Programming a Futaba 9C (PCM) for dual elevator servos
I'm new to all this and need some info on programming my elevator, it uses one servo on each side so I assume I have to use two channels but how are they programmed on the 9C.
Help will be greatly appreciated.
My Feedback: (16)
Wa8,
I set up my plane with two elevator servos. You have to set up the Ailevator function and use channels 1 and six (or is it 2 and six) I'll have to check my plane. It is on page 49 of your manual.... if you have it. If not, let me know and I can fax it.
I found this on Futaba's web site....
http://www.futaba-rc.com/faq/faq-9c-q512.html
My Feedback: (16)
GA
The Ailevator function uses channels 2 and 8. If you are using a 7 channel receiver, you need to mix 2 and (5 or 7)
