 Quick ? >
Quick ?
Quick ?
Old 08-27-2004 | 10:04 PM
Default Quick ?
I live a good 40 minutes away from a feild in Abilene Tx and i have about 2 acres at my house. I live out in the country bout five miles from an interstate and theres another farm rode by the house....An airforce base is about 15 miles from the house and planes usually fly over not low but there close so what im gettting at is it ok to fly at my house i have r/c cars and drive them out here and seem to have no problems with interferance of any kind. What do any of you think about this....thanks....Steven
Old 08-27-2004 | 10:18 PM
Mr. Canadian's Avatar
Default RE: Quick ?
How high do the planes fly over your house 10000-15000 feet?
Old 08-27-2004 | 11:03 PM
Default RE: Quick ?
from what i've read, i guess you're not supposed to fly above 500 ft if you are in the vicinity of a airport. I might be incorrect in that assumption but I read that on a notice the other day. Anyone else?
Old 08-27-2004 | 11:08 PM
Default RE: Quick ?
I couldnt tell you how high they are.....they are mostly B-1 Bombers and C-130s. The take off south and make a turn 180 degrees to come right over my house most of the time and usually make a turn again 180 degrees to go land at the base....they are usually lowering there gear over my house it that helps....they dont seem to be to high.
Old 08-27-2004 | 11:27 PM
Default RE: Quick ?
WOW! that must be loud neighborhood huh??? hehehe..... if their gear is just coming down around your house they are def. less than 10k ft, i'd say around 5 somewhere, maybe less like 3 ... not sure though, i'm not the foremost expert on military aircraft, but they are cool though!!1 hehehe
Old 08-27-2004 | 11:41 PM
Default RE: Quick ?
sounds like they keep doing touch and go's and that your house is near the end of the run way but u should be able to fly your plane on your field but i warn u i have seen people's planes get screwed up from military planes
Old 08-28-2004 | 12:38 AM
Default RE: Quick ?
Ya the do touch and gos all the time....its not so loud here but in the town of tye which is right at the runway i think it would suck. I had a friend whos house was like half a mile from the runway and the house shooke things were makin all kinds of noises it sounded like something really big blowing up but i dont see me having a problem of hitting them i was just wondering if it would be ok or is there any law or somthing about it.....if i do do this should i have a pretty smooth surface or would a few bumbs be ok....mostly some weed stump things bout 1 inch high?.....thanks steven
Old 08-28-2004 | 01:28 AM
wings's Avatar
Default RE: Quick ?
That was a long sentence man!
I think in the very rare chance there was a collision, your plane would loose.
Old 08-28-2004 | 05:23 AM
LuckyArmpit's Avatar
Default RE: Quick ?
My house is in the final approach area of the local air force reserve base. The air force transports fly directly over my house.
They are less than 1000 feet up. I have flown my sailplanes and other electrics awfully close to them. So far, no one in black suits
have visited me yet. I know they can see the RC planes because they have "wing waggled" back at me.
Dave...
Old 08-28-2004 | 06:35 AM
bingo field's Avatar
Default RE: Quick ?
Heck, I can hardly see my planes at 400'. I would say altitude is not your problem. The stubble is. Get a lawnmower and cut that stuff down so you can taxi on it. I have a 4 ' roller I use behind my rider every time I cut the grass. You are going to need about 200 or more feet long, by 20 - 50 ' wide area to use.
Old 08-28-2004 | 08:18 AM
Default RE: Quick ?
I think you'll be okay. The AMA has things to say about flying within 3 miles of an active airport runway, but you're outside that.
As long as you've flown before you should be fine.
Dennis-
Old 08-28-2004 | 08:40 AM
Default RE: Quick ?
You should be ok. Just don't see how high up you can go.
Make sure you put over size tires on you plane for the rough ground.
Old 08-28-2004 | 10:25 AM
Scar's Avatar
Default RE: Quick ?
I read through the thread and didn't see any mention of neighbors. What's the situation there?
The reason I ask is, 2 acres is nothing, when you're flying anything that might get above 400'. If you're flying parkflyers or Lazy Bees or something light & slow, 2 acres is plenty. If you're flying a ½A glow combat plane, 2 acres with a bunch of overfly would be fine. If you're flying a .40 sport plane, you'd want that 2 acres arranged in a runway, and another 10 acres (give or take, but that seems minimal) for overfly. And if neighbors are close enough to hear that ½A combat plane, you might want to make sure they enjoy the sound.
I hope you get to fly at home, I'd sure like that! I told a guy who was visiting our tent at the local Blue Angels airshow, if he rigged a field at his house, he'd make a lot of friends among us, right away!
Good luck,
Dave Olson
Old 08-28-2004 | 12:30 PM
Default RE: Quick ?
Dave,
I'm assuming he has the 10 acres (or more) from his description. He said he's 5 miles from the interstate and that there's "another farm rode" by his house. Sounds like the boonies to me.
Dennis-
Old 08-28-2004 | 09:53 PM
Default RE: Quick ?
Thanks everyone...i have some neighbors but i dont see them careing to much it was really just a thought right now.....i might try it sometime but i dunno anyways...thanks for the help....steven
