Draganfly Innovations Products Discuss all the Draganfly Innovations Products in this forum
Another camera mount
Old 01-11-2007 | 09:01 AM
Default RE: Another camera mount
I will post some more when I get home. Yes this replaces the battery tray but can attach over it (not with the SAVS board as the battery extension gets in the way) - however the front leg (riser) inhibits some of the motion. By replacing the existing tray, I am able to attach other mounts (within 10 secs) for different purposes - i.e battery only, night flight lights, or just hacking around.
Old 01-11-2007 | 09:19 AM
Cheers sounds good, will look forward to the pics
Old 01-11-2007 | 11:59 PM
It just occurred to me that your buddy was flying your df with a camera and the sav baseplate...was the wireless camera also attached? I thought the SAV board and wireless camera weigh 4 oz, so that plus your digital camera is dragging an anchor around. I think the baseplate looks like it weighs at least 2 oz. alone?
Old 01-12-2007 | 12:04 AM
I doubt it, the camera was not attached though if that helps
Old 01-12-2007 | 12:19 AM
thanks, I think your flying around with almost 5-6 oz (sav baseplate + digital camera). It is obviously working well!
Old 01-12-2007 | 08:07 AM
  #31
SAVS's Avatar
Even with me not being an experienced pilot, I had the video and still cameras attached at the same time and flying was not a problem. I was surprised that I did not even have to get into the throttle much more than usual, although I did have to launch out of a 5 gal bucket...
Old 01-12-2007 | 03:13 PM
  #32
Do you recall your flight time?
Old 01-13-2007 | 08:28 AM
  #33
SAVS's Avatar
My flight time was limited by the sudden power outages resulting in frame customization (crash!) but with the GentLED set for 8 seconds and I guess I was aloft about 3 minutes the last flight doing the math I got a bunch of pictures. If (again) I was an experienced pilot I would not need more than 5 minutes to take all the pictures I needed at each athletic facility I am taking stills of. My DF came with the HD motors and I did not notice any real heating up of the motors (although the mud packed into the bottom of each motor made a good heat conductor).
Old 01-13-2007 | 10:17 PM
  #34
And the gentled...Well your pics are pretty sharp, can't wait to see more when you get your DF back. Shouldn't be too much longer, DFI should be thawing out a bit now. I hear the temp in Saskatoon was -40C for a few days (thats so cold that you no longer need conversion -40C=-40F).
