Vector Flight Edge 540? >
Old 07-02-2003 | 11:18 PM
  #51
Default Vector Flight Edge 540?
Calflyer, can you give some numbers on reduced rates for the 66" Extra? I only have a single rate 4 channel radio for this plane and don't know what to set the throws at safely. Thanks.
~noah
Old 07-03-2003 | 01:18 AM
  #52
Sydways, for initial flights I would say no more than half inch up and half inch down for the elevator and about 3/4 inch each side for the rudder. The ailerons should be about 1/2 inch also. I am trying to work this from memory as I took the radio out of the 300S for the 540. You can always increase the throws after you get used to the airplane.
