VectorFlight 300s, anygood? >
Old 07-07-2004 | 08:49 PM
  #676
IronCross's Avatar
Default RE: VectorFlight 300s, anygood?
That's what I was hopeing for...
What size props are you using on the .91's ?...
15 percent fuel ?
Roger
Old 07-08-2004 | 03:12 AM
  #677
ORIGINAL: evfast
Has anybody flown the sukhoi yet? Thinking about getting one.
I have the Sukhoi with a Magnum 91 4-stroke in it and the Sukhoi flies great, It's like it's on rails but you need to keep the speed up a little on landings or it will drop a wing. I laterally ballenced it before flying so it's not bad at all but does need to keep the speed up. It's my most flown plane.
IronCross, I started with a 15x4 to get good climb and it worked great as a break to slow it down for landing until I got used to it and now I've been using a 14x6 and still has good vert.
Dauntae
Old 07-08-2004 | 05:27 AM
  #678
evfast's Avatar
My Feedback: (31)
D
I just order one last night, will keep you posted with the build.
thanks for the info
Old 07-10-2004 | 08:10 AM
  #679
IronCross's Avatar
WOW
Doorbell rang and I found this big box on my front step.. My new 66 inch Extra was here.. What a beauty... I have been flying the 58 inch Extra and having a blast with it.. It has become my main plane.. Looks like the 66 inch Extra may replace it though.. Can't get over these great flying planes at these prices.. And fantastic customer service to go with the deal... I don't think CW ever sleeps..
Old 07-17-2004 | 07:56 PM
  #680
is saito 100 enough power for vectorflight 300
Old 07-17-2004 | 08:20 PM
  #681
evfast's Avatar
My Feedback: (31)
I will be putting in a saito 100 on my VF sukhoi, should be plenty of power.
Old 07-30-2004 | 10:20 AM
  #682
This thread is long and sorry if it's already been answered. I have an OS 61 FX and seriously looking to buy the 58". Wondering if I use this engine, will be under powered? If so, does anyone have any recommendations?
Old 08-13-2004 | 09:28 PM
  #683
TOFAST4U2C's Avatar
I love my VF 66" Extra. But anyone find that if they fly to slow the extra tip stalls and wants to nose over??? Slow speed is ok at stright and level but dont use the ailerons. All throws are to instructions.
Old 08-13-2004 | 10:19 PM
  #684
My extra never had a problem with tip stall at any speed, How is yours balanced? Mine flew like a fast trainer.
Miloh.
Old 08-13-2004 | 10:59 PM
  #685
David Cutler's Avatar
If it always tip stalls in the same direction it might be laterally out of balance.
Try checking that.
Good luck!
-David C.
Old 08-15-2004 | 04:13 AM
  #686
My Feedback: (10)
Matt 22,
I have an OS 60 FP on my 58" Extra and it is no way under powered. So your 60 FX should be just fine.
Scott
Old 08-17-2004 | 10:04 AM
  #687
Scott, Thanks for the info. Just received it yesterday and I have say I'm impressed. It's certainly one of the better constructed ARFs I've seen. Instructions are weak....and would be hard for a first/second timer. Looking forward to getting this bird up.
Matt
Old 08-17-2004 | 02:41 PM
  #688
CHassan's Avatar
My Feedback: (13)
ARRRGGGHHHHH where is mine?!!!!!!!!!!!
Old 11-12-2004 | 10:22 AM
  #689
How does the VF 58" Extra 300 perform with the Saito FA 80? Been looking for a long time for an A/C to mount the 80 on. Worried it might be a bit underpowered. I'd appreciate your opinion. Thanks!
Kurt
[email protected]
Old 11-12-2004 | 01:08 PM
  #690
Scar's Avatar
A Magnum .80 hauled mine around just fine. Not underpowered at all. Your Saito probably has as much or more power, but you may need another ounce or two in the nose.
Best wishes,
Dave Olson
ORIGINAL: Jetstud
Kurt
[email protected]
Old 01-31-2005 | 10:18 PM
  #691
Matt 22,
I was looking at the same set up as you. Could you please keep me posted on how it works for you?
Bill
Old 04-15-2005 | 07:07 PM
  #692
ckangaroo70's Avatar
My Feedback: (51)
Im thinking of ordering me the VF Extra here real soon and am just curious if anyone that has had both the 58" version and the 66" version can tell me if they both handle about the same, or does the 66" version handle much better due to its larger size?
Old 04-16-2005 | 07:25 AM
  #693
TOFAST4U2C's Avatar
Bigger is Better......I love flying mine.
Old 04-16-2005 | 09:00 AM
  #694
IronCross's Avatar
I have both of them.. Started with the 58 inch and like it so well I purchased the 66 inch one.. They both fly great.. If I had to pick one to be best it would probably be the 66 inch one... There is something to "bigger flys better".
Old 04-16-2005 | 11:47 AM
  #695
My Feedback: (51)
Thanks for the replies! The 66" it will be then.
Old 04-18-2005 | 03:09 PM
  #696
Hey
How are you guys doing. DIABLOKID. How does your VF 300 fly with the Saito 91. I have a Saito 91 and i was thinking about using it on the 58" version. Also does anyone know if this plane use a pull-pull rudder setup or how is it setup.
Thanks Scott
Old 04-21-2005 | 10:14 PM
  #697
Sturtz's Avatar
My Feedback: (20)
My next plane will be the VF 66 Extra-300. Do you think the OS.91FX will perform well in it ?
Old 04-22-2005 | 06:56 AM
  #698
TOFAST4U2C's Avatar
Kurt
I fly mine with the OS.91FX and it is a real mover. With the changes OS has made to that engine it is very relieable now. The 14x6 APC prop is quiet but I love the sound you get from the Master Airscrew 14x6 and Bisson Pitts muffler. The plane sounds like a 1/4 scale gasser as it flys buy with that combo. Heads turn at the field. Let me know what you think.
Old 07-22-2005 | 08:12 PM
  #699
aerobatixkid's Avatar
Anyone flying this bird (66") with a OS 120 Four banger?
Old 07-22-2005 | 08:19 PM
  #700
I am flying the 66" with an OS 1.20 (pumped engine). Great combination!! lands a bit fast but the plane has plenty of vertical climb(need right rudder in upline) and responds well in manuevers. Had to work on aielerons throws a little to get the rolls axial, but it was worth the effort. It is one of my favorite airplanes now.
