying days left for me. Can't stand the cold [sm=thumbs_down.gif]
Old 11-07-2008 | 11:22 PM
  #175
My Feedback: (117)
Our rough field is cracking my Wheel pants. Guess I'll only have them on for Fly-ins. I installed a bigger set of wheels. Are any of you think of a sturdier landing Gear?? Mine tend to spread a little after 5 or so flights, even with greased landings. . Man this thing is fun. Brian
