Help! Goop Attack! >
Help! Goop Attack!
Help! Goop Attack!
Old 11-11-2002 | 01:26 PM
Default Help! Goop Attack!
Help guys! I gooped in some lead into a pink foam plane that was finished and covered. It is attacking the foam. I thought it was foam safe as I have read everyplace about gooping in servos. Can I stop it? Will It stop by itself?
I do not want to hack out chuncks of a new plane.
PLease give me good news fast!
Old 11-11-2002 | 01:53 PM
my experience is once it seats up ,it will stop eating the foam.
Old 11-11-2002 | 01:57 PM
Default MAn I hope so.
Any Idea how long that'll take?
Old 11-11-2002 | 02:13 PM
You mean the glue Goop? Almost all glues fully cure in around a few hours. If it ate through the styrofoam, then carve a piece from the same material (there are different types of styrofoam) and then use either tack glue to glue it on or a low temperature hot glue gun (both of these should be available by Woodland Scenics, in the model railroad section of your hobby shop).
Old 11-11-2002 | 02:49 PM
> I have read everyplace about gooping in servos. <
Alas, the hard plastic of a servo case is not the same as foam. Alternative cements include woodworker's glues such as Elmers and Titebond, CyA if labelled as foam safe (not just "odorless"), ProBond, silicone adhesives and epoxy.
Dave Segal
