KAOS AND RELATED PLANES AND INFO
Old 01-09-2018, 06:03 AM
  #1051
Skyhawk940
Already have a build thread open https://www.rcgroups.com/forums/show...0-Bronco-build If you want to take a look. I also started a Bronco years ago with an 80 inch WS, but never finished.
Skyhawk
Old 01-11-2018, 11:13 AM
  #1052
ETpilot
ETpilot's Avatar
Haven't done much on this build. I've installed ribs in the jig and sanded the top to shape. It didn't take too long. Just have to be careful. I'll flip the ribs over and sand the bottom. After sanding I'll match these ribs to the ribs for the other wing and sand those down. Ribs then go back in the jig and wing build starts. I made this jig as a 2 part system. One is the table and support blocks. The second is the jig itself. I can flip the jig top to bottom or left to right or just remove it from the table. It has 2 positions for 34” and 46” wing builds.
Old 01-11-2018, 11:17 AM
  #1053
ETpilot
ETpilot's Avatar
Here is another wing build with the jig off the table. The table comes in handy for building smaller parts like rudder, stabilizer, elevator, etc.
Old 01-11-2018, 01:41 PM
  #1054
do335a
ETpilot, what are you using for the rib support rods in your jig - especially for the 46" half span wings?
Old 01-11-2018, 01:48 PM
  #1055
Skyhawk940
Interesting way to do your ribs. Live and learn. Are you using two or three wheels?
Skyhawk
Old 01-11-2018, 04:56 PM
  #1056
ETpilot
ETpilot's Avatar
do335a, for the short span I use 5/16" steel rods 36" long. For the long span 1/4" steel rods 48" long. On the long span I use a support block to support the middle. You can just make out the support block in the picture after the 5th rib. I sand the rods clean then light coat with primer. I waxed the rods so ribs slide on easy. I use PAM cooking oil in the workshop. Good for lots of things. I'm going to try it on the rods. I forgot about PAM and used wax this time.
Skyhawk, two wheels; tail dragger. That is all I have been building.
Old 01-11-2018, 06:55 PM
  #1057
do335a
Thanks for that info, ETpilot.
I used that sort of jig years ago, with 1/4 diameter music wire rods and found that sagging even at the 36" length was an issue due to the weight of the rods. Several supports in between the ends were necessary.
Your rods and jig seem to work out quite well.
Old 01-12-2018, 11:27 AM
  #1058
RC_Fanatic
I have to wonder if steel tubing would work better. The stiffness goes as the cube of the radius so the material in the middle mostly adds weight and contributes to the flex.
Old 01-12-2018, 12:07 PM
  #1059
Skyhawk940
What about like 1/2 inch copper water pipe? Don't weight much and is very stiff.
Skyhawk
Old 01-12-2018, 01:34 PM
  #1060
do335a
The big issue is exactly as you guys describe - stiffness vs. weight. If not stiff and light weight, you get a lot of flex.
The stiff copper tubing is also an interesting idea. However, the 1/2" diameter could be too large for tip ribs, as it would be for my next project.
Old 01-12-2018, 03:26 PM
  #1061
vasek
vasek's Avatar
what about cf rods ?
Old 01-12-2018, 03:55 PM
  #1062
RC_Fanatic
Good point, if you can get them long enough. Years ago I used fiberglass arrow shafts that were 48" long. Forgot about that. Been away from building for too long.
Old 01-12-2018, 04:03 PM
  #1063
ETpilot
ETpilot's Avatar
I don't have a problem with the flexing. I just use a support block for the fix. Since this is a tapered wing I wanted the rods as wide spaced as possible so ¼” rods worked best. For a straight wing you can get by with thicker rods. I did see, at Walmart, some 5/16” x 48” Fiberglass rods. Thought about it but passed for the 1/4" steel rod. Flexing for me is not a big issue. You can use one or two support blocks and problem gone. Take a few measurements to check for straight. Once you start sheeting, flexing will no longer be a problem. .
Today I flipped the ribs over and sanded the bottom side. This side went a lot faster than the top. You just develop a technique for the How-To. I'll match these ribs to the other side then get ready to build the wing.
Old 01-13-2018, 04:43 PM
  #1064
ETpilot
ETpilot's Avatar
Well the worst of the wing build is over. Time to cut spars and see how this goes together.
Old 01-14-2018, 04:15 PM
  #1065
ETpilot
ETpilot's Avatar
The first half wing started. Cut the spars and reassembled ribs on jig. Lots of weight holding spar in the ribs. With the center support block, there was only 2mm deflection on either side. I cut and added 2 blocks to bring the rod to straight. Two mm is not that much deflection.
Old 01-16-2018, 03:28 PM
  #1066
ETpilot
ETpilot's Avatar
Since flipping the wing over is a simple process with my jig, I'm working a little different with this wing. I started with the top spar. Then flipped it and did the bottom spar followed by the leading edge. Here I am having the top sheeting adjust to follow the curve of the ribs. I have trailing edge pieces cut and ready to be glued. Working like this i really have to think things out. Don't want to box me in and then regret it.
Old 01-17-2018, 05:13 AM
  #1067
Skyhawk940
I can tell, you've built a few planes from scratch. Teach the younger generation or this skill will die.
Old 01-17-2018, 06:03 PM
  #1068
ETpilot
ETpilot's Avatar
Building RC airplanes and building and fixing things in general is just slowly dying. When I got back into the hobby I could not find any kits locally. I also found out how the hobby had changed. In the past, you had to build to fly. So I just started scratch building.
A few weeks ago I was going to the Post Office and saw a baby stroller off the side of the road, country road. Figured I'd check it out on way back if it was still there. It was there turned out to be an expensive stroller. It had a bent axle and rubber tire had come off the plastic rim and rim was bent. Other than that it was in good shape but a bit dirty. May have been there a while. I took it home and had it fixed in 30 minutes. Someone may have abandoned it cause it was damaged. Probably fell off a vehicle.
Old 01-17-2018, 06:09 PM
  #1069
ETpilot
ETpilot's Avatar
When you kit build or scratch build you sometimes have to fix problems. When I drew my wing plan I thought 72” wing would work good with my 36” balsa stock. Perfect!!
WRONG. What I failed to take notice of is that the wing has a LE and TE sweep. My 36” stock was a bit short. Never tried it before but I tested an end to end balsa joint. CA, Titebond and Epoxy. Epoxy won. I scraped the bottom of the epoxy bottles for this fix.
The joint turned out very strong. It's placement will be at the center of the wing and will be covered by fiberglass. Should work good.
Old 01-17-2018, 06:31 PM
  #1070
ETpilot
ETpilot's Avatar
This morning was super cold for this area. Maybe close to record temperature, not sure. Yesterday it snowed, a rare event. So I decided to move the wing jig into the house and work there. I got the TE pieces installed. Just one more thing to do, then sheet top and bottom and wing will be ready to come off the jig. The aileron servo I'll do later. Wing is looking good.
Old 01-21-2018, 12:45 PM
  #1071
ETpilot
ETpilot's Avatar
The top and bottom sheeting glued on and drying. I should be able to remove wing from jig as the next step. Aileron and servo location will come later. I finally was able to get some epoxy glue. It sure did take a while to get that glue. I did a little work on fuselage. I'll join the sides soon. AND I got that balsa storage rack out of my way. Now I need to install it in my garage.
Old 01-23-2018, 08:41 AM
  #1072
ETpilot
ETpilot's Avatar
While the wing was in the jig I went ahead and glued in some cap strips and also also made some cuts to the aileron. Two more cuts and the aileron will be off the wing. The left wing is now off the jig but still more work to be done. Now I get to do it all again for the right wing. Only difference on the right wing is I will cant the root rib to set the dihedral. Hope it builds fast.
Old 01-24-2018, 04:40 PM
  #1073
Skyhawk940
Remember, one left and one right!
Old 01-24-2018, 07:50 PM
  #1074
ETpilot
ETpilot's Avatar
Yes, I double and triple checked that. I've read where mistakes have been made. Ha Ha.
Well, the sad news is I have to put this build on super slow. The last 1 ½ to 2 years I have been plagued by wild hogs. It is a big Texas problem. I've been hit the last 3 days. Yesterday I trapped one. My neighbor's came over at night and got another. They have done extensive pasture damage that I need to restore. The really bad news is they hit my grass runway again. I'm going to weld a drag to help restore the pastures. I have a design in my head. Need to put it together. This will be time consuming.
Hope to devote some time to the build but it may be slow. Here is a picture of the hog I trapped.
Old 01-24-2018, 08:00 PM
  #1075
ETpilot
ETpilot's Avatar
This is the damage along the edge of the runway. This is the type of damage that they do. This is a small area of damage. They have done more extensive damage in other areas.
