 Servo size >
Servo size
Servo size
Old 02-16-2009 | 03:53 PM
flystright's Avatar
My Feedback: (13)
Default RE: Servo size
Thanks, Question If I use Spekrum dig servo and program one in reverse mode with a programmer can I use a plan Y harness on Ailerons
Old 02-16-2009 | 04:04 PM
w8ye's Avatar
My Feedback: (16)
But you can use most of the name brand servos with the Spektrum receiver
Old 02-16-2009 | 04:14 PM
flysright,
Go with the Magnum XL 91 RFS engine and the Airtronics 94102z standard servos in your plane. The deals at Hobby People is very nice right now and you should be well please with those components in your 60 size model.
JR is the brand that has different polarity (in the transmitter) but it should be a non-issue. The new Z-connector servos work with any receiver that will accept servos with z-connectors. (I have Hitec, Airtronics, and Futaba servos all plugged into my Airtronics receiver in one of my planes.)
I bought 4 of those metal gear servos for future use but they are larger and heavier than what I'd want in a 60 size model.
Regards,
Clay
Old 02-16-2009 | 04:40 PM
hogflyer's Avatar
ORIGINAL: flystright
Why use a "Y" harness? Your radio is capable of supporting dual aileron servos, so just make use of its capabilities. You should be able to program in aileron differential while your at it.
Hogflyer
Old 02-16-2009 | 05:57 PM
flystright's Avatar
My Feedback: (13)
Hi thanks. Have not began to learn my Radio yet. Just learning how to build a good plane. I belive is is a good foundation to have under your belt.
Old 02-16-2009 | 06:12 PM
  #31
jib
ORIGINAL: RCKen
This is only on older Airtronics servos. Everything that has been sold by Airtronics in the 5-6 years has had "Z" connectors on them which will allow them to connect to every other major brand. The easy way to tell is if the connector is black it's older Airtronics, and if it's a blue connector it's a "Z" connector that will connect right up.
Ken
Thanks for updating me Ken!!!
Jack
Old 02-16-2009 | 07:35 PM
  #32
What are you using as a trainer?
Old 02-16-2009 | 07:51 PM
  #33
flystright's Avatar
My Feedback: (13)
Hi I will be using the Hobbico NexSTAR Select - 46 for starters.
Old 02-17-2009 | 01:02 AM
  #34
Sandmann_AU's Avatar
It's probably easier to take hogflyer's suggestion than it is to reprogram your servo, and cheaper than buying a Y harness and servo programmer. Simply plug your left aileron servo into the AIL connector on your receiver, plug your right aileron servo into the FLAP or AUX1 (whichever you have) connector, and change your model's wing type to "flaperon". That setting automatically changes your flap connector to an opposite aileron connector, and will also give you flaperon ability on your flaps switch but you don't need to (and probably don't want to) use that. You could also leave your wing type alone, and program a mix from the AIL to FLAP that reverses the inputs, and disables the flaps switch.
If you really don't want to do it that way, just buy yourself a "servo reversing Y adapter" which looks like a normal Y adapter which a bit of circuitry in the middle that reverses one of the servos. Still cheaper than a servo programmer.
Old 02-17-2009 | 09:43 PM
  #35
flystright's Avatar
My Feedback: (13)
Hi will the Hitec HS-311 BE OK will be using 6v instead of 4.8. The futaba 3003 servo specifications are 44.3 oz/in @ 4.8V and the Hitec is 51 oz/in if I use 6v and 42 oz/in @ 4.8
Old 02-17-2009 | 10:06 PM
  #36
w8ye's Avatar
My Feedback: (16)
It's a standard servo - should be OK
http://www3.towerhobbies.com/cgi-bin...&I=LXDEL5&P=ML
Old 02-18-2009 | 03:53 AM
  #37
flystright's Avatar
My Feedback: (13)
Thanks w8ye I already have some of these servo at home, Would talk more but in process of returning home from NJ.
Thanks again
Old 02-18-2009 | 04:04 AM
  #38
w8ye's Avatar
My Feedback: (16)
Have a good safe trip
Old 02-18-2009 | 08:14 AM
  #39
Yep they'll be fine. I'm using HS311's for the flaps on my harmon rocket. They're not going to be quite as speedy or precise as the spektrum DS821's I use for the rest of the flight surfaces, but the 821's are overkill - I just happened to have them so I used them. And at AU$60 for the DS821's and AU$15 for the HS311's the Hitec's are much better value for basic use.
Old 02-18-2009 | 08:30 AM
  #40
flystright's Avatar
My Feedback: (13)
Thanks. I found the 821 at Hobby Hanger LHS just outside of WDC where I just finished a job, it is a very nice hobby shop. Thay also have many RTF airplanes with the price range from 7000.00 to 100.00. The fellow that ownes the hobby shop has been flying planes for more then 30yrs. He builds all the RTF his self for resale, it would be very nice to have one of these hobby shops close to the house. Well back on the Road.
Thanks to all for all the Help.
Old 02-18-2009 | 09:57 AM
  #41
821s have become my favorite servos. Great performance, and available for ~$20 each.
Old 02-18-2009 | 05:01 PM
  #42
flystright's Avatar
My Feedback: (13)
Hi, Did you buy your 821's on line? I found mine out of town working for 20.00 at a Hobby Hanger. Would like to find a store on line that offers this price. Thanks for sharing the nice coments about the Spektrum servo. I hope they work well for me to.
Old 02-18-2009 | 05:28 PM
  #43
I buy most of mine at RCG. Lately I've been buying a lot of things in the forums there. It's how RCU's swapshop used to be.
Old 02-18-2009 | 05:56 PM
  #44
flystright's Avatar
My Feedback: (13)
Thanks Will give a look. Right now just started the wings on my Bridi Stick 90. I started a thread awile back asking question about a Super Tiger S3000 I have. w8ye turned me on to this plane (boy it's big). He has been alot of help to me and so have alot of others. I have alot of questions to ask about this plane. Just started a thread in kit building, Please take a look if interested.
Old 02-23-2009 | 10:27 AM
  #45
flystright's Avatar
My Feedback: (13)
Hi, Just recived my Martin AM-1 Mauler airplane in mail from FlyBoy Models, they have very good service, Thanks. Can't wait to start working on this plane. Still waiting on Parts form Hobby People, they should be in in a few days I hope. Ordered plane same day. This company seems to be very busy or under staffed don't know witch, Ordered parts by phone took 2hrs to talk to them, other then that they had good service. Can't wait to start.
Old 02-23-2009 | 07:59 PM
  #46
flystright's Avatar
My Feedback: (13)
Hi. Here are some photos of the Martin AM-1 Mauler airplane FlyBoy Models recived today.
ID:	1143339   Click image for larger version
ID:	1143340   Click image for larger version
ID:	1143341   Click image for larger version
ID:	1143342   Click image for larger version
ID:	1143343   Click image for larger version
