Getting into covering now. Really excited about maiden flight, probably late April or early May.
https://cimg2.ibsrv.net/gimg/www.rcu...7b6dcd051e.jpg |
Because there will be 2 connections from the wing to the receiver, I color-coded one of them.
https://cimg1.ibsrv.net/gimg/www.rcu...1254da4692.jpg |
Finally, over the weekend, I finished painting the engine cowling.
https://cimg5.ibsrv.net/gimg/www.rcu...2104d34de5.jpg |
So now all the blue color and the black trim have been applied - time to start with the red stripes. Right now, the completed bare frame weighs in at 2 3/4 pounds.
https://cimg8.ibsrv.net/gimg/www.rcu...94d3423935.jpg |
The stripes and spaces are 3", so to keep them consistant, I made a template at 2 7/8", then use 1/8" striping tape to make the edge for the next stripe.
https://cimg9.ibsrv.net/gimg/www.rcu...02789b3704.jpg |
Rather than keep measuring 3" on the monokote, I made another template. I tape the monokote, then tape the template. Next I put a steel ruler at the edge of the template, and cut. Saves a lot of measuring.
https://cimg7.ibsrv.net/gimg/www.rcu...850e99e014.jpg |
Red stripes on fuselage are done. I can start putting equipment in. Still need to do the wing. Each stripe takes me about 15 minutes. The rudder to stab intersection was especially tedious.
https://cimg7.ibsrv.net/gimg/www.rcu...43c98cbfd2.jpg |
The covering is now complete. 44 red stripes that took about 15 minutes each - phew!
https://cimg1.ibsrv.net/gimg/www.rcu...8e86ad0d51.jpg |
Now I can start to install the equipment. I'm going "old school" for the R & E pushrods - threaded rod married to 1/4" dowels. only difference is using medium CA instead of 5 min epoxy to coat the thread.
https://cimg2.ibsrv.net/gimg/www.rcu...4dc37fe3b0.jpg |
Hooked up the pushrods to the servos, using those brass cubes with setscrews - only problem is when I looked at the side view, those cubes stuck up into where the wing goes. *sigh* So I had to remove the servo arms and re-install the connectors upside down.
https://cimg9.ibsrv.net/gimg/www.rcu...09a532aac2.jpg |
Really getting down to the final parts. Here's the free-wheeling tail wheel. I figure that with the large rudder, it will turn the plane, and the wheel will just follow.
https://cimg1.ibsrv.net/gimg/www.rcu...b48ee5632f.jpg |
Ah, the propulsion. Motor attached, and the ESC is nestled in its pocket.
https://cimg4.ibsrv.net/gimg/www.rcu...d06082a056.jpg |
And with that, I declare the plane is finished !
https://cimg7.ibsrv.net/gimg/www.rcu...f306bb62f8.jpg |
Final question - How much does it weigh? The answer, just under 6 pounds with the battery installed ! My old Patties used to weigh 7 1/2.
https://cimg8.ibsrv.net/gimg/www.rcu...06db56ce9d.jpg |
One last item - balance. She balanced right on target without adding any weight.
Looks great and should fly fantastic at that weight! Looking forward to the flight report :-)
Me, too! Hopefully late April. Maybe someone will shoot a video.
Nic |
I went through the dudgeon, and came up with this.....
Here's the whole, complete evolution of all the Peppermint Patties: Niris: I have a print of the original plan w/ some notes - no date on the plans. It was published, however, in Model Aviation October 1975. Niris II: a copy of the original plans, with notes for versions III, IV, V, and VI. Changes noted were engine mount, Aileron placement and shape, rudder cross-section, and the like. Funny thing, I don't remember building all these versions. Unfortunately, no dates are on the plans. Major fuselage changes generated the Peppermint Pattie .60 - I have the original plans, with a note that they were modified in 11/79. Then I found the Peppermint Pattie II ! This is what Master Kit produced, but that was after it was sold from CT to the Midwest somewhere. It was dated 12/81. Notes on the plan state the nose was lengthened 1" for a 16 oz tank, the tail 2" for lateral area, bottom of fuse was made parallel to thrust line for increased side area (read smoother knife edges) Main gear changed to make retract and fixed gear placement the same, gear lengthened 1/2" for ground clearance, and lastly, the fuse doubler was extended beyond the wing TE to disperse forces. (must have been a crash breakage point?) The .60 Pattie was marketed as "the pattern ship of the '80's" Now let's back up to the .15 Pattie: Published in March 1978 R/C Sportsman, I have early photos of my first one, which differ from the Masterkit version. I have a photo of me hand launching it at Rocky Hill. Sadly, I could not find my original plans. I think I gave them to M/K to reproduce, they might have had the same sort of notes I put on the other plans as I evolved each design. Pattie .40: I have the original plans, dated 7/79. Sadly, I only built one of them, and didn't like the way it flew. It needed stab anhedral to prevent a pitch problem in knife edge, I remember clearly having to cut the stab and make the modification. After one season, I sold it at the WRAMS show. I remember doing it after Rhett Miller won the Nats with a .40 Contendor(?) So that's the complete history that I can document. I will findo out what it costs to reproduce plans and keep you posted. By the way, my current .15 Pattie is done like Ed Kasmirski's Taurus, MAN Jan '63 cover. And yes, I had one of those, too. |
My next build will be a Mark's Models Windfree sailplane w/ electric assist. The build thread is here:
https://www.rcuniverse.com/forum/rc-...l#post12818393 |
Tomorrow's weather report is favorable for the maiden flight..... Report to follow tomorrow afternoon.
Unfortunately, no maiden flight. Field was too rutted to take off, she kept nosing into the ground. Next possible attempt will be the weekend of May 3-4
| All times are GMT -8. The time now is 03:59 AM. |
