 Engine break-in question >
Old 03-08-2008 | 06:26 PM
Fly or Die's Avatar
Default Engine break-in question
Hello all,
I will soon be purchasing this engine
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFMD5&P=ML]Engine[/link]
I was just wondering how many tanks of fuel I should run through to break it in so I know how much I need to purchase.
Old 03-08-2008 | 06:44 PM
Default RE: Engine break-in question
Normally ill run 2 tanks on the ground and do the rest of the break in flying it slightly rich
Steven
Old 03-08-2008 | 06:49 PM
ORIGINAL: Fly or Die
Hello all,
Naturally that would depend on tank size which you didn't mention. Seriously, burn 2 tanks on the ground and go fly just slightly richer than normal. 2 more tanks like that and break-in will be complete. It will still take about a full gallon to get to optimum and best idle but you'll get there without further ado.
Old 03-08-2008 | 06:50 PM
I run a tank on the ground to make sure no loose screws or anything come out of the plane and when everythings good I would brake in the engine in the air.
Old 03-08-2008 | 08:06 PM
Missileman's Avatar
2 tanks for me.
Old 03-11-2008 | 07:54 PM
broke_n_bummin's Avatar
RTFM
Old 03-11-2008 | 11:42 PM
YUKONFLYR's Avatar
Run a couple of tanks, check the idle and transition, and then fly it with a light prop for a couple of more tanks rich. You can lean it out a bit each flight, and run increasingly bigger props. Your engine should stay cool during the first few tanks and after 5-6 should be fully broken in.
Each engine is different. The idea is to run it so that it can stay cool, run rich with a reduced load for the first few flights. Your engine will thank you with long life and great performance
Old 03-12-2008 | 02:31 AM
Yeah . I found my max today and ran a tank on the ground. My idle to WOT was smooth so i took her up and had a blast. I let her cool off for 20 minutes. Flew her for another 10. Let her cool off for 30. Flew for another 12. She was beautiful. Starts up with a flip or two now. Don't freak out about new motors. Just run them 6-8 click rich of max lean, and you'll be fine. Just look for a consistent exaugst and you won't burn out your motor.
