Go Back  RCU Forums > RC Helicopters > Electric RC Helis > E-Flite Helicopters
 BCX2 Outer Shaft Assembly Question >
E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Old 03-14-2008 | 08:12 PM
Default BCX2 Outer Shaft Assembly Question
Is there a "step" washer that goes up in the body
between the base of the outer shaft and the bearing
that is mounted in the body?..and if so, does the ridged
side of the washer go up against the inner bearing?..
thanks for any help...John H.
Old 03-14-2008 | 08:31 PM
Default RE: BCX2 Outer Shaft Assembly Question
Hello John,
Per the book yes there is one! If you would the parts break down page from the CX 2 book I scanned for you and I can send off to you in an email, let me know. However, only today I took down my friends C2 to the bones for a bad crash. If there was one there it stayed in place in the body so I did not see it. There must be some kind of wear to show you which way it goes if this is something left from your repair job? My gut tells me the step goes up as to my memory from this morning I did not notice any step on the gear and shaft, I kinda took a peek looking for light grease.
Sorry I cannot give a diffintive answer on the step washer for side up or down.
Old 03-14-2008 | 08:32 PM
Yes-- that ridged washer is important. The ridge goes towards the bearing, and presses against the inner race that turns with the shaft, and keeps the plastic gear from rubbing against the outer part of the bearing, that should not turn. Without the washer, there is drag and wear.
Old 03-14-2008 | 10:21 PM
without that washer over time your bearing will bind to the top of the outershaft gear. Yes the beveled part faces upward.
Old 03-14-2008 | 11:01 PM
eat2muchrice's Avatar
heres a picture
