E-FLITE BLADE CP PRO
#1426
CA
ORIGINAL: karl k
I don't know how you guys feel that the 2100+MAh batteries are suitable for the blade.
They are HUGE and way heavier than the stock battery. I get 12 minutes of hovering off of the stock pack before I have to land. With a batter that is that heavy, I would think the performance would suffer immensely. The stock motor would also not have any chance of lasting at all. I wouldn't mind some more flight time, so I may go up to a 1500MAh or so battery, but you guys are talking about lifting the Trex batteries!!
I just don't see the advantage.
Karl
Karl
Maybe you're right. I use 3S 2100mAh batteries for a plane - stryker27c, and there is no way I could use that battery on this heli. I just thought maybe the batteries were 'different' somehow. I guess before buying any battery of a different size, it would be important to see the specs on size and weight and compare them to the stock blade CP lipo. I wouldn't want to go to much heavier or bigger.
#1427
Hey Holyschmoley, You really need to think twice before going up to a 2100. I have one that I tried out in my CP. She rally had a hard time getting off of the ground. No problem for the 450 SE or Walker60 size of heli though.
I would recommend not going any higher than a 1500 battery just because of the payload your heli is carrying.
But that is only my opinion!
Michael
Michael
#1430
CA
ORIGINAL: mykul812
Michael
Michael
Oh, I'm not. I was just saying in my last post that I use those 2100 mAh for an airplane (that they're meant for). I wouldn't put that thing on my blade. It's huge. I was just wondering if there were different smaller batteries or something, but that was just ignorant thinking. I took a look at a ton of batteries today and the different specs including weight and size compared to the stock battery. I think going up to 1200 or so might be okay, but when it came down to price, I just said forget it and I'm going with the $17.00 battery in my other post that has the same specs as the stock blade lipo. I just want a 2nd battery for now. I'll see about picking up something with a little more mAh late.
#1431
Holyschmoley,
I understand what you are saying!
Just remember what I posted after your post about ALL Battery. Although their price is good, the connector (white molex) is wired BACKWARDS! So if you find yourself with a different balancer / charger set up, you will need to be VERY CAREFUL about how you plug into the balancer or otherwise you will FRY yours as I FRIED mine [&o]
#1432
CA
[link=http://stores.ebay.com/AplusRCstore]A+ Enterprises[/link] That is the link.
If the 2100mAh battry will work. Using the stock motor probably not. I had no choice because as I said before I bough a BL motor rated for 25A cont. so I needed a 2200mAh 15C cont. battry
ORIGINAL: holyschmoley
Where'd you get the 2200 mah lipo. You mentioned the name of the company, but do you have a link?
ORIGINAL: Commander_Bob
The rating on that battry is the same to E-Flights, that is if it is any good. I bought a no name 2200mah lipo off A+Enterprises and it looks very nice. I have not actualy flow it yet but it charged nice and cool on the stock e-flight chargers. I have 2 stock battries and they don't supply much power. If I were you I would look for one that has a little more kick like 800mah 15C or even 20C continuous. (20 is probably over kill). Thunder Power has a nice 910mAh 16C 3s for $46.
Wow that was lucky... I just look at the pic again and you right it is fliped. Luckly the one I got was right.
ORIGINAL: Lilpilot13
Comander Bob,
Hey, I was wondering would a 2150mah 3s1p 11.1V Vli Po battery work on the blade CP Pro without any modifications? It is a 25c 53.75 Amp Contunous, 40C 86Amp Bursts.... Or would it be too heavy to lift off, or would it blow the motor? Thanks Comander Bob!
Comander Bob,
#1433
ON, CANADA
[sm=confused.gif][sm=confused.gif]if you bought a 25A cont. motor, doesn't it mean that it can handle up to 25A? and not "have to run 25A or else"?
#1434
ORIGINAL: chopperdudes
If I remember right from previous posts, Commander Bob basically run the Trex 450 power system in a blade.
That includes the battery, motor and ESC.
Karl
#1435
CA
That is right. If you have a 25A cont. motor and a battry that can only supply 8-10A (stock e-flight) then it will over heat and may explode. Also if you have a 15A esc then the motor will try to take 25A. Remember that ESC pulse the current, so for a 25A motor at 50% throttle it will take 25A half of the time. I have a 35A align Bl esc, 3800Kv motor, and 2200mAh 15C battry. I can't wait to try it. I need a deans conector, spliter (tail and main esc) Pinion and some luck.
#1436
I have been reading up on this forum for several weeks, and have just recently gotten to the end of it. I just recently bought a Blade CP Pro because the LHS had a good deal on it, and they carry all the parts (they only carry e-flite and the t-rex parts for heli's, so most other heli's were out), plus they carry them all at internet pricing to keep the business local.
I also had alot of trouble because the tail rotor is not working properly. I have full right trim on the left stick, and I still have to give it 1/2 to 3/4 right stick on the rudder to keep it straight. I didn't know how to adjust it, so I just left it. I think you adjust it with the pot on the 3 in 1 that is between the other pot (gyro I think) and the LED. How much do I need to adjust this? Is it pretty sensative, or should I just do something like 1/16th of a turn with the battery unplugged, then reinitialize and test it out?
I am trying to get the spindle out to replace it because it is bent. I've got the bolt out of one side, and the paddle control frame off, and the screw out of the bell mixer arm but the blade grips wont come off. I haven't pulled very hard because I am afraid that some of the small peices will come flying out, and either I wont find them or I wont know which order to put them back in. Also when you put things back together, on the screw that goes through the mixer arm and the screws that go into the spindle, how hard are they supposed to be tightened?
I know this is kind of long, but I couldn't think of a way to shorten it, except putting the crash in a different post =)
#1437
This is my crash story
To make a long story short, when I got my helicopter they did not have any of the training gear, so I made some out of wooden dowels and waffle balls. I used 1/4" dowels trimmed down to just over the length of the blades. This worked quite well (though the dowels were somewhat heavy for the chopper), and I flew a battery pack once a day for a week without any major events. The LHS got the regular training balls in stock so I bought some of them because they were lighter. I attached them the same way I attached the dowels. I had been hovering quite well in about a 2 foot cube, except I usually had one time per flight where it would get away from me (I think this might be atleast in part because of the proportional pot needing to be adjusted), and I would have to throttle down and let it skid across the hardwood gym floor. This worked alright when I had the wood skids, but because the new skids were flimsy when they hit the ground the zip ties slid off and that in combination with the bounce that those new skids had, I got a boom strike from comming down from about 1' up (yes still very much in GE). I couldn't believe that it had such a terrific crash with such a small height.
Because I had plasti blades and super-skids, the only real damage I received was a bent spindle and a couple of dents in the blades.
#1438
CA
Finally a decent flight. I had the blade cp. I was careful about learning to hover but did so on my 8X12 deck mostly surrounded by brick on 3 sides. I took a few crashes, of course, here and there. Long story short, over a few months of being able to hover well I went through a few parts (1 4in1 among many others) and my blade eventually flew like crap. I was fed up with troubleshooting the problems and sold it on Ebay. After a few months I just got the blade cp pro after having the blade cx2 for the past couple months, previously. I've got to say, the blade cx2 is a fun and quality heli for playing with indoors. If you want 1 keeper heli to fly indoors, get it. Anyway, so I got back to the cp pro today. I couldn't make it to the park but while hovering well finally had the confidence to take it up to 10, 20 and then about 30 or 40 feet in the air and take it behind my house into an open wilderness area. I flew it for awhile there and then back, carefully and maybe a bit wobbly at times. My 2 yr old daughter got in the way of my landing area, and in my distraction got a little crazy and within probaby a couple inches of my house. My heart pounding after that, I landed it, and all is well with my new cp pro uncrashed as of yet. It's nice to finally have a 'real' flight under my belt vs. just hovering. It's frustrating learning these things as a new pilot and seeing your $250 heli crash, not knowing how much the repairs will cost or even if you can make them. Eventually, if you enjoy it and stick with it and it's worth it.
So tomorrow I'm going fulll throttle and upside down. Or maybe that'll be next week.
#1439
Great. I'm just learning to fly my Blade CP Pro, it's my first heli ever, but i am only 13 so i will probly have many more to come. I'm thinking of getting the Flat bottom plastiblades because with the stock blades, i got a little to close to a flower box and ticked the blades on it. It looked fine so i centered it again. But as soon as I rose to about 4ft. the end of one of the blades came flying off and almost hit me, so i am considering plastiblades. Are plastiblades a lot more stronger? and will they help me learn to fly quicker and safer? Thanks for you time.
Lilpilot13
Lilpilot13
#1440
Lilpilot13
Lilpilot13
Hope this helps,
mrasmm
#1441
Lilpilot13,
You will hear a lot of different opinions on this one. My personal experience is that the plastics are Ok but you really want to keep with the symmetrical blade. The flat bottoms are not easier in my opinion. Remember that you still have to balance them--especially when you ding them. Also, when you make one item stronger (i.e. plastic blades), other items that normally won't bend or break are now easier to break.
Just my honest opinion,
Michael
Michael
Lilpilot13
Lilpilot13
#1442
CA
I agree. I have a set of plasti blades symmetrical and before I got them I never broke the blade grips. Now I have 4 broken blade grips.
symmetrical blades = faster head speed more stable
Flat blades = more lift slower head speed and less damage when you crash
I like the symmetricals.
ORIGINAL: mykul812
Lilpilot13,
Michael
Lilpilot13,
Michael
Lilpilot13
Lilpilot13
#1443
Thanks for your help, I geuss when i go to the LHS i will by 2 sets of balsa blades. does one set come with two blades?
#1444
The carbon blades are also nice. You really do notice the difference in cyclic response. And they are really tough. Only problem is, if the blades aren't absorbing the impact, something else down the line will and that means broken parts.
BTW, I finally get to fly outside today for the first time since I got my blade. She's gonna see the world upside down for the first time! Maybe I'll get a pic....
#1445
CA
The guy at my LHS said the CF blades would splinter if you crashed. I still use my plasti blades because $9.99 blade grips are cheaper that $15 blades and I break the grips less.
ORIGINAL: AeroDave
#1448
http://www.helidirect.com/product_in...roducts_id=975
Check those out.............. Get at least 2 sets, and then the shipping isn't dinging you so much.
__________________________________________________ _____________________________________
Of all the things I ever lost............................................ I miss my mind the most!
#1449
Thanks, I will just buy them at my LHS though. Does it make it fly better with teh flat bottom? like would ti be more stable? Thansk for ur help again guys!
#1450
Bob,
I guess if you hit really hard they would break. I don't know about splinter..... Even when I've broken a carbon blade on a Raptor, hitting really hard, they just break in a couple of places. Usually I've just dinged up the tips with these little electric guys. Anyway, its all about what works best for you. I just love the way a stiff carbon blade flies.
