e th
Old 10-23-2007 | 11:25 PM
fellers's Avatar
Default e th
Please help setting up my panes electronics.
Here is the problem. I get the ailerons working by ail and aux 1 channell. Rudder on rudder channell. Throttle on throttle.
What my problem is that I have 2 servos for my elevator. How can I get it all to work on a jr 7 ch rx and a jr xp6102. Trying to finsih is so i can fly in th e morning.Thanks
Old 10-23-2007 | 11:28 PM
skiman762's Avatar
Default RE: e th
the 6102 can't do duel elevator servos without a reversing y cord ,one with an adjustable center trim is best
http://www3.towerhobbies.com/cgi-bin...4150&search=Go
Old 10-24-2007 | 01:34 AM
fellers's Avatar
Default RE: e th
Well i got it to work by using a simple y harness and switching a servo how 180 deg. Works perefect now. The i adjusted them to the exact same and they are perfect now. As imple turn of the servo horn...
Old 10-24-2007 | 04:00 PM
KWJ48's Avatar
Default RE: e th
You can program the XP 6102 for dual elevators, but you have to Y harness the ailerons. Turn Flaperons off. Then go into the program mode to:
[MX4] > ELE -> FLA
ON OFFSET 0
% % ----- adjust percentages
SW ALWAYS ON
On the reciever I used Elevator plug and AUX1 the reciever is a R790UL
You may not be able to get your elevators to line up exactly on full deflection on a Y harness
That is how I set up my 30% Extra
