E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
E-FLIGHT BLADE CP
Old 06-03-2006 | 08:38 AM
  #3426
djdavidcp's Avatar
Default RE: E-FLIGHT BLADE CP
My Blade CP is green with envy. Yesterday I finally got my Trex 450 SE all setup and flew four battery charges through it. Man oh man! It is so stable it's almost boring to hover. When you guys are ready to upgrade, I would highly recommend the Trex. I am amazed at how this bird flies. The rotor sound is pretty incredible too. I'm glad I started with the Blade though, because Trex crashes are going to cost a lot more than the Blade crashes.
Anyone know of a good Hughes 500 fuselage that fits the Blade? I think I'm going to bling it out, now that I won't be flying it as much.
Doug
Old 06-03-2006 | 12:18 PM
  #3427
Nice ,
im having trouble flying my heli
it seems stable but im not sure since i can only hover for 5 or 6 seconds and it goes into ground effect and hits something lol . been windy ALLLLLLL week , so hopefully today i can set it up and go fly..
i hope i can not a sighn of wind ( pray for me )
todays a new day , i hope i finish my heli
ohh nad yeah im gonna build a blade balencer today
i just need to find my protractor
Old 06-03-2006 | 01:37 PM
  #3428
freeonthree's Avatar
Try this and see if it helps... Don't try to hold the heli in one spot, just keep it moving around a bit, that way your flying it instead of chasing it. Trying to keep it in one spot is not important, but being in control of it is... Remember to keep the heli always moving, and keep the tail pointed at you for now. Let me know if that helps, it sure helped me when Lacey gave me that advise...
Old 06-03-2006 | 01:45 PM
  #3429
k ill try that when i reassemble the damn thing
im gonna do it after i get back from the movies
Old 06-03-2006 | 01:52 PM
  #3430
Don't try to keep the heli in one spot... thats not important... Keep the heli moving constantly, that way your flying it, instead of chasing it. You'll just keep crashing if you keep chasing it. Don't let the heli fly you. LOL Let me know if that seems to be helpfull. When Lacey told me that, it changed everything, and I was hovering like a champ very quickly.
I posted this twice accidentally. After I posted the first one, I looked and it wasn't there... now their both there. LOL OOPS !!! Oh well, good advise is good twice I suppose. LOL
Old 06-03-2006 | 02:15 PM
  #3431
IMAC781's Avatar
Talon you could balance the entire rotor just as easy...this is what the main shaft really feels.
[link]http://www.bladecprepair.com/man_mr_setup_and_adjustment#balance[/link]
Old 06-03-2006 | 02:24 PM
  #3432
thats what i do as well..
i think my shaft is bent
but how do i get it off the gear?
cause i cant get it out lol
http://img376.imageshack.us/img376/9016/dscf00036sn.jpg
HEHE , Can you see were i got the idea ! ?
Old 06-03-2006 | 02:30 PM
  #3433
First undo the control tray pushrods from the swashplate. Pull the pin and remove the head. With a small file, remove all burrs from around the pin hole in the shaft. Loosen the collar and remove it. Eyeball and straighten the shaft with pliers the best ya can. The shaft may not come out easy, and will probably require the use of a a small hammer or simular tool, and a long skinny punch, nail or whatever. The shaft is part of the gear, and they don't seperate... Also, you need to remove the skids and battery tray...
Old 06-03-2006 | 02:34 PM
  #3434
Just in case ya don't have this yet...
http://bladecprepair.com/smf/index.p...e07c15659a51c&
Old 06-03-2006 | 02:36 PM
  #3435
These guy are great, and even make stuff for the BCP...
http://bladecp.corocks.com/
Old 06-03-2006 | 02:38 PM
  #3436
This dude teaches you how to fly without crashing if ya don't cheat. LOL
http://www.dream-models.com/eco/flying-index.html
Old 06-03-2006 | 02:45 PM
  #3437
IMAC781's Avatar
I've decided to try a direct drive tail rotor mod using the GW/EDP-50H motor. I notice it is not grounded from the negative terminal to the case like the stock tail motor. Do you guys think this is important?
Old 06-03-2006 | 04:36 PM
  #3438
yeah i have Rads school of flight ,
cept lost it so im gonna have to reprint it lol...
and i should go threw that this weekend
well im gonna figure out a way to rebend my main shaft
but one thing . does it come all the way out ?
cause its kinda hard getting it threw the swash plate
Old 06-03-2006 | 05:19 PM
  #3439
zooland1's Avatar
ORIGINAL: IMAC781
I didn't worry about it on mine and have had no trouble.
Old 06-03-2006 | 05:27 PM
  #3440
zooland1's Avatar
ORIGINAL: {EH}Talon
If it's bent it can be dificult to remove. Just don't force it. Remember, there are two bearings involved which are designed to be an exact fit so you may need to slightly straighten it by hand to get it to come out. You don't want to damage the bearings. Also, the bearing guide set screw may have put a burr in the shaft which will have to be filed smooth before you can get it through the bearing as well. Once you straighten the shaft, slide a bearing down it to make sure it fits. Lightly file it if it catches along the length then put a drop of thin oil on it. If the bearing slides on smoothly you'll have no problem with the swash.
Old 06-03-2006 | 06:07 PM
  #3441
Gonna have to buy a new one
some how when it was in the dremel and i was testing it it went to full speed and with just a LITTLE wobble the thing bent into an L shape
i tried my Df4 Main shaft and it dosent work either
Old 06-03-2006 | 07:57 PM
  #3442
does anyone know if there is a brushless available for the cp tail rotor?
Old 06-03-2006 | 08:27 PM
  #3443
heliyardsale's Avatar
Well, This is my first post here... I've been lurking for a while and have picked up some great advice. I have had my CP since Dec 2005 and I have to say it is one frustrating piece of plastic! Damn! It seems like every time I take it out, the littlest nick against the blades (switched to CF) and the main shaft and rod that attaches the blade grips both get trashed. Very Frustrating! Is there anything (short of selling it and getting a Raptor) that I can do to increase the strength of the mainshaft and bladegrip shaft? I'm at my wits end with this thing!!
Old 06-03-2006 | 10:23 PM
  #3444
zooland1's Avatar
ORIGINAL: heliyardsale
Yes, learn to fly....just kidding. What's probably hurting you the most right now is the CF blades. They are unforgiving in even the smallest crash and the torque will bend or break everything else. I know it's really easy to damage the wood blades, but they can (much to the dismay of some) be repaired if careful. I got my blade in November, have replaced the blades only twice and the main shaft only once. And I'm a lousy pilot compared to some of these guys. I crash a lot, just not as much as I used to. The main thing is to allow yourself time to learn. Take it easy. A wise man once said, if the heli is not in "your" control, you have to do too much to get it back in control and more likely you will crash. Keep it low to the ground for a while. That way if it starts to get away from you, you can always set it down quickly. Being able ti fly indoors (no wind or grass to worry about) and slide around on wood floors helped me a lot. If you can't do that, throw down a sheet of plywood.
If you haven't checked out "Radd's school of rotary flight" do it now
also check bdavison's build thread and bladecprepair.com to verify your setup is good.
Patience will save you money and don't be shy to ask questions.
Old 06-03-2006 | 10:29 PM
  #3445
zooland1's Avatar
ORIGINAL: collinsurf
the only ones I've seen were homemade. You can use the parts from an old cd rom and make one quite easily. You can even buy a kit from gobrushless.com. if you're shy about a scratch build.
Old 06-04-2006 | 01:07 AM
  #3446
hehe
i keep it about 6-12 inches off the ground and always hit stuff
i know why thoe
cause im flying in mabey 8 foot square area if that mabey 5 or 6
so im going to the park when i buy myself a new main shaft
Old 06-04-2006 | 09:26 AM
  #3447
Any word on the new plastic blades yet? I am going to try an experiment later today. I have a cheap 2 channel Dragonfly heli that I bought from radtech for 40.00 a while back. Even though its really low tech the thing is indestructable. I've hit trees 25 feet up and the thing slams to the ground and just bounces. I flip it over and up she goes again... I have crashed it at least 15 times hard with no damage, its crazy! It's fixed pitched and has really soft rubbery coated blades that are about the same size as CP blades, I think I'm going to pull the blades and try them on my CP just to see if it will fly with them.....
Old 06-04-2006 | 09:42 AM
  #3448
theradioflyer's Avatar
Hey guys, thanks for the compliments! The song on that one is for Time Life's Big Band compilation. I'm having such a good time. Heliyardsale,( BTW great name), I wouldn't go with stronger blades cause you'll just break more expensive parts! You might be able to repair the woodies if they're not to baddly damaged. I put plastic blades on and that's when I broke alot of stuff, including bending my main shaft and snapping the tail boom in two.
Old 06-04-2006 | 02:20 PM
  #3449
djdavidcp's Avatar
Hey guys,
I thought you might enjoy this little video I shot this morning. It was pretty windy above the trees, and I almost lost control, but it came back safely.
http://www.dougsuniverse.net/images/...kyard1_340.wmv
You might have to right click and "save as" to view it.
Doug
Old 06-04-2006 | 07:02 PM
  #3450
Hey all, been reading this thread for over 3 weeks trying to catch up with the end, made it! First off, some very good info buried in here on many problems and good advice on flying this lil p.o.s. weakling. I have had mine for about 4 or 5 months and wish I had never laid eyes on it and bought a decent one instead. Mine flew for awhile and developed every problem known or seen in this forum. First the sticky collective, repaired and moved on, then tail rotor dying mid flight, repair and move on. Even 4 in 1 problems. I thought it was just me at first but have had experienced fliers help with setup and flying and even they said it was the weakest helo they ever saw! If it gets set down with anything less than perfection it's a boom strike, if it gets hard rear cyclic a boom strike, WHAT A PIECE O'WORK!!! other than that I love the size and quietness as this is my first non nitro chopper. I am cutting my losses now and gluing what i can and when that don't work it's dumpster time for the unholy monstrosity! Any suggestions for small size e-helo that is less pricy than a t-rex but MUCH stronger and better built than bladeCraP? sorry for rant, another boom strike today and shattered it again, any suggestions welcome
