 ? about receiver switches >
Old 06-22-2008 | 11:13 AM
Warbird Joe's Avatar
Default ? about receiver switches
will a futaba rx switch work with Spektrum dx7 receivers? This is what i have as a spare >>> http://cgi.ebay.com/FUTABA-Receiver-...QQcmdZViewItem and am hoping it does.
thanks
Joe
Old 06-22-2008 | 11:24 AM
BadSplice's Avatar
Default RE: ? about receiver switches
It should work just fine, the only issue being that there might be a tab on the side of the plug that goes into the reciever. If the plug wont go in because of the tab, you can just trim it off with an exacto knife or sandpaper.
snacker's Avatar
I could be wrong but I think you need the three wire switch. I have all JR or Spektrum switches in my planes with three wires.
Isn't the third wire used for binding?
Old 06-22-2008 | 11:31 AM
JohnBuckner's Avatar
The third wire and plug is for charging without unplugging the battery and the link he posted is a three wire switch harness with a charge plug.
Old 06-22-2008 | 11:36 AM
snacker's Avatar
I'm talking about three wires per connection not three different leads. It looks like two wires per lead to me.
Old 06-22-2008 | 11:47 AM
Missileman's Avatar
You only have to bind once unless something radical happens and you can do that directly on the receiver.
Old 06-22-2008 | 12:14 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
<<Edited>>
I've edited this and removed my comments as I realized that I was thinking of a different receiver when I made these comments, and they don't apply here. Sorry.
Ken
Old 06-22-2008 | 12:28 PM
snacker's Avatar
ORIGINAL: RCKen
Missleman is correct, the only reason a 3-wire switch is needed is for binding the receiver.
I thought that was what I said.
I must bind to much then. Any time I change the settings in the DX-7 for a particular plane I re-bind the reciever in the plane. For instance if I reverse a servo on a channel or change the expo I re-bind the reciever.
Thanks.
Old 06-23-2008 | 09:22 AM
MinnFlyer's Avatar
3 wires are not needed on a switch harness. All the switch harness does is send the battery current to the Rx with a switch between them (And supplies a charging receptacle).
If you plug a battery directly into a receiver, it will work - even though the battery only has two leads.
Same thing with the Switch Harness. I use Futaba Switches with JR all the time. You just have to shave the tab off the plug so it will fit in the JR receiver.
Old 06-23-2008 | 11:24 AM
ORIGINAL: MinnFlyer
OK thanks soooo much. I tried half heartedly to get the batter charger to hookup into the charger slot and it would go. I am sure I was doing it wrong. I will try again today and see what I can do because I don't want to take out that switch harness because it will leave a big hole in the side of the plane compared to the JR switch. Well off to see what happens.
